30th September 2008, 13:31 | #463 | Link |
@xopowo
Have you tried installing the latest version of the Nvidia drivers: 178.13? Also, please ensure that you have only one instance of nvcuvid.dll present and that it is the one shipped with the version of DGAVCDecNV that you are using (which should be 1.0.1 or 1.0.2). Make sure you have one version of the DLL in your system32 directory and no others anywhere else (including your Avisynth plugins directory and the directory that DGAVCDec is installed and its subdirectories). What video card do you have? How much memory does it have? Last edited by Guest; 30th September 2008 at 13:37. |
30th September 2008, 17:22 | #468 | Link | |
I'm referring to this pic here: http://forum.doom9.org/showpost.php?...&postcount=380 The sample is still here (It's frame 92): http://forum.doom9.org/showpost.php?...&postcount=298 dgavcdecnv102 gives the following result: command line: Code:
DGAVCDecodeNV_AVCSource("00014.dga", deinterlace=true) |
1st October 2008, 14:14 | #469 | Link | |
NVIDIADisplayWin2K(177_84)Int.exe ** that is the name of the driver I'm using. I went to the nVidia site again and this is the only one that it lets me download? nvcuvid.dll - I have one on the box and it is in the \system32 folder. VIDEO CARD - GPU Type : GeForce 8600 GTS GPU Clocks : Core 675 MHz / RAM 1008 MHz GPU Memory : DDR3 256MB |
1st October 2008, 14:39 | #470 | Link |
http://www.nvidia.com/object/winxp_178.13_whql.html
It's quite possible that you don't have enough memory on your GPU card. |
1st October 2008, 15:04 | #472 | Link | ||
1st October 2008, 17:26 | #474 | Link | |
LONG time lurker... 1st time poster.
I'm giving it a try on the 8500 tonight and I'll report back. |
1st October 2008, 20:11 | #475 | Link |
For multi-instance, you're going to need a lot of memory. My 8500GT card has 1024MB.
BTW, regarding problems in MEGUI, etc., I am working on a solution such that all instances use a single instance of D3D and float the CUDA contexts. If this succeeds it will have the useful consequence of dramatically reducing memory needs for multi-instance. I'm not concerned about the overhead of floating contexts because in practice the usage is serialized. |
1st October 2008, 20:45 | #476 | Link |
neuron, have you done tests to see what speed difference different cards make, is the ram alot more important than the clock speeds or the memory speeds? Would help quite alot of people.
I know this is off topic but does the amount of ram make a massive difference for DXVA-HD-Balanced x264 profile in megui? As i use the following tools to create my 720p bluray encodes and not dgavc: GraphStudio, Eac3to, x264, AVSP, AviSynth, FFmpeg source, MeGUI, Haali, ffdshow, SurCode DTS, Arcsoft DTS DLLs, Arcsoft Total media. |
1st October 2008, 23:14 | #478 | Link |
x264aholic
Would it theoretically be possible to utilize two cards to help with multi instance decoding? I could imagine the instances would be split between the two.
You can't call your encoding speed slow until you start measuring in seconds per frame. |
2nd October 2008, 08:10 | #480 | Link |
To neuron2:
Well, may be little offtopic, but I am confused. I would like to pay for your product, but have no PayPal account and would like to avoid creating the one. On your WEB page you were stating: "Note that you do not need to have a PayPal account; you can pay with a credit card account also.", but when I do go to "Donate" page, the only option is to create the PayPal account... Is there the way to pay by Credit card WITHOUT creating this account? Screw |
