19th December 2008, 12:08 | #7421 | Link |
Jup that one.
No change with 2.80 :-( a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [a04] Decoding with libav/ffmpeg... [a04] Swapping endian... [a04] Remapping channels... [a04] Creating file "G:\Hancock\audio2.pcm"... [a04] The original audio track has a constant bit depth of 16 bits. Video track 2 contains 147076 frames. Video track 3 contains 147076 frames. eac3to processing took 28 minutes, 12 seconds. Done. |
19th December 2008, 15:42 | #7423 | Link |
But why does it register gaps when extracting the AC3?
[a05] Extracting audio track number 5... [a05] Removing AC3 dialog normalization... [a05] Creating file "G:\Hancock\audioac3.ac3"... [a05] Audio overlaps for 27ms at playtime 0:05:51. [a05] Audio overlaps for 23ms at playtime 0:27:55. [a05] Audio overlaps for 16ms at playtime 0:32:31. [a05] Audio overlaps for 9ms at playtime 0:34:13. [a05] Audio overlaps for 20ms at playtime 0:48:54. [a05] Audio overlaps for 18ms at playtime 0:49:56. [a05] Audio overlaps for 17ms at playtime 0:52:28. [a05] Audio overlaps for 29ms at playtime 0:53:10. [a05] Audio overlaps for 31ms at playtime 0:57:34. [a05] Audio overlaps for 8ms at playtime 1:04:46. [a05] Audio overlaps for 25ms at playtime 1:07:09. [a05] Audio overlaps for 7ms at playtime 1:10:47. [a05] Audio overlaps for 23ms at playtime 1:13:47. [a05] Audio overlaps for 24ms at playtime 1:15:20. [a05] Audio overlaps for 18ms at playtime 1:25:56. [a05] Starting 2nd pass... [a05] Realizing (E-)AC3 gaps... [a05] Creating file "G:\Hancock\audioac3.ac3"... |
19th December 2008, 18:45 | #7428 | Link | |
You seem to think that there MUST be a message about gaps/overlaps, or else there's something wrong. But that's not the case. Thanks for the confirmation. |
20th December 2008, 07:03 | #7429 | Link |
madshi
I've noted two titles that break eac3to both 2_81 and 2_82 as well as 2_83. Seems to relate to handling over audio gaps/overlaps. Eac3 eventually fails with "The temp file could not be interpreted correctly." The original ISO's play fine in PDVD8 and TMT Logs are attached (I hope) Last edited by williewonton; 20th December 2008 at 07:05. Reason: adding attachments |
20th December 2008, 10:57 | #7431 | Link |
Pig on the wing
When converting mono AC3 tracks to MP4 using Nero, it seems that they are converted to stereo. Is there a way around this?
20th December 2008, 14:29 | #7433 | Link | |
That's very weird. eac3to is trying to crop the resolution to 1080i. Don't know why you get 1084i. Must be a bug in eac3to. It works fine for German 1080i50 broadcasts, though. Can I please have a small sample of the TS file? 20MB should be enough. Thanks! |
20th December 2008, 15:16 | #7434 | Link | |
eac3to mono.ac3 mono.mp4 NeroAacDec mono.mp4 -> mono.wav Foobar mono.mp4 -> mono.wav but ffdshow mono.mp4 -> stereo.wav Faad mono.mp4 -> stereo.wav Bass mono.mp4 -> stereo.wav
20th December 2008, 15:19 | #7435 | Link | |
Pig on the wing
By the way, this command line writes the output in the eac3to folder with the name "enarnia.wav": Code:
eac3to "y:narnia.ac3" "e:narnia.wav"
20th December 2008, 15:20 | #7436 | Link |
Pig on the wing
I opened the file in MediaInfo, it showed that it's a stereo file. Also the avg bitrate is pretty much the same as a regular stereo file has at q 0.4.
20th December 2008, 17:36 | #7437 | Link | |
eac3to v2.83 command line: "D:\Test\AudioN\eac3to\eac3to.exe" "D:\Test\AudioD\Samples\ac3\1a100.ac3" mono.mp4 ------------------------------------------------------------------------------ AC3, 1.0 channels, 0:00:20, 96kbps, 48khz The Nero decoder doesn't seem to work, will use libav instead. Decoding with libav/ffmpeg... Reducing depth from 64 to 32 bits... Encoding AAC <0.50> with NeroAacEnc... eac3to processing took 1 second. Done. Code:
... Codec : AAC LC Bit rate mode : VBR Bit rate : 16.0 Kbps Maximum bit rate : 103 Kbps Channel(s) : 1 channel Channel positions : C Sampling rate : 48.0 KHz ...
20th December 2008, 18:01 | #7438 | Link |
Pig on the wing
Strange..now I'm unable to reproduce the problem - the final mp4 file is in mono I must have chosen the incorrect file in MediaInfo because of the bug I posted (the path in the eac3to command line is parsed a bit wrong). I usually cd to working directories in MS-DOS prompt and then use the drive letters only for paths.
Sorry
20th December 2008, 20:39 | #7440 | Link | |
madshi
Game Plan - Region B Open Season - Not Locked |
eac3to |
