Old 13th February 2015, 07:47   #1501  |  Link
Kupildivan
Is there any really working plugin which allows to import 16-bit PNG sequence?
When I'm trying to use ImageMagick writer/reader it says:
Script evaluation failed:
Python exception: Read: Failed to read image properties: vspipe.exe: RegistryKeyLookupFailed `CoderModulesPath' @ error/mode.c/GetMagickModulePath/662
Traceback (most recent call last):
  File "vapoursynth.pyx", line 1488, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:25136)
  File "G:\Sintel\VS48.vpy", line 9, in <module>
    v = core.imwri.Read(r'G:\Sintel\00002564.png',24000,1001)
  File "vapoursynth.pyx", line 1387, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:23631)
vapoursynth.Error: Read: Failed to read image properties: vspipe.exe: RegistryKeyLookupFailed `CoderModulesPath' @ error/mole.c/GetMagickModulePath/662
Also VS doesn't want to import with vsimagereader-0.2.1:
"No frame returned at the end of processing by Read"
and vspipe crushes.
Tried both 32 and 64 versions of both plugins and nothing.
Kupildivan is offline   Reply With Quote
Old 13th February 2015, 12:51   #1502  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Is this really with imwri test6?
Myrsloik is offline   Reply With Quote
Old 13th February 2015, 15:34   #1503  |  Link
Kupildivan
Thanks for help! I had imwri test4, but with test6 now it's ok.
Old 17th February 2015, 17:50   #1504  |  Link
RTW47
Rome Total War
RTW47's Avatar
1. was expecting to receive error then concatenating two or more different fps clips. I'm right that vs will take fps value from the first clip and then automatically apply AssumeFPS/(speed adjustment) on the rest of the segments? If so, there should be no difference between adding AssumeFPS manually and letting vs do this internally?
2. noticed also there is an optional parameter for vapoursynth resizers,- yuvrange, but not mentioned in the documentation for some reason(s)
GOTO:EOF
RTW47 is offline   Reply With Quote
Old 17th February 2015, 18:06   #1505  |  Link
Myrsloik
Myrsloik's Avatar
1. The check has now been fixed in both splice and interleave
2. It's because swscale rarely cares about it.
I plan to rip out swscale and use zimg instead in the next release if I have enough time to work on it.
Old 19th February 2015, 16:11   #1506  |  Link
lo1t3yu
Hello. How use qtgmc in vapoursynth for doubled frame rate deinterlacing?
lo1t3yu is offline   Reply With Quote
Old 19th February 2015, 17:40   #1507  |  Link
MonoS
In the same way you used it in avs, be sure to have all the necessary plugins
MonoS is offline   Reply With Quote
Old 20th February 2015, 19:18   #1508  |  Link
Kupildivan
Are they have to be the ported ones? Or native avisynth plugins will work too?
Old 20th February 2015, 19:28   #1509  |  Link
Are_
Vapoursynth's QTGMC works with vapoursynth filters only, except for the denoising. It uses avisynth's fft3dGPU and FFT3DFilter if they are selected, else it uses native dfttest.
Are_ is offline   Reply With Quote
Old 20th February 2015, 20:15   #1510  |  Link
MonoS
As Are_ said all plugin are native, for avoiding to use avs plugin remember to set denoising to at least Slow or set manually the denoiser to dfttest [also you can use 16bit precision if you want ]
Old 20th February 2015, 22:25   #1511  |  Link
lo1t3yu
It's clear, but interestingly how ffms2 decoding interlaced sources now. Is correctly (for smoothed 2x fps with phases saving)? I don't know about 2.20, may be interlaced sources now is fully supported... Else have need to use directshowsource2 that impossible in vapoursynth.
Thanks to all vapoursynth's (and plugins) devs for the crossplatform and modern frameserver!
Old 21st February 2015, 16:44   #1512  |  Link
MonoS
Have you tried with lsmash??
Old 21st February 2015, 16:45   #1513  |  Link
YamashitaRen
I confirm that lsmash works fine. ffms2 with "threads=1" should works too.
https://github.com/vapoursynth/vapoursynth/issues/139
YamashitaRen is offline   Reply With Quote
Old 23rd February 2015, 15:27   #1514  |  Link
lo1t3yu
No, i will try later.
ffms2 works even without param 'threads=1'.
Also, vs works and all needed plugins loaded.
libaddgrain.so libdeblock.so libffms2.so libgenericfilters.so libmvtools.so libscenechange.so libtemporalsoften2.so libyadifmod.so
libdctfilter.so libeedi2.so libfmtconv.so liblsmash.so libnnedi3.so libtdeintmod.so libtemporalsoften.so
import vapoursynth as vs
import havsfunc as haf
core = vs.get_core()
v = core.ffms2.Source(source='2_1080i.mkv', fpsnum=25, fpsden=1)
v = haf.QTGMC(v, Preset='Slow', TFF=True)
v = core.fmtc.resample(v, w=1280, h=720, kernel="spline64")
v.set_output()
vspipe --y4m script.vpy - | x264 - --demuxer y4m --crf 20 --profile high --level 4.1 --preset slow --output encode.mkv
Script don't show errors, but x264 breaks:
x264 [error]: could not open input file `-'
Streaming into pipe also don't works.
If script runned without qtgmc then x264 encodes stream.
v = core.nnedi3.nnedi3(v, field=3)
v.set_output()
It works.
x264 compiled with options: --enable-static, --enable-shared
Old 23rd February 2015, 15:45   #1515  |  Link
jackoneill
unsigned int
jackoneill's Avatar
vspipe should output some error message, but if you don't see one, run this instead, to make sure x264's output isn't overwriting it:
vspipe script.py /dev/null --progress
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 23rd February 2015, 16:00   #1516  |  Link
lo1t3yu
This breaks segfault.
Old 23rd February 2015, 16:20   #1517  |  Link
Are_
Maybe are you using an outdated version of some filter? This does not crash for me.
Old 23rd February 2015, 16:43   #1518  |  Link
lo1t3yu
All libs have been compiled from sources (from here or git). May be required libs were missed? What plugins and which versions are you using?
Old 23rd February 2015, 16:59   #1519  |  Link
jackoneill
unsigned int
jackoneill's Avatar
A missing plugin would result in a different error message (usually).
Did you compile GenericFilters from here? https://github.com/chikuzen/GenericFilters
The original author disappeared and left behind a number of bugs which have been fixed here: https://github.com/myrsloik/GenericFilters.
Old 23rd February 2015, 19:18   #1520  |  Link
lo1t3yu
Thanks! Myrsloik's version of GenericFilters works fine.
speed, vaporware, vapoursynth
