#3521 | Link |
Hmm so installed R46 32+64bit in a vm, only per user installation. 32 first then 64. But only the 32bit version seems to work. (I also restarted the pc)
See here: https://i.imgur.com/QFUOxBu.png What can I do to "debug" this further? EDIT vs 32 has no vsvfw.dll? https://i.imgur.com/2m1WwyT.png Re-install of VS64 didn't help.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 7th July 2019 at 16:00. |
#3522 | Link |
I uninstalled Vapoursynth and Python completely.
Then installed Python 3.7.1 followed by Vapoursynth 64-R46 Worked fine Then I upgraded Python to 3.7.3 This way you get to select per user or all users mode |
#3523 | Link | |
Professional Code Monkey
Loading the module also worked fine in both cases. I have no idea what you're doing wrong.
#3524 | Link |
Import notice regarding installs:
PYTHON FROM THE MS STORE DOES NOT WORK Installing the Python module with the "--user" option in pip ALSO DOES NOT WORK (for example if you want to have VapourSynth in multiple Python environments) I think I'll finally look into the possibility of (optionally) installing python.
#3525 | Link |
Pig on the wing
Because of the "not installed for all users" problem, I uninstalled Python, reinstalled 3.7.3 for all users and then updated VS to R46 (64-bit). Now when I try to import a function, I just get an error "Python exception: No module named 'resamplehq'". In registry, the Python path seems ok and also all my .py files are in their usual location, in C:\Program Files\Python37\Lib\site-packages\vapoursynth.
EDIT: Looks like it's missing the __init__.py file from that Python directory?
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 9th July 2019 at 08:45. |
#3526 | Link | |
Vapoursynth 32 didn't work after installing it as a per user installation. See video here: https://www.dropbox.com/s/a2humc9d4l...32err.mp4?dl=0 (watch with 1.5x speed ;-))
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository |
#3527 | Link | |
Can you verify that you have the vs2019 (or possibly 2017) installed? Not having it could make it fail to load I guess.
#3528 | Link |
Yep that was it. After installing vcredist x86 2019 (14.21.xxx) it worked.
EDIT0: And the runtimes are not shown in this installer bcs they can't be installed with user, rights!? EDIT1 And I think there is a python installer bug or maybe I'm understanding it wrong. Vapoursynth detects it as a "per user installation" and not "for everyone". ![]() EDIT2: OK I can click on "Install for all users" in customize installation. So python launcher and python are two seperate things I guess!? The thing is, on my PC it shows always the "for all users" option by default. ![]()
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 9th July 2019 at 16:50. |
#3529 | Link | |
Pig on the wing
#3530 | Link |
It seems that r46 just copies the dll instead of linking it. A reinstall does not help? You could try the diagnose function in vsrepogui to see which plugin folder is used and if it shows any problems.
#3531 | Link | |
1. You need elevated privileges to create links 2. The Python bits are now installed as a normal package using pip and it doesn't really do links either
#3532 | Link |
You should never have put things in the vapoursynth subdir. That was reserved for VS and nothing else. Make your own directory if you want to do things that way or simply let VSRepo stuff everything into the right place...
#3533 | Link |
Pig on the wing
I think that once it was required to put your .py files containing your own VS functions under site-packages to get them to autoload so you could just import them in your script. It has worked perfectly fine until R46, hence the confusion.
#3535 | Link |
There was a ppa by djcj but it seem to be gone. See here (and sublinks) https://github.com/vapoursynth/vapoursynth/issues/455
EDIT his git repo: https://github.com/darealshinji/vapoursynth-plugins
#3536 | Link |
@ChaosKing: I know about djcjs repository problem is it doesn't get updated any more (even the repository is 'archived'), I spoke with him and he's trying to make a 'build' script for all the filters, but I was wondering if somebody already did that and may be shared it with others.
![]() --- For those interested in the issue: https://github.com/darealshinji/scri.../master/Hybrid (currently not 'finished' or 'well tested', but probably helpful)
Hybrid here in the forum, homepage Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,.. Last edited by Selur; 17th July 2019 at 19:45. |
#3537 | Link |
Got an issue on Linux, regarding:
Cu Selur |
#3538 | Link | |
speed, vaporware, vapoursynth |
