Old 3rd February 2019, 20:03   #3301  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by Boulder View Post
Thanks, looks like I'll skip it then. I was just thinking about testing it in case Zopti starts crashing the native plugin which probably doesn't have all the fixes and tweaks from the AVS version. It's been quite some time since the last commit.
Just report the bugs you find and they should probably get fixed quite quickly.
Myrsloik is offline   Reply With Quote
Old 3rd February 2019, 22:26   #3302  |  Link
gonca
https://forum.doom9.org/showthread.php?t=154696
Originally Posted by asarian View Post
I tried to whip out the old SupTitle.dll (as I remembered it can do 'relocation'), but that wouldn't run somehow:
core.avs.LoadPlugin ("C:/VS/plugins/SupTitle.dll")
Should still work, right?!
EDIT: Yeah, that's an old 32-bit filter. Nevermind.
gonca is offline   Reply With Quote
Old 3rd February 2019, 23:04   #3303  |  Link
zorr
The latest released version crashes... a lot. I recommend using the version jackoneill shared after fixing this issue (download link available at that url).
I have another issue open, hopefully that one can be fixed as well. But I totally understand it can take time, the author is doing this on his free time after all.
zorr is offline   Reply With Quote
Old 4th February 2019, 05:32   #3304  |  Link
Fabulist
Hello,
May I ask if there is some kind of guide or documentation to help me make VapourSynth work with PotPlayer (more specifically, with madVR/SVP)? I have been researching this for days; I run multiple different installations of both VapourSynth and PotPlayer, seemingly appropriate, but I simply cannot make it work with PotPlayer itself, and of course not with anything else - I have no idea what I am missing.
Sorry to bother, and I am sorry if this is not the right place to ask.
Fabulist is offline   Reply With Quote
Old 12th February 2019, 07:31   #3305  |  Link
hydra3333
Intel claim to speed up python runtime by 20x, for free
https://www.infoworld.com/article/33...lq_cid=4495538
Intelís distribution is a tuned version of the open source Python we all normally use. Itís been prebuilt to deliver much higher performance by a variety of methods, but most importantly by relying on the Intel Performance Libraries to accelerate x86 and x86-64 performance. This means that performance improvements can come without changing our Python code.
I suppose this does not have any relevance to vapoursynth ?
Cheers
Old 12th February 2019, 11:17   #3306  |  Link
asarian
Cheers
Probably none. The real work is done in the filters.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 13th February 2019, 14:17   #3307  |  Link
RainyDog
Vapoursynth newbie here.
Can anyone help me get this bbmod AVS port to work please?
I assume it should be something along the lines of the below syntax but with the correct instruction to replace the *?
clip = core.*.bbmod2(c, cTop = 0, cBottom = 0, cLeft = 0, cRight = 0, thresh = 128, blur = 999)
RainyDog is offline   Reply With Quote
Old 13th February 2019, 16:00   #3308  |  Link
Selur
Selur's Avatar
assuming you named the file DUMMY.py and placed int into the autoloading folder (http://www.vapoursynth.com/doc/autoloading.html),
# Import the script
import DUMMY
# ... whatever you do otherwise in your script
# call the script
clip = DUMMY.bbmod(c=clip, cTop = 0, cBottom = 0, cLeft = 0, cRight = 0, thresh = 128, blur = 999)
if you keep the file inside another folder than the autoload folder for example e:/vsfilters you need to to use something like:
# Imports
import os
import sys
# Import scripts folder
scriptPath = 'e:/vsfilters'
sys.path.append(os.path.abspath(scriptPath))
# Import script
import DUMMY
# call the script
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 13th February 2019, 16:22   #3309  |  Link
DJATOM
DJATOM's Avatar
It should be DUMMY.py, not vpy.
Me on GitHub | My Telegram
PC Specs: Ryzen 3900X (no OC with 250W Air cooling), Asus ROG Crosshair Hero VII (WiFi) @ chipset x470, 32 GB RAM @ 3333MHz OC, Gigabyte RTX 2070, Kingston A1000 @ 240 GB
DJATOM is offline   Reply With Quote
Old 13th February 2019, 16:45   #3310  |  Link
Selur
Selur's Avatar
Yup, fixed
Old 13th February 2019, 19:51   #3311  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Cheers
No, it does not. Python scripts are used to build the filters graph and pretty much for nothing else. VapourSynth doesn't really depend on Python. Someone could make a new language for it. But it would be hard to beat Python's vast infrastructure.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 16th February 2019, 08:17   #3312  |  Link
Selur
Selur's Avatar
Is there something like Wavefront for Vapoursynth?
I'd like to do something along the (Avisynth) lines of:
LoadPlugin("I:\MkvCutter\ffms2.dll")
LoadPlugin("I:\MkvCutter\waveform.dll")
function m4(float x) {return(x<16?16:int(round(x/4.0)*4))}
V = FFVideoSource("F:\Family.mkv", cachefile="F:\Family.ffindex", threads=1).ConvertToYv12()
A = FFAudioSource("F:\Family.mkv", cache=false).ConvertToMono
V = V.BicubicResize(Ceil(V.Width*1)-(Ceil(V.Width*1)) % 4, V.Height)
AudioDub(V,A).WaveForm(window=1, height=m4(V.Height/4.0))
which is
a. taking audio and video from a source
b. converting the audio to mono
c. overlaying the audio wavefront onto the video
Did some googling, but couldn't find anything.
So does someone know how to do this with Vapoursynth or is it simply not possible atm. ?
Cu Selur
Old 16th February 2019, 21:39   #3313  |  Link
Mystery Keeper
Beyond Kawaii
which is
Cu Selur
Likely not done by anyone. Implementable by making a source filter that reads audio from media files and generates the waveform video.
...desu!
Old 17th February 2019, 13:12   #3314  |  Link
tebasuna51
tebasuna51's Avatar
@Selur, remember than VapourSynth don't support audio.
Don't exist any xxAudioSource() or AudioDub().
waveform.dll can't read audio data inside VapourSynth.
Like Mystery Keeper say a new source filter must do all the job:
a. taking audio from a source
c. supply the waveform converted to video
Old 17th February 2019, 13:18   #3315  |  Link
Selur
Selur's Avatar
Yeah, I hoped I missed something and that there already were filters to do all this.
-> Thanks for confirming, that there currently isn't a filter in Vapoursynth to do what I wanted.
Old 17th February 2019, 16:11   #3316  |  Link
asarian
Nor should it, IMHO. There's absolutely no point letting VS do audio conversions, when you can just use eac3to to convert/extract your audio outside the VS process.
Old 17th February 2019, 20:44   #3317  |  Link
lansing
There can a point when he's trimming the video in the script, there he would have to set the same trim on the audio as well so they can be in sync.
Some audio trimming programs can takes in a cut_list file and trim the audio according to the cut points in that file. It would be nice to have vapoursynth or vs editor to output these cut_list file as well according to the trimming in the script.
Old 18th February 2019, 20:14   #3318  |  Link
Selur
Selur's Avatar
@asrain:
a. for me it's not about doing a conversion, but seeing the wave front in a preview to make decisions about cutting and chapter points.
b. last I checked eac3to is Windows only and only support a few audio formats and no filtering, so at least for me it's hardly useful. (ffmpeg and sox are way more useful for me)
Old 19th February 2019, 17:04   #3319  |  Link
sl1pkn07
Pajas Mentales...
eac3to works almost good with wine
[AUR] Vapoursynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 20th February 2019, 17:49   #3320  |  Link
poisondeathray
avfs x64 issue with certain x64 avs scripts ? R45
A simple TIVTC script works ok through avisynth+ x64 , verified in avspmod x64, or vdub2 x64 . But when run though avfs x64, it produces "green screen" . avfs x86 ok
MPEG2Source()
TFM().TDecimate()
YV12 working for both avfs x86, x64 with version yv12, and blankclip yv12
version()
converttoyv12()
blankclip(pixel_type="YV12")
Why does avfs x64 TIVTC script in YV12 not work ? But simple "version" or "blankclip" in YV12 work ?
Even if I remove the x86 dgdecode.dll, tivtc.dll from the avisynth x86 plugins folder to "force" x64 pathway, still
does not work
But different source filter works in x64, TIVTC works, so this suggests the x64 dgdecode compatibility issue with avfs ?
dgdecode.dll x64 was from here
https://www.mediafire.com/download/c..._3-19-2010.rar
http://avisynth.nl/index.php/AviSynth%2B_x64_plugins
FFVideoSource()
TFM().TDecimate()
speed, vaporware, vapoursynth
