14th April 2011, 18:31 | #6862 | Link | |
http://forum.doom9.org/showthread.ph...41#post1480241 I found when I updated my drivers that the full screen exclusive mode meant everything switched to 60hz. The last working version of ati ccc drivers that didn't switch from 50hz to 60hz in exclusive mode is version 10.10. Everything after that and exclusive mode switched to 60hz, no matter how many settings in catalyst you tweaked. |
14th April 2011, 18:32 | #6863 | Link |
_
Just my quick report (only visual, I don't look at stats for now) :
- 0.49: ok - 0.50 (new path): CPU heavy (dropped frames) - 0.51: ok - 0.52: CPU heavy (dropped frames) - 0.53: ok - 0.54, tomorrow: CPU heavy. Last edited by pirlouy; 14th April 2011 at 19:56. |
14th April 2011, 19:21 | #6864 | Link | |
14th April 2011, 19:39 | #6866 | Link | |
0.53 is worse for me, even with 14 and 16 pre-rendered I have some glitches. |
14th April 2011, 19:46 | #6867 | Link | ||
I try the cpu2 build , it's fixed . But window mode is broken , same behaviour . Also FSE --> pause --> window mode ---> black screen . log : http://www.mediafire.com/download.php?ze4h382n38heula Last edited by someone`; 14th April 2011 at 20:04. |
14th April 2011, 20:15 | #6872 | Link |
MPC-HC with Cyberlink HAM for me works extremely well on both my main HTPC (5870) and my laptop (3450). W7SP1 x64 in both cases.
14th April 2011, 20:31 | #6873 | Link |
Well duh, madVR does not work with DXVA, whatever results you get, its really unpredictable - quite surprising that you get any image though. =)
14th April 2011, 20:37 | #6874 | Link |
PotPlayer's DXVA implementation is more like a decoder. They're copying the frames back into system memory after they're decoded on the GPU. As you're well aware, this could be extremely slow depending on the implementation. But, it's the wave of the future. LOL.
14th April 2011, 20:39 | #6875 | Link | |
In windowed and the old exclusive path though, I still get major frame drops, but that's fine I guess. So now only waiting for that non-debug version that doesn't create a huge txt file on my desktop! |
14th April 2011, 20:43 | #6876 | Link | |
14th April 2011, 20:46 | #6877 | Link | |
14th April 2011, 20:52 | #6878 | Link | |
AV heretic
14th April 2011, 20:55 | #6879 | Link |
I may. I'm not jazzed about using a new player, though. The ffdshow extension that was linked to earlier looks possible, though. I was going to check that out and apply the patch to my local ffdshow repository and build it. Don't know when I'll get to test it but I'm curious to see how it compares to Cyberlink HAM/LAVF CUVID with madVR.
14th April 2011, 21:07 | #6880 | Link |
Firstly, thanks for the switch to a green OSD, it's much easier to read now.
I'm getting a large number of presentation glitches in 0.53. I tried increasing the backbuffers to 16, but that only made things worse, almost 500 in a 10 minute video. http://www.mediafire.com/?725le1n1ai6985p |
