29th March 2018, 21:01 | #4023 | Link |
70 KB (MABS) go quickly ... do you know any with a large package?
OK, MPC-HC (14 MB): faster than I can confirm the target directory. Last edited by LigH; 29th March 2018 at 21:12. |
1st April 2018, 15:06 | #4027 | Link | |
dither=-1 (default) -> mode=-1 aka round to int (or truncate?) dither=0 -> mode=0 aka ordered dithering dither=1 -> mode=6 aka Floyd-Steinberg
powered by Google Translator |
1st April 2018, 15:18 | #4028 | Link | |
Magiblot,
Test DNS servers and settings for a domain name http://dnscheck.pingdom.com/?domain=avisynth.nl Quote:
EDIT: IsItDownRightNow (OK) https://www.isitdownrightnow.com/avisynth.nl.html
1st April 2018, 15:23 | #4029 | Link | |
Acid fr0g
int dither If 0, add ordered dither; if -1 (default), do not add dither Is it outdated?
@turment on Telegram |
1st April 2018, 18:47 | #4030 | Link |
Retried Guesser
Yes, it was outdated... thx, fixed now.
ColorBarsHD(pixel_type="YUV444P16") Crop(300, 440, 816, 80) ColorYUV(cont_y=0.1, cont_u=0.1, cont_v=0.1, f2c=true) Interleave( \ ConvertBits(8, dither=-1).Subtitle("dither=-1") [* no dither *] \ , ConvertBits(8, dither=0).Subtitle("dither=0") [* ordered dither *] \ , ConvertBits(8, dither=1).Subtitle("dither=1") [* Floyd-S *] \ ) ColorYUV(cont_y=10.0, cont_u=10.0, cont_v=10.0, f2c=true) return Last Last edited by raffriff42; 1st April 2018 at 19:04. Reason: images |
2nd April 2018, 01:28 | #4032 | Link | |
Eurobeat Fan
traceroute to avisynth.nl (82.150.137.175), 30 hops max, 60 byte packets 1 _gateway (192.168.1.1) 0.607 ms 5.277 ms 5.131 ms 2 168.red-81-46-38.customer.static.ccgg.telefonica.net (81.46.38.168) 5.098 ms 5.079 ms 5.031 ms 3 221.red-81-46-34.customer.static.ccgg.telefonica.net (81.46.34.221) 5.005 ms 225.red-81-46-34.customer.static.ccgg.telefonica.net (81.46.34.225) 4.997 ms 221.red-81-46-34.customer.static.ccgg.telefonica.net (81.46.34.221) 26.302 ms 4 * * * 5 50.red-80-58-81.staticip.rima-tde.net (80.58.81.50) 26.251 ms 26.179 ms 26.173 ms 6 et-4-0-0-400-grtbcnes1.net.telefonicaglobalsolutions.com (213.140.50.244) 4.795 ms 21.423 ms 3.039 ms 7 176.52.251.237 (176.52.251.237) 12.692 ms 12.694 ms 12.526 ms 8 176.52.251.213 (176.52.251.213) 12.623 ms 213.140.33.252 (213.140.33.252) 14.049 ms 213.140.33.249 (213.140.33.249) 13.141 ms 9 94.142.107.37 (94.142.107.37) 13.955 ms 11.986 ms 5.53.5.74 (5.53.5.74) 12.586 ms 10 94.142.97.138 (94.142.97.138) 11.507 ms xe-9-3-3.cr2-ams1.ip4.gtt.net (89.149.180.117) 51.350 ms 94.142.97.138 (94.142.97.138) 12.498 ms 11 atom86-gw.ip4.gtt.net (77.67.72.67) 43.810 ms 40.651 ms 94.142.107.37 (94.142.107.37) 12.848 ms 12 xe-9-3-3.cr2-ams1.ip4.gtt.net (89.149.180.117) 46.916 ms a572.datact.atom86.net (95.142.96.179) 42.362 ms 41.976 ms 13 atom86-gw.ip4.gtt.net (77.67.72.67) 40.117 ms * 39.640 ms 14 a572.datact.atom86.net (95.142.96.179) 41.511 ms * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * |
2nd April 2018, 02:00 | #4033 | Link |
Tracing route to avisynth.nl [82.150.137.175] over a maximum of 30 hops: 1 1 ms 1 ms 6 ms 192.168.100.1 2 * * * Request timed out. 3 60 ms 66 ms 76 ms 172.23.192.145 4 75 ms 40 ms 58 ms 172.30.146.163 5 48 ms 59 ms 59 ms 188.31.255.42.threembb.co.uk [188.31.255.42] 6 47 ms 56 ms 61 ms 188.31.255.85.threembb.co.uk [188.31.255.85] 7 57 ms 59 ms 59 ms 188.31.255.117.threembb.co.uk [188.31.255.117] 8 57 ms 61 ms 59 ms 188.31.255.154.threembb.co.uk [188.31.255.154] 9 66 ms 65 ms 57 ms 188.31.255.170.threembb.co.uk [188.31.255.170] 10 55 ms 61 ms 54 ms ae26-65.cr0-lon1.ip4.gtt.net [46.33.78.5] 11 59 ms 66 ms 80 ms et-2-1-0.cr2-ams1.ip4.gtt.net [141.136.105.89] 12 80 ms 79 ms 79 ms atom86-gw.ip4.gtt.net [77.67.72.67] 13 51 ms 39 ms 71 ms a572.datact.atom86.net [95.142.96.179] 14 74 ms 77 ms 79 ms mysmt175.mysmt.net [82.150.137.175] Trace complete. EDIT: Above using OpenDNS resolver. EDIT: Depending upon how your Firewall is set up, you may need to provide filewall access to multiple DNS servers (I allow about 6), and I use Nirsoft QuickDNS to switch DNS via hotkey (easy peasy):- https://www.nirsoft.net/utils/quick_set_dns.html
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd April 2018 at 03:12. |
2nd April 2018, 02:59 | #4034 | Link |
Retried Guesser
This browser stuff is way off topic, but I had a similar problem which I solved by manually adding a new DNS server. There is a selection of free DNS servers here.
16th April 2018, 03:23 | #4035 | Link |
I'm curious, what's the rationale behind fulls=false as the default for YUV when using ConvertBits()?
Edit: I ask mainly for up-converting, as e.g. white in 8 bit (255) is no longer truly white when in 10+ bit without fulls=true, it's just very close to true white (i.e. UCHAR_MAX << (BitsPerComponent() - 8)). Last edited by `Orum; 16th April 2018 at 03:36. |
16th April 2018, 05:21 | #4036 | Link | |
"Video white" or legal range white, no longer becomes legal range white if you use fulls=true. In 10bit video, legal Y should be 64 to 940 . ie. the 8bit "235" should "map" to 10bit "940" . You could argue that "legal range" video usage case is more common |
16th April 2018, 06:12 | #4037 | Link | |
Angel of Night
This isn't true for HDR, but that's an entirely different ballgame. |
16th April 2018, 06:57 | #4038 | Link | ||
Edit: Granted, none of this matters if you're only using 10-bit to reduce quant error, but it's interesting nonetheless. Last edited by `Orum; 16th April 2018 at 07:01. |
17th April 2018, 05:56 | #4039 | Link | |
Angel of Night
HDR is different because now 990,512,512 can actually mean something useful; it's often converted to a floating point value that's scaled against the display's actual white point before being converted into raw RGB to display. 900 may convert to only 600 if a display can produce blinding enough whites. That's why it has to be signaled, there's no way to infer what white point was meant out of raw pixel values other than assuming. Some HDR schemes still saturate at limited range, and simply rescale everything within it; some place the rec.709 white point at the end of the TV range and everything outside of it is special. The former is more common. Last edited by foxyshadis; 17th April 2018 at 05:59. |
