30th December 2012, 05:32 | #16401 | Link | |
Thanks for the reply! |
30th December 2012, 05:39 | #16402 | Link | |
OK, I checked the option that says "Keep HD Audio for BD25 /Alternate intact" and ripped it again, this time it seems to have worked perfectly. Funny, that option has never been checked that I know of, and I've never had problems before. Last edited by D-Train61; 30th December 2012 at 06:07. |
30th December 2012, 05:43 | #16403 | Link |
There shouldn't be a problem encoding the HD tracks. I simply don't like doing it myself, unless absolutely necessary. There are some BD's(Rare) that will benefit from the extra space. Inspect.exe is located in the bdrebuilder folder.
Only one rooster, need be in the hen house... |
1st January 2013, 05:03 | #16406 | Link |
Here are the results of my Inspect log:
- Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3326], Ok - WIN7 preferred AVC CODEC: Not Set correctly - WIN7 preferred VC-1 CODEC: Not Set correctly - WIN7 preferred MPEG2 CODEC: Not Set correctly - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.42.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok I just downloaded and installed ffdshow_rev3326_20100319_clsid.exe then reran Inspect and that is now OK. I've also read the first message in this thread and can't find a way to fix the issues with FFDShow not being configured correctly because it says I'm not running it as administrator. I've also run FF_RESET.bat but it opens a DOS command prompt window that says the path was not found and that I need to run it as administrator, but this is after right clicking FF_RESET and selecting "Run as administrator" so I don't know what I gotta do to set the environment variable so that the path can be found. Any help there would be appreciated. Anybody know how to fix my incorrect CODEC preferences? Last edited by D-Train61; 1st January 2013 at 05:34. |
1st January 2013, 06:20 | #16407 | Link |
@D-Train61
Next time you run it, when the message is waiting for you to hit any key... don't hit a key. Go to the BD-Rebuider folder and look for a file called "FF_CONFIGURE.BAT". Open it with notepad and post the contents here. It sounds like something in that BAT file has a bad path associated with it. If we look at the contents we may be able to see what it is. Where did you install BD Rebuilder (what path did you use)? |
1st January 2013, 08:10 | #16408 | Link |
2 audio tracks will not rebuild
Downloaded latest version 0.42.07 of BD Rebuilder Beta and ripped The Last Emperor. But 2 audio tracks refuse to rebuild. This is what is displayed when the movie files are loaded:
. I double-clicked the 2 entires, and the red X was replaced by the same icon that shows the other audio tracks enabled. But when I add the project to the batch cue and click 'Batch' to start the process, I can click the 'Stream' tab and see the two audio tracks were disabled again. I discovered this after I let the complete process to run, and found the director's commentary track for the main movie was not ripped. Thoughts?
[Taku Skan doesn't represent me, but is recogition of a Lakota sense of the sacred.] [My TakuSkan avatar is a detail from a Dali painting that's provoked a few philoshopic questions.] [I do Zen on a K75S] Last edited by TakuSkan; 1st January 2013 at 11:57. |
1st January 2013, 11:49 | #16410 | Link |
That seems to have fixed things. The 2 tracks are now shown enabled after changing those settings. I'll try building a new set a files. Thanks so much Adbear.
[Taku Skan doesn't represent me, but is recogition of a Lakota sense of the sacred.] [My TakuSkan avatar is a detail from a Dali painting that's provoked a few philoshopic questions.] [I do Zen on a K75S] |
1st January 2013, 13:56 | #16411 | Link |
You have to be careful with audio tracks, especially in batch jobs. There are several actions that can force BD-RB to rescan the source (like changing a setting, editing the Config file, or browsing for a file) -- causing the audio selections to revert back to the defaults. If you wish to change the audio selections (from the default) for a batch job, you should make that change immediately before adding the job to the queue.
1st January 2013, 16:50 | #16412 | Link | |
[Edit] Ok. I found the error. It has been corrected for the next release. Last edited by jdobbs; 1st January 2013 at 17:28. |
1st January 2013, 18:50 | #16413 | Link |
hello
bug in blu-ray structure, perfectly reproduce the original files with ArcSoft TotalMedia 5 and PowerDVD 12 . I tried the blu-ray structure of 100% without doing anything, and the result is that the menu is locked and do not leave the contents of the menu: ( Code:
----------------- [01/01/13] BD Rebuilder v0.42.07 (beta) [13:35:55] Source: REBELDES - Input BD size: 38,27 GB - Approximate total content: [03:29:26.970] - Target BD size: 23,82 GB - Windows Version: 6.2 [9200] - Quality: Ultra High Quality (Extremely Slow), Two Pass - Decoding/Frame serving: X264/LAVF [6-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [13:35:58] PHASE ONE, Encoding - [13:35:58] Processing: VID_00006 (6 of 53) - [13:35:58] Reencoding video [VID_00006] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 160.966 frames - Bitrate: 10.451 Kbs - [13:35:58] Reencoding: VID_00006, Pass 2 of 2 - [15:54:19] Video Encode complete - [15:54:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - Track 4355 (ita): Keeping original audio - Track 4356 (spa): Keeping original audio - Track 4357 (por): Keeping original audio - Track 4358 (rus): Keeping original audio - Track 4359 (jpn): Keeping original audio - [15:54:19] Multiplexing M2TS - [15:58:27] Processing: VID_00007 (7 of 53) - [15:58:27] Extracting A/V streams [VID_00007] - [15:58:37] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 7.002 frames - Bitrate: 12.461 Kbs - [15:58:37] Reencoding: VID_00007, Pass 1 of 2 - [15:59:46] Reencoding: VID_00007, Pass 2 of 2 - [16:06:46] Video Encode complete - [16:06:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [16:06:46] Multiplexing M2TS - [16:06:55] Processing: VID_00008 (8 of 53) - [16:06:55] Extracting A/V streams [VID_00008] - [16:06:59] Reencoding video [VID_00008] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 5.032 Kbs - [16:06:59] Reencoding: VID_00008, Pass 1 of 2 - [16:07:00] Reencoding: VID_00008, Pass 2 of 2 - [16:07:02] Video Encode complete - [16:07:02] Processing audio tracks - [16:07:02] Multiplexing M2TS - [16:07:05] Processing: VID_00009 (9 of 53) - [16:07:05] Extracting A/V streams [VID_00009] - [16:07:09] Reencoding video [VID_00009] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.551 Kbs - [16:07:09] Reencoding: VID_00009, Pass 1 of 2 - [16:07:09] Reencoding: VID_00009, Pass 2 of 2 - [16:07:11] Video Encode complete - [16:07:11] Processing audio tracks - [16:07:11] Multiplexing M2TS - [16:07:14] Processing: VID_00010 (10 of 53) - [16:07:14] Extracting A/V streams [VID_00010] - [16:07:20] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.423 frames - Bitrate: 6.512 Kbs - [16:07:20] Reencoding: VID_00010, Pass 1 of 2 - [16:07:56] Reencoding: VID_00010, Pass 2 of 2 - [16:10:17] Video Encode complete - [16:10:17] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [16:10:17] Multiplexing M2TS - [16:10:22] Processing: VID_00011 (11 of 53) - [16:10:22] Extracting A/V streams [VID_00011] - [16:10:26] Reencoding video [VID_00011] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 5.609 Kbs - [16:10:26] Reencoding: VID_00011, Pass 1 of 2 - [16:10:27] Reencoding: VID_00011, Pass 2 of 2 - [16:10:28] Video Encode complete - [16:10:28] Processing audio tracks - [16:10:28] Multiplexing M2TS - [16:10:32] Processing: VID_00012 (12 of 53) - [16:10:32] Extracting A/V streams [VID_00012] - [16:10:36] Reencoding video [VID_00012] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.115 Kbs - [16:10:36] Reencoding: VID_00012, Pass 1 of 2 - [16:10:36] Reencoding: VID_00012, Pass 2 of 2 - [16:10:37] Video Encode complete - [16:10:37] Processing audio tracks - [16:10:37] Multiplexing M2TS - [16:10:41] Processing: VID_00013 (13 of 53) - [16:10:41] Extracting A/V streams [VID_00013] - [16:10:45] Reencoding video [VID_00013] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.992 Kbs - [16:10:45] Reencoding: VID_00013, Pass 1 of 2 - [16:10:45] Reencoding: VID_00013, Pass 2 of 2 - [16:10:47] Video Encode complete - [16:10:47] Processing audio tracks - [16:10:47] Multiplexing M2TS - [16:10:50] Processing: VID_00014 (14 of 53) - [16:10:50] Extracting A/V streams [VID_00014] - [16:10:54] Reencoding video [VID_00014] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.826 Kbs - [16:10:54] Reencoding: VID_00014, Pass 1 of 2 - [16:10:54] Reencoding: VID_00014, Pass 2 of 2 - [16:10:56] Video Encode complete - [16:10:56] Processing audio tracks - [16:10:56] Multiplexing M2TS - [16:10:59] Processing: VID_00015 (15 of 53) - [16:10:59] Extracting A/V streams [VID_00015] - [16:11:03] Reencoding video [VID_00015] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.262 Kbs - [16:11:03] Reencoding: VID_00015, Pass 1 of 2 - [16:11:03] Reencoding: VID_00015, Pass 2 of 2 - [16:11:05] Video Encode complete - [16:11:05] Processing audio tracks - [16:11:05] Multiplexing M2TS - [16:11:08] Processing: VID_00016 (16 of 53) - [16:11:08] Extracting A/V streams [VID_00016] - [16:11:12] Reencoding video [VID_00016] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.888 Kbs - [16:11:12] Reencoding: VID_00016, Pass 1 of 2 - [16:11:13] Reencoding: VID_00016, Pass 2 of 2 - [16:11:14] Video Encode complete - [16:11:14] Processing audio tracks - [16:11:14] Multiplexing M2TS - [16:11:17] Processing: VID_00017 (17 of 53) - [16:11:17] Extracting A/V streams [VID_00017] - [16:11:21] Reencoding video [VID_00017] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.958 Kbs - [16:11:21] Reencoding: VID_00017, Pass 1 of 2 - [16:11:21] Reencoding: VID_00017, Pass 2 of 2 - [16:11:23] Video Encode complete - [16:11:23] Processing audio tracks - [16:11:23] Multiplexing M2TS - [16:11:26] Processing: VID_00018 (18 of 53) - [16:11:26] Extracting A/V streams [VID_00018] - [16:11:30] Reencoding video [VID_00018] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 1.839 Kbs - [16:11:30] Reencoding: VID_00018, Pass 1 of 2 - [16:11:30] Reencoding: VID_00018, Pass 2 of 2 - [16:11:31] Video Encode complete - [16:11:31] Processing audio tracks - [16:11:31] Multiplexing M2TS - [16:11:34] Processing: VID_00019 (19 of 53) - [16:11:34] Extracting A/V streams [VID_00019] - [16:11:39] Reencoding video [VID_00019] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 622 frames - Bitrate: 7.478 Kbs - [16:11:39] Reencoding: VID_00019, Pass 1 of 2 - [16:11:44] Reencoding: VID_00019, Pass 2 of 2 - [16:12:08] Video Encode complete - [16:12:08] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:12:08] Multiplexing M2TS - [16:12:11] Processing: VID_00020 (20 of 53) - [16:12:11] Extracting A/V streams [VID_00020] - [16:12:16] Reencoding video [VID_00020] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 487 frames - Bitrate: 6.342 Kbs - [16:12:16] Reencoding: VID_00020, Pass 1 of 2 - [16:12:20] Reencoding: VID_00020, Pass 2 of 2 - [16:12:36] Video Encode complete - [16:12:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:12:36] Multiplexing M2TS - [16:12:39] Processing: VID_00021 (21 of 53) - [16:12:39] Extracting A/V streams [VID_00021] - [16:12:43] Reencoding video [VID_00021] - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 1.315 frames - Bitrate: 2.680 Kbs - [16:12:43] Reencoding: VID_00021, Pass 1 of 2 - [16:12:45] Reencoding: VID_00021, Pass 2 of 2 - [16:12:56] Video Encode complete - [16:12:56] Processing audio tracks - Track 4352 (spa): Keeping original audio - [16:12:56] Multiplexing M2TS - [16:13:00] Processing: VID_00022 (22 of 53) - [16:13:00] Extracting A/V streams [VID_00022] - [16:13:06] Reencoding video [VID_00022] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.600 frames - Bitrate: 10.422 Kbs - [16:13:06] Reencoding: VID_00022, Pass 1 of 2 - [16:13:43] Reencoding: VID_00022, Pass 2 of 2 - [16:16:34] Video Encode complete - [16:16:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:16:34] Multiplexing M2TS - [16:16:39] Processing: VID_00023 (23 of 53) - [16:16:39] Extracting A/V streams [VID_00023] - [16:16:43] Reencoding video [VID_00023] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.826 Kbs - [16:16:43] Reencoding: VID_00023, Pass 1 of 2 - [16:16:44] Reencoding: VID_00023, Pass 2 of 2 - [16:16:45] Video Encode complete - [16:16:45] Processing audio tracks - [16:16:45] Multiplexing M2TS - [16:16:48] Processing: VID_00024 (24 of 53) - [16:16:48] Extracting A/V streams [VID_00024] - [16:16:52] Reencoding video [VID_00024] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.962 Kbs - [16:16:52] Reencoding: VID_00024, Pass 1 of 2 - [16:16:52] Reencoding: VID_00024, Pass 2 of 2 - [16:16:54] Video Encode complete - [16:16:54] Processing audio tracks - [16:16:54] Multiplexing M2TS - [16:16:57] Processing: VID_00025 (25 of 53) - [16:16:57] Extracting A/V streams [VID_00025] - [16:17:01] Reencoding video [VID_00025] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.826 Kbs - [16:17:01] Reencoding: VID_00025, Pass 1 of 2 - [16:17:01] Reencoding: VID_00025, Pass 2 of 2 - [16:17:02] Video Encode complete - [16:17:02] Processing audio tracks - [16:17:02] Multiplexing M2TS - [16:17:06] Processing: VID_00026 (26 of 53) - [16:17:06] Extracting A/V streams [VID_00026] - [16:17:09] Reencoding video [VID_00026] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.747 Kbs - [16:17:09] Reencoding: VID_00026, Pass 1 of 2 - [16:17:10] Reencoding: VID_00026, Pass 2 of 2 - [16:17:11] Video Encode complete - [16:17:11] Processing audio tracks - [16:17:11] Multiplexing M2TS - [16:17:15] Processing: VID_00027 (27 of 53) - [16:17:15] Extracting A/V streams [VID_00027] - [16:17:18] Reencoding video [VID_00027] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.481 Kbs - [16:17:18] Reencoding: VID_00027, Pass 1 of 2 - [16:17:19] Reencoding: VID_00027, Pass 2 of 2 - [16:17:20] Video Encode complete - [16:17:20] Processing audio tracks - [16:17:20] Multiplexing M2TS - [16:17:23] Processing: VID_00028 (28 of 53) - [16:17:23] Extracting A/V streams [VID_00028] - [16:17:27] Reencoding video [VID_00028] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.803 Kbs - [16:17:27] Reencoding: VID_00028, Pass 1 of 2 - [16:17:28] Reencoding: VID_00028, Pass 2 of 2 - [16:17:29] Video Encode complete - [16:17:29] Processing audio tracks - [16:17:29] Multiplexing M2TS - [16:17:32] Processing: VID_00029 (29 of 53) - [16:17:32] Extracting A/V streams [VID_00029] - [16:17:36] Reencoding video [VID_00029] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.673 Kbs - [16:17:36] Reencoding: VID_00029, Pass 1 of 2 - [16:17:37] Reencoding: VID_00029, Pass 2 of 2 - [16:17:38] Video Encode complete - [16:17:38] Processing audio tracks - [16:17:38] Multiplexing M2TS Last edited by jdobbs; 1st January 2013 at 20:33. |
1st January 2013, 18:50 | #16414 | Link |
- [16:17:41] Processing: VID_00030 (30 of 53) - [16:17:41] Extracting A/V streams [VID_00030] - [16:17:45] Reencoding video [VID_00030] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.283 Kbs - [16:17:45] Reencoding: VID_00030, Pass 1 of 2 - [16:17:45] Reencoding: VID_00030, Pass 2 of 2 - [16:17:47] Video Encode complete - [16:17:47] Processing audio tracks - [16:17:47] Multiplexing M2TS - [16:17:50] Processing: VID_00031 (31 of 53) - [16:17:50] Extracting A/V streams [VID_00031] - [16:17:53] Reencoding video [VID_00031] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.069 Kbs - [16:17:54] Reencoding: VID_00031, Pass 1 of 2 - [16:17:54] Reencoding: VID_00031, Pass 2 of 2 - [16:17:55] Video Encode complete - [16:17:55] Processing audio tracks - [16:17:55] Multiplexing M2TS - [16:17:59] Processing: VID_00032 (32 of 53) - [16:17:59] Extracting A/V streams [VID_00032] - [16:18:03] Reencoding video [VID_00032] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 10 frames - Bitrate: 500 Kbs - [16:18:03] Reencoding: VID_00032, Pass 1 of 2 - [16:18:03] Reencoding: VID_00032, Pass 2 of 2 - [16:18:03] Video Encode complete - [16:18:03] Processing audio tracks - [16:18:03] Multiplexing M2TS - [16:18:07] Processing: VID_00033 (33 of 53) - [16:18:07] Extracting A/V streams [VID_00033] - [16:18:10] Reencoding video [VID_00033] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 2.943 Kbs - [16:18:10] Reencoding: VID_00033, Pass 1 of 2 - [16:18:11] Reencoding: VID_00033, Pass 2 of 2 - [16:18:12] Video Encode complete - [16:18:12] Processing audio tracks - [16:18:12] Multiplexing M2TS - [16:18:15] Processing: VID_00034 (34 of 53) - [16:18:15] Extracting A/V streams [VID_00034] - [16:18:19] Reencoding video [VID_00034] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.577 Kbs - [16:18:19] Reencoding: VID_00034, Pass 1 of 2 - [16:18:19] Reencoding: VID_00034, Pass 2 of 2 - [16:18:20] Video Encode complete - [16:18:20] Processing audio tracks - [16:18:20] Multiplexing M2TS - [16:18:24] Processing: VID_00035 (35 of 53) - [16:18:24] Extracting A/V streams [VID_00035] - [16:18:28] Reencoding video [VID_00035] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 12 frames - Bitrate: 500 Kbs - [16:18:28] Reencoding: VID_00035, Pass 1 of 2 - [16:18:28] Reencoding: VID_00035, Pass 2 of 2 - [16:18:28] Video Encode complete - [16:18:28] Processing audio tracks - [16:18:28] Multiplexing M2TS - [16:18:32] Processing: VID_00036 (36 of 53) - [16:18:32] Extracting A/V streams [VID_00036] - [16:18:35] Reencoding video [VID_00036] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 12 frames - Bitrate: 500 Kbs - [16:18:35] Reencoding: VID_00036, Pass 1 of 2 - [16:18:35] Reencoding: VID_00036, Pass 2 of 2 - [16:18:36] Video Encode complete - [16:18:36] Processing audio tracks - [16:18:36] Multiplexing M2TS - [16:18:39] Processing: VID_00038 (37 of 53) - [16:18:39] Extracting A/V streams [VID_00038] - [16:19:01] Reencoding video [VID_00038] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 47.490 frames - Bitrate: 8.297 Kbs - [16:19:01] Reencoding: VID_00038, Pass 1 of 2 - [16:20:44] Reencoding: VID_00038, Pass 2 of 2 - [16:37:23] Video Encode complete - [16:37:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:37:23] Multiplexing M2TS - [16:37:40] Processing: VID_00039 (38 of 53) - [16:37:40] Extracting A/V streams [VID_00039] - [16:37:45] Reencoding video [VID_00039] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 1.000 frames - Bitrate: 8.350 Kbs - [16:37:45] Reencoding: VID_00039, Pass 1 of 2 - [16:37:47] Reencoding: VID_00039, Pass 2 of 2 - [16:38:10] Video Encode complete - [16:38:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:38:10] Multiplexing M2TS - [16:38:14] Processing: VID_00041 (39 of 53) - [16:38:14] Extracting A/V streams [VID_00041] - [16:38:18] Reencoding video [VID_00041] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 2.040 frames - Bitrate: 8.369 Kbs - [16:38:19] Reencoding: VID_00041, Pass 1 of 2 - [16:38:23] Reencoding: VID_00041, Pass 2 of 2 - [16:39:00] Video Encode complete - [16:39:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:39:00] Multiplexing M2TS - [16:39:04] Processing: VID_00042 (40 of 53) - [16:39:04] Extracting A/V streams [VID_00042] - [16:39:11] Reencoding video [VID_00042] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 8.490 frames - Bitrate: 8.289 Kbs - [16:39:11] Reencoding: VID_00042, Pass 1 of 2 - [16:39:31] Reencoding: VID_00042, Pass 2 of 2 - [16:42:41] Video Encode complete - [16:42:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:42:41] Multiplexing M2TS - [16:42:47] Processing: VID_00043 (41 of 53) - [16:42:47] Extracting A/V streams [VID_00043] - [16:42:52] Reencoding video [VID_00043] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 2.968 frames - Bitrate: 8.310 Kbs - [16:42:52] Reencoding: VID_00043, Pass 1 of 2 - [16:42:58] Reencoding: VID_00043, Pass 2 of 2 - [16:44:02] Video Encode complete - [16:44:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:44:02] Multiplexing M2TS - [16:44:06] Processing: VID_00044 (42 of 53) - [16:44:06] Extracting A/V streams [VID_00044] - [16:44:12] Reencoding video [VID_00044] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 2.950 frames - Bitrate: 8.360 Kbs - [16:44:12] Reencoding: VID_00044, Pass 1 of 2 - [16:44:19] Reencoding: VID_00044, Pass 2 of 2 - [16:45:07] Video Encode complete - [16:45:07] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:45:07] Multiplexing M2TS - [16:45:11] Processing: VID_00045 (43 of 53) - [16:45:11] Extracting A/V streams [VID_00045] - [16:45:20] Reencoding video [VID_00045] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 13.560 frames - Bitrate: 8.274 Kbs - [16:45:20] Reencoding: VID_00045, Pass 1 of 2 - [16:45:49] Reencoding: VID_00045, Pass 2 of 2 - [16:50:01] Video Encode complete - [16:50:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:50:02] Multiplexing M2TS - [16:50:08] Processing: VID_00046 (44 of 53) - [16:50:08] Extracting A/V streams [VID_00046] - [16:50:16] Reencoding video [VID_00046] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 7.221 frames - Bitrate: 8.361 Kbs - [16:50:16] Reencoding: VID_00046, Pass 1 of 2 - [16:50:32] Reencoding: VID_00046, Pass 2 of 2 - [16:52:48] Video Encode complete - [16:52:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:52:48] Multiplexing M2TS - [16:52:53] Processing: VID_00047 (45 of 53) - [16:52:53] Extracting A/V streams [VID_00047] - [16:52:58] Reencoding video [VID_00047] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 3.601 frames - Bitrate: 8.336 Kbs - [16:52:58] Reencoding: VID_00047, Pass 1 of 2 - [16:53:06] Reencoding: VID_00047, Pass 2 of 2 - [16:54:23] Video Encode complete - [16:54:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:54:23] Multiplexing M2TS - [16:54:27] Processing: VID_00048 (46 of 53) - [16:54:28] Extracting A/V streams [VID_00048] - [16:54:33] Reencoding video [VID_00048] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 4.949 frames - Bitrate: 8.382 Kbs - [16:54:33] Reencoding: VID_00048, Pass 1 of 2 - [16:54:45] Reencoding: VID_00048, Pass 2 of 2 - [16:56:28] Video Encode complete - [16:56:28] Processing audio tracks - Track 4352 (eng): Keeping original audio - [16:56:28] Multiplexing M2TS - [16:56:32] Processing: VID_00049 (47 of 53) - [16:56:32] Extracting A/V streams [VID_00049] - [16:56:50] Reencoding video [VID_00049] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 25.080 frames - Bitrate: 8.296 Kbs - [16:56:50] Reencoding: VID_00049, Pass 1 of 2 - [16:57:46] Reencoding: VID_00049, Pass 2 of 2 - [17:07:23] Video Encode complete - [17:07:23] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:07:23] Multiplexing M2TS - [17:07:33] Processing: VID_00050 (48 of 53) - [17:07:33] Extracting A/V streams [VID_00050] - [17:07:42] Reencoding video [VID_00050] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 13.260 frames - Bitrate: 8.285 Kbs - [17:07:42] Reencoding: VID_00050, Pass 1 of 2 - [17:08:11] Reencoding: VID_00050, Pass 2 of 2 - [17:12:38] Video Encode complete - [17:12:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:12:38] Multiplexing M2TS - [17:12:45] Processing: VID_00051 (49 of 53) - [17:12:45] Extracting A/V streams [VID_00051] - [17:12:49] Reencoding video [VID_00051] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29,970fps, 12 frames - Bitrate: 500 Kbs - [17:12:49] Reencoding: VID_00051, Pass 1 of 2 - [17:12:49] Reencoding: VID_00051, Pass 2 of 2 - [17:12:49] Video Encode complete - [17:12:49] Processing audio tracks - [17:12:49] Multiplexing M2TS - [17:12:53] Processing: VID_00052 (50 of 53) - [17:12:53] Extracting A/V streams [VID_00052] - [17:12:56] Reencoding video [VID_00052] - [17:12:56] Keeping original video (no reencode) - [17:12:56] Processing audio tracks - [17:12:56] Multiplexing M2TS - [17:13:00] Processing: VID_00066 (51 of 53) - [17:13:00] Extracting A/V streams [VID_00066] - [17:13:03] Reencoding video [VID_00066] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 3.628 Kbs - [17:13:03] Reencoding: VID_00066, Pass 1 of 2 - [17:13:04] Reencoding: VID_00066, Pass 2 of 2 - [17:13:05] Video Encode complete - [17:13:05] Processing audio tracks - [17:13:05] Multiplexing M2TS - [17:13:09] Processing: VID_00069 (52 of 53) - [17:13:09] Extracting A/V streams [VID_00069] - [17:13:13] Reencoding video [VID_00069] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - Bitrate: 3.846 Kbs - [17:13:13] Reencoding: VID_00069, Pass 1 of 2 - [17:13:21] Reencoding: VID_00069, Pass 2 of 2 - [17:13:32] Video Encode complete - [17:13:32] Processing audio tracks - [17:13:32] Multiplexing M2TS - [17:13:36] Processing: VID_00071 (53 of 53) - [17:13:36] Extracting A/V streams [VID_00071] - [17:13:39] Reencoding video [VID_00071] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - Bitrate: 4.551 Kbs - [17:13:39] Reencoding: VID_00071, Pass 1 of 2 - [17:13:40] Reencoding: VID_00071, Pass 2 of 2 - [17:13:41] Video Encode complete - [17:13:41] Processing audio tracks - [17:13:41] Multiplexing M2TS [17:13:45]PHASE ONE complete [17:13:45]PHASE TWO - Rebuild Started - [17:13:45] Rebuilding BD file Structure [17:13:47] - Encode and Rebuild complete [17:13:47] JOB: REBELDES finished. [Options] VERSION=0.42.0.7 MODE=0 DTSX_ENABLE=1 B_PYRAMID=1 EXTENDED_GOP=1 AUTO_BIAS=4 MIN_M2TS_SIZE=1 MIN_PLAYLIST_MINS=1 BLANK_THRESHOLD=1 ENABLE_TEST=1 ENCODE_QUALITY=4 ONEPASS_ENCODING=0 MULTIPROCESS=6 AUTO_QUALITY=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=1 DEINTERLACER_TYPE=3 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24390 ENABLE_BLANKING=1 TARGET_SIZE=24390 [Paths] SOURCE_PATH=I:\REBELDES\ WORKING_PATH=D:\REBUILDERASAX\ Last edited by jdobbs; 1st January 2013 at 20:33. |
1st January 2013, 19:46 | #16415 | Link | |
Here is the contents of my FF_CONFIGURE.BAT file: @"C:\Users\Ìnspiron\BD-RB\BD_Rebuilder\tools\setacl_x64.exe" -ot reg -on "HKLM\SOFTWARE\Microsoft\DirectShow\Preferred" -actn setowner -ownr "n:S-1-5-32-544;s:y" -rec yes > nul @if ERRORLEVEL 1 GOTO ERREXIT @"C:\Users\Ìnspiron\BD-RB\BD_Rebuilder\tools\setacl_x64.exe" -ot reg -on "HKLM\SOFTWARE\Microsoft\DirectShow\Preferred" -actn ace -ace "n:S-1-5-32-544;p:full;s:y" -rec yes > nul @REM Change preferred AVC @reg add HKLM\SOFTWARE\Microsoft\DirectShow\Preferred /v {31435641-0000-0010-8000-00AA00389B71} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f > nul @REM Change preferred VC-1 @reg add HKLM\SOFTWARE\Microsoft\DirectShow\Preferred /v {31435657-0000-0010-8000-00AA00389B71} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f > nul @REM Change preferred MPEG-2 @reg add HKLM\SOFTWARE\Microsoft\DirectShow\Preferred /v {e06d8026-db46-11cf-b4d1-00805f6cbbea} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f > nul @REM Change FFDSHOW VC-1 default to WMV9 @"C:\Users\Ìnspiron\BD-RB\BD_Rebuilder\tools\setacl_x64.exe" -ot reg -on "HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred" -actn setowner -ownr "n:S-1-5-32-544;s:y" -rec yes > nul @if ERRORLEVEL 1 GOTO ERREXIT @"C:\Users\Ìnspiron\BD-RB\BD_Rebuilder\tools\setacl_x64.exe" -ot reg -on "HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred" -actn ace -ace "n:S-1-5-32-544;p:full;s:y" -rec yes > nul @REM Change preferred AVC @reg add HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred /v {31435641-0000-0010-8000-00AA00389B71} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f > nul @REM Change preferred VC-1 @reg add HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred /v {31435657-0000-0010-8000-00AA00389B71} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f > nul @REM Change preferred MPEG-2 @reg add HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred /v {e06d8026-db46-11cf-b4d1-00805f6cbbea} /t REG_SZ /d {04FE9017-F873-410E-871E-AB91661A4EF7} /f > nul @REM Change FFDSHOW VC-1 default to WMV9 @reg add HKCU\Software\GNU\ffdshow /v wvc1 /t REG_DWORD /d 12 /f >nul @reg add HKCU\Software\GNU\ffdshow /v mpg2 /t REG_DWORD /d 1 /f >nul @reg add HKCU\Software\GNU\ffdshow /v h264 /t REG_DWORD /d 1 /f >nul @reg add HKCU\Software\GNU\ffdshow /v rawv /t REG_DWORD /d 1 /f >nul @echo --- @echo SUCCESSFULLY RECONFIGURED @echo --- @EXIT :ERREXIT @echo --- @echo UNSUCCESSFUL -- MUST RUN AS ADMINISTRATOR @echo --- @PAUSE And I installed BD_Rebuilder right in the root of my home folder C:\Users\Inspiron\BD-RB\BD-Rebuilder Note that the first letter of the name Inspiron has a funny initial letter Ì with a strange accent mark above it. Could this be a contributing factor? (I have no idea why this is named this way) Thanks again for your help. |
1st January 2013, 20:40 | #16417 | Link |
BD Rebuilder v0.42.08 (beta)
I have updated the first post of this thread with links to a new version of BD-RB (v0.42.08). Changes for this release:
- Changed the maximum value of the MULTIPROCESS function from 16 to 32 for extremely high-end multi-core processors. - Modified LAVF encodes to explicitly indicate the target framerate for X264. - Corrected an error in which DVD_IMPORT_THRESHOLD (see HIDDENOPTS.TXT) was calculated at twice its intended value, and the default threshold was 30 minutes rather than the intended 15. - Corrected an error in the IMPORT function where importing a source that has a width of less than 720 pixels could cause a resize to 1280x720 and an output stream that is not compliant. - Made modifications so that non-compliant original sources that use 480p or 576p are corrected into compliancy during encoding (by using the X264 --fake-interlaced switch). - Added code to remove overscan when outputting to non-DVD ALTERNATE output formats. - Other minor corrections and cosmetic fixes. |
1st January 2013, 20:40 | #16418 | Link |
It seems like somebody in this thread had a similar issue once upon a time. I generally just leave it in my downloads folder. That way when I update, everything is just right there
1st January 2013, 20:51 | #16419 | Link | |
thanks
