13th October 2003, 18:19 | #181 | Link | |||
MKVToolNix author
However, I could include the option to split after 'n' frames, or after given set of frame numbers and try to find the closest key frame - much like I'm handling splitting at the moment. That wouldn't be frame accurate, but you could give the number of frames. Quote:
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
13th October 2003, 19:27 | #182 | Link | |
A/V moderator @ hydrogenaudio.org My weird old sh*t: http://www.nic.fi/~lhahne/ http://last.fm/user/Latexxx/ |
13th October 2003, 20:10 | #183 | Link | |
MKVToolNix author
13th October 2003, 20:35 | #184 | Link |
(schein)heilig
frame accurate splitting: should have been more precise, sorry. Of course by »frame accurate« I mean »key frame accurate«. The option I'm looking for is something like: »split the file at frames no 10000, 20000 and 30000 or closest keyframe«.
The manifest file: Latexxx basically said what it does. Without manifest mmg has the traditional look with rectangular buttons etc. even if the new WinXP look is activated. I don't want to argue about crappy or not or slow or not. But as mmg does not have any problems with the XP styles why not include a manifest file and leave the choice to every individual user: WinXP look globally enabled --> mmg looks XP-ish, WinXP look disabled --> mmg looks traditional. Btw: I like the skinning ability (though not the default style) and it doesn't feel slower than Win2k.
Brother John When lost in BeSweet's options, have a look at the Commandline Reference. DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen! |
13th October 2003, 20:38 | #185 | Link | |
Señor Member
13th October 2003, 23:12 | #186 | Link | ||
MKVToolNix author
14th October 2003, 15:34 | #187 | Link |
MKVToolNix author
mkvtoolnix 0.7.2 released
Heya,
I've just released version 0.7.2 of mkvtoolnix. It is mainly a bug fix release but has some internal changes that may or may not work for you Anyway, due to the bugs that I've fixed I strongly recommend that you upgrade to 0.7.2. The URLs: http://www.bunkus.org/videotools/mkvtoolnix/ http://www.bunkus.org/videotools/mkv...lnix-0.7.2.rar The ChangeLog since 0.7.1: -------------------------- 2003-10-14 Moritz Bunkus <moritz@bunkus.org> * Released v0.7.2. * mkvmerge: bug fix: If 'no linking' and splitting was active mkvmerge would abort on the start of the second output file due to timecodes that were calculated incorrectly. * mkvmerge: Implemented some speedups for a couple of container formats and track types (mainly AVI reader, MP3/AC3/AAC packetizers). Especially noticeable when splitting is active as well. 2003-10-12 Moritz Bunkus <moritz@bunkus.org> * mkvextract: bug fix: Support for extracting SBR AAC (previous 'fix' did not actually fix this). * mkvextract: bug fix: All extracted subtitles where written to the first output file given, not to the one they were supposed to be written to. 2003-10-11 Moritz Bunkus <moritz@bunkus.org> * mmg: bug fix: The 'abort' button was doing nothing under Windows. 2003-10-06 Moritz Bunkus <moritz@bunkus.org> * mmg: bug fix: Audio, video and subtitle track selection was translated into the wrong command line options. * mkvmerge: Replaced the avilib based AVI reading functions with AVI classes from Cyrius. ----------------------------- Have fun
14th October 2003, 15:36 | #188 | Link | |
MKVToolNix author
Re: Problem Muxing AC3
14th October 2003, 15:42 | #189 | Link |
Anime Otaku
As I 'm downloading your new version of mkvtoolnix Mosu, I want to bring to your attention a bug that is still present in mkvtoolnix-0.7.2-pre1 and since there is no mention of it in the changelog I assume it is present in 0.7.2 also. The .SRT subtitle parser is still stalling when an empty line is encountered in the SRT text file. This bug was supposed to be fixed in 0.7.1 but I 'm still experiencing the bug. Can you look at it? Thanks.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
14th October 2003, 16:02 | #191 | Link | |
MKVToolNix author
Re: sub ?
14th October 2003, 16:03 | #192 | Link | |
MKVToolNix author
20th October 2003, 21:00 | #193 | Link | |
Re: Re: Problem Muxing AC3
KpeX Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC Linux Audio/Video FAQ |
20th October 2003, 23:39 | #194 | Link |
李姗倩 Lǐ Shān Qiàn
The doc says "AAC audio files (only those with ADTS headers before each packet)" works, but it seems mkvmerge can already handle AAC without ADTS headers too (I happened to find it when I was trying to mux a .m4a file created by the AAC encoder come with Apple iTunes.)
1. Is such a .m4a "officially" supported by mkvmerge? 2. If so, I'd like to see "*.aac *.mp4 *.m4a" as the filemask for AAC in mmg And here's a very small request for better usability: 3. Would like to have File > New in mmg, which would just clear all the forms (needed when you want to make more than one Matroska files in succession) |
21st October 2003, 09:22 | #195 | Link | |||
MKVToolNix author
21st October 2003, 12:05 | #196 | Link |
李姗倩 Lǐ Shān Qiàn
m4a
a small sample by iTunes, itunes.m4a, has just been sent to you.
I could even use this trick. to convert m4a to "normal" aac: mkvmerge -o tmp.mka in.m4a mkvextract tracks tmp.mka 1:_out.aac _out.aac has a lot of headers like "FF F1 50 xx xx xx FC" periodically, while in.m4a doesn't have such things (I think) |
21st October 2003, 12:13 | #197 | Link | |
MKVToolNix author
Re: m4a
21st October 2003, 12:26 | #198 | Link | |
Matroska Team
21st October 2003, 12:32 | #199 | Link | |
MKVToolNix author
In short: It's probably a .mp4 and I'll add .m4a to the GUI's file selection dialog.
