Old 10th August 2009, 13:34   #141  |  Link
Originally Posted by hxhxd View Post
Have problem in demgpindexnv:
When I open the four vts_01 - 04 files. dgmpgindex says (look at the snapshot)
What version of Nvidia drivers do you have installed?
Old 10th August 2009, 13:53   #142  |  Link
buzzqw
HDConvertToX author
thanks you, Neuron2
the HDC package doesn't include NVTools.
i add link/info on first post of hdc thread
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 10th August 2009, 14:45   #143  |  Link
canTsTop
canTsTop's Avatar
Is this tool can handle videos with errors? Audio/video synchronization will be good? Video samples (333_0_0.ts, with_errors_2.ts, with_errors_LTV.ts) are here.
Thank You.
canTsTop is offline   Reply With Quote
Old 10th August 2009, 14:46   #144  |  Link
There is no special handling for corrupted streams.
Old 11th August 2009, 06:12   #145  |  Link
woah!
i am having an issue with beta6 and 7 server. beta5 opens and plays any indexed file from beta7 indexer, but using server beta6 or 7 crashes viewer as soon as i open the avs script to preview it. i cant give a clip as it happens with every thing i process, and as i said works correctly with beta5 and below?
using 190.38 drivers on 32bit xp sp3.. is there anything i can upload to help solve this?
woah! is offline   Reply With Quote
Old 11th August 2009, 13:37   #146  |  Link
What is the "viewer" and what is the script?
Old 11th August 2009, 14:15   #147  |  Link
Another thought: re-download beta 7 as it changed a few times. Make sure you update all the components.
Old 12th August 2009, 02:08   #148  |  Link
woah!
ok found out what it was, i didnt update DGDecodeNV.dll in my AviSynth 2.5\plugins folder ... damn i should know better...
Old 12th August 2009, 03:22   #149  |  Link
hxhxd
I don't remember the exact version. Only I can get is a snapshot of the card properties page.
Edit: I've installed the lastest version from nvidia site. And the problem has gone.
hxhxd is offline   Reply With Quote
Old 14th August 2009, 23:35   #150  |  Link
prokhozhijj
I do my post here JIC:
I've got error when opening VOB files in NVBeta7 DGMPGIndexNV.exe
GPU decoder: Failed to create video decoder [100].
After this error happens I can not to close application legally. But when I close project firstly (File -> Close) than I can to close application.
When I try to preview or play video in DGMPGIndexNV.exe apllication I am getting following: No video frames found!
This issue happens with all VOB files.
Neuron2 can not help me with this issue. May be somebody else?
CPU: Core 2 Quad q9505 RAM: 4G OS: Windows 7 64 Video: Nvidia Geforce 460 GTX VP4 AviSynth: 2.5.8
prokhozhijj is offline   Reply With Quote
Old 15th August 2009, 02:34   #151  |  Link
How much memory does your video card have? Some of the 8800GTS cards have VP1 only.
http://en.wikipedia.org/wiki/PureVid..._.28HD.29_GPUs
Old 15th August 2009, 05:00   #152  |  Link
woah!
since the new betas came out, i see you are leaving the source as is. 1920x1088 ---> 1920x1080 was done by your program automatically before. why do most file viewers like mediainfo show the source files as 1920x1080 but yours show 1088?
should i crop 8 off before processing it then or leave it as is, mostly use bluray source files which are film 24/23.976fps ..
DGAVCIndexNV 1.0.14 beta 5 on left pic and beta 6 on right:
Old 15th August 2009, 06:11   #153  |  Link
Audionut
As I said, dgindex always reports the coded frame size, not including the stream's specified (cropped) display area.
http://forum.doom9.org/showthread.ph...60#post1312860
http://www.7-zip.org/
Old 15th August 2009, 09:39   #154  |  Link
prokhozhijj
It seems that I have videocard with 640 Mb memory. Is it a reason why it does not work with your soft? If so, sorry for disturbing you.
But could you add to your soft some tests about version of Pure Video HD engine used by videocard? I think that it can save the time for other users such me (and your time too).
Old 15th August 2009, 09:59   #155  |  Link
ultratoto14
With 640Mb, you have the first version of the 8800 GTS, this version does not have the required component to use DGNV tools.
ultratoto14 is offline   Reply With Quote
Old 15th August 2009, 12:50   #156  |  Link
Yes, you can just use "Video/Cropping Filter" to crop it.
I have seen some streams that have good content in that last 8 pixels and thought it would be useful to have the option to retain it when resizing. I'm open to reconsidering that decision if it bothers people too much.
Old 15th August 2009, 12:53   #157  |  Link
That card won't work. But didn't you say that it worked with beta 4??? That's why I didn't immediately explore this possibility.
Old 15th August 2009, 16:19   #158  |  Link
prokhozhijj
Yes, your soft (beta 4) worked with my videocard. So I am surprised too. Again, sorry for disturbing you. I did not noticed this restriction.
Old 15th August 2009, 17:28   #159  |  Link
I don't believe it. And if by some miracle it happens to be true, then we should investigate it further.
Old 15th August 2009, 17:33   #160  |  Link
Audionut
A good start would be to download this and provide a screen shot of the main screen.
http://www.techpowerup.com/downloads...-Z_v0.3.4.html
