20th January 2009, 03:34 | #681 | Link | |
Jddobs: What should I try to help debug this issue with this player? |
20th January 2009, 03:50 | #682 | Link |
We found that removing the AUXDATA folder (inside the BDMV folder), before burning the disc with ImgBurn made "Movie Only" copies work with some other players, and they retained playability in the PS3. You don't have to reencode anything...just delete that one folder and burn.
This probably won't work if you have several smaller branching .m2ts files which make up the movie. The only luck I had with those movies was to pre-process them to combine them into a single file. I hope this helps... Last edited by GaPony; 20th January 2009 at 03:53. |
20th January 2009, 04:56 | #683 | Link | |
@Cabal2000:
20th January 2009, 07:26 | #684 | Link |
Video Maniac
Greetings Once More jdobbs
I Realise This Isn't A Bug But I Thought You Wouldn't Mind My Calling On Your Expertise... I Successfully Remuxed A DTS Audio Track (Converted From PCM) Back Into A Blu-Ray Movie With It Working And Chapter Select Still Works But Seems To Be Of By One... Chapter 2 = 1 And Chapter 15=14 Etc... Any Idea How I Can Correct That? Any Help Is Much Appreciated And Again.
20th January 2009, 10:58 | #685 | Link |
There seems to be an issue with 'My Best Friend's Girl'... It is a seamless branched BD and has been the only one that BD-RB hasn't been able to encode correctly for me.
I joined all the m2ts files together with TSSplitter, then remuxed with TSMuxer (also tried it with TSRemux) into Bluray format while stripping unwanted audio and PGS streams. And the output from either of those apps has played and looked flawless on my harddrive. BD-RB however seems unable to encode itcorrectly. There are multiple scenes where a blurry blotch appears for split seconds thru-out the BD-RB output (both from the HDD or from the BD-9). Also this title has been the only one that plays the subtitles in wrong sequence. I've redone this movie several times and each time it has these problems 'after' encoding thru BD-RB... and at the same exact spots every time. So for whatever reason, this title is giving BD-RB fits. Can't do it from the full Bluray rip because it has 25 2ts files making up the movie, thus gives me the multiple instances of FFDShow and Matroska, which leads to out of memory error. Anyone else did this Bluray? It's the only title that I haven't been successful on yet with BD-RB.
MBK |
20th January 2009, 13:17 | #686 | Link |
Version 0.18.02
I've posted a new version of BD Rebuilder in the first post of this thread. I think it corrects most of the issues reported in this thread. But... I made a LOT of changes, so there is a high likelihood that we may find something new. Please remember to post them only in this thread. Thanks. Important note: This version requires AVISYNTH 2.57 or above. It will warn you and close itself it you don't have it installed. Here are the changes made in this version: Code:
January 20th, 2008 - v0.18.2 - PLEASE NOTE: Starting with this version, BD Rebuilder REQUIRES AVISYNTH v2.57 or above. If you do not have it installed, please download it from: http://www.jdobbs.net/freeware/Avisynth_257.exe and install it. BD-RB will not work with older versions of AVISYNTH. - Improved command line settings used for QUICK encodes. - Corrected error in QUICK encoding routine that could result in oversizing (particularly on series and extra discs). - Corrected an error that could cause "Runtime Error 6" when encoding audio. - Added code to catch errors during audio reencoding. - Added a checkbox in SETUP to make AC3 reencodes default to 640Kbs rather than 448Kbs. - Updated quality selection. There are now four levels based on recommendations from Dark Shikari. Now uses "ENCODE_QUALITY=" parameter in INI file. - Added a warning/restriction when source path lengths are too long (previously caused oversizing). - Corrected an error that would cause "Runtime Error 9" on certain discs with multiple story paths (angles). - Completely rewrote the movie-only handling routines to correct issues with certain multi-path/angle sources that had huge numbers of components and could cause BD-RB to crash with out-of-memory errors. - Added code to correct the "snap" sound in WAV files resulting from demuxing via TSMUXER. - Added chapter calculation to movie-only mode. Now the chapters will match those in the original playlist. - Added the ability to select from alternate playlists. This is especially useful for series discs and discs with more than one version of a film. Note: You can select only from playlists of least 15 mins. - Added traps to catch muxing errors that could result in "Runtime Error 76 - path not found". - Corrected "Runtime Error 424". - Fixed an error related to audio (especially LPCM) that could cause errors in "ReencodeAudio()" routine. - Fixed several issues in related to reecoding/keeping audio streams that could result in the wrong type code being set in the MPLS file. This could result in silent playback. - Made calculation changes to help prevent oversizing under certain conditions when audio is kept intact. - Added a SETUP option that makes what appears to be a more strictly compliant output (AVCHD) for the movie- only option. - Other minor corrections and cosmetic fixes. |
20th January 2009, 19:49 | #687 | Link | |
Hi!
I am doing a Full backup with the new version 0.18.02 of Starship Troopers, german release. My main movie (the video) is only approx 1m43s long. I checked the AVS file created, and in it lies the problem: Quote:
Since the AVS scripts are overwritten when starting again, I also cannot change it myself. When I remove the framecount parameter, the AVS plays with full length. Bye |
20th January 2009, 19:55 | #688 | Link |
I discovered that DirectShowSource() was dropping at least one frame on each segment. That becomes very problematic and cause out-of-sync audio when a title might contain numerous segments (M2TSs) in movie-only (e.g. Ratatouille). The way to fix it is by setting it to the correct value in the AVS file.
Capture the screen and post it so I can see what you mean by "the main movie" -- also capture the screen with the menu down shown where you can select MPLS files. |
20th January 2009, 19:56 | #689 | Link |
dings!
Movie only not possible with Life of Brian blu ray Europe
Bd-Rebuilder selects an obscure mpeg2-Stream@480i with 1.50h length and 5GB size as main movie, but the main movie is 25GB and AVC (mpeg4) and 1080p. Unfortunately it's not possible to select the main movie manually. Is there a possibility to do main movie only for this disk?
Thanks MvB |
20th January 2009, 19:59 | #690 | Link |
It is possible to select the main movie manually if you are using the latest version. The main-movie is selected by total size (in hours and minutes) -- there really is no other way to do it. Which version of BD-RB are you using?
20th January 2009, 20:03 | #691 | Link |
Version 0.18.03
I just did another update to the first post of this thread. Here is an updated change list for v0.18.02/03: Code:
January 20th, 2008 - v0.18.3 - Fixed an error in which empty folders that should be removed in AVCHD mode were not being correctly removed. January 20th, 2008 - v0.18.2 - PLEASE NOTE: Starting with this version, BD Rebuilder REQUIRES AVISYNTH v2.57 or above. If you do not have it installed, please download it from: http://www.jdobbs.net/freeware/Avisynth_257.exe and install it. BD-RB will not work with older versions of AVISYNTH. - Improved command line settings used for QUICK encodes. - Corrected error in QUICK encoding routine that could result in oversizing (particularly on series and extra discs). - Corrected an error that could cause "Runtime Error 6" when encoding audio. - Added code to catch errors during audio reencoding. - Added a checkbox in SETUP to make AC3 reencodes default to 640Kbs rather than 448Kbs. - Updated quality selection. There are now four levels based on recommendations from Dark Shikari. Now uses "ENCODE_QUALITY=" parameter in INI file. - Added a warning/restriction when source path lengths are too long (previously caused oversizing). - Corrected an error that would cause "Runtime Error 9" on certain discs with multiple story paths (angles). - Completely rewrote the movie-only handling routines to correct issues with certain multi-path/angle sources that had huge numbers of components and could cause BD-RB to crash with out-of-memory errors. - Added code to correct the "snap" sound in WAV files resulting from demuxing via TSMUXER. - Added chapter calculation to movie-only mode. Now the chapters will match those in the original playlist. - Added the ability to select from alternate playlists. This is especially useful for series discs and discs with more than one version of a film. Note: You can select only from playlists of least 15 mins. - Added traps to catch muxing errors that could result in "Runtime Error 76 - path not found". - Corrected "Runtime Error 424". - Fixed an error related to audio (especially LPCM) that could cause errors in "ReencodeAudio()" routine. - Fixed several issues in related to reecoding/keeping audio streams that could result in the wrong type code being set in the MPLS file. This could result in silent playback. - Made calculation changes to help prevent oversizing under certain conditions when audio is kept intact. - Added a SETUP option that makes what appears to be a more strictly compliant output (AVCHD) for the movie- only option. - Other minor corrections and cosmetic fixes. |
20th January 2009, 20:22 | #692 | Link | |
Bye |
20th January 2009, 21:10 | #695 | Link | ||
double image!!!
After reading thru many threads on different forums, I found out that the workarounds were either to re-encode adding borderss to any video streams that are not 720p or 1080p OR using BDedit + a hex editor to change the vertical res to 720p or 1080p. BD Rebuilder will then encode the streams correctly and there will not be any double images. Link to the writeup and needed software is http://brothers_grim.webs.com/bd/index.html BDedit thread here on doom9 is http://forum.doom9.org/showthread.php?t=125903 Good luck. James
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM |
20th January 2009, 22:46 | #699 | Link | |
Deleting AUXDATA did not work!
Just to let you know, with AUXDATA, disc is recognized as BD and it play but only audio with black screen. Movie Only. Jdobbs: Do you want me keep posting this error in this thread? Do you think the player is not accepting a BD disc into a DVD-5 disc? Do you think the new BD-RB version could make a difference? |
