20th March 2011, 22:43 | #4085 | Link |
Jagged edges on Standalone player
I have a great mystery going on here. I am seeing jagged edges on a 720 x 400 Xvid encode but I can't figure out why. I've used 2 sources, one of them progressive so its not a deinterlacing issue. I can encode a small clip of the file or the whole movie without audio and the problem isn't there. It consistently shows up when I try to encode the whole movie with audio. It almost looks like the resolution is way lower than it should be. I only see this on my Phillips DVP-3140 player, not on the PC. This means the player is seeing something different between the files but what? If I'm allowed to post pictures here, I could take one with my camera. I tried vidcaps in Media Player Classic and there is no difference.
25th March 2011, 04:57 | #4086 | Link |
My OS is Windows XP Pro 32 bits. I have tried several versions of staxrip (1.1.8 beta etc) but I get the same error... I tried to encode an AVC ts file.
Complete name : D:\2011_3_25_3_25_29.TS Format : MPEG-TS File size : 8.89 GiB Duration : 1h 39mn Overall bit rate : 12.7 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 1h 39mn Bit rate : 11.5 Mbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 1.107 Stream size : 8.01 GiB (90%) colour_primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM transfer_characteristics : BT.470-6 System B, BT.470-6 System G matrix_coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 39mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Video delay : -120ms Stream size : 274 MiB (3%) The errors I got... System.Exception: AVIFileOpen failed at StaxRip.AVIFile.Open(String path) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) System.Exception: AVIFileOpen failed at StaxRip.AVIFile.Open(String path) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.AviSynthDocument.GetFramerate() at StaxRip.GlobalClass.GetPreviewPosMS() at StaxRip.Macro.Solve(String value, Boolean rekursive, Boolean silent) at StaxRip.GlobalClass.MakeBugReport(Exception e) System.IO.IOException: Unknown error (0x402) at Microsoft.VisualBasic.FileIO.FileSystem.ThrowWinIOError(Int32 errorCode) at Microsoft.VisualBasic.FileIO.FileSystem.ShellFileOperation(SHFileOperationType OperationType, ShFileOperationFlags OperationFlags, String FullSource, String FullTarget, UICancelOption OnUserCancel, FileOrDirectory FileOrDirectory) at Microsoft.VisualBasic.FileIO.FileSystem.ShellDelete(String FullPath, UIOptionInternal ShowUI, RecycleOption recycle, UICancelOption OnUserCancel, FileOrDirectory FileOrDirectory) at Microsoft.VisualBasic.FileIO.FileSystem.DeleteDirectoryInternal(String directory, DeleteDirectoryOption onDirectoryNotEmpty, UIOptionInternal showUI, RecycleOption recycle, UICancelOption onUserCancel) at Microsoft.VisualBasic.FileIO.FileSystem.DeleteDirectory(String directory, UIOption showUI, RecycleOption recycle) at StaxRip.DirectoryHelp.Delete(String filepath) at StaxRip.GlobalClass.MakeBugReport(Exception e) Any ideas where is the problem? Last edited by w4tt4n4b3; 25th March 2011 at 05:10. |
26th March 2011, 17:39 | #4087 | Link |
Do you have Avisynth installed?
And can you open the ts file in windows media player? And can you open the ts file in VLC? Try both! And I have a question for the coders here. If you open the x264.vb file and go to the line: Sub ApplyDefaults(ByVal profileTunePreset As x264Params) You see all kinds of presets for x264, now I want to make my own preset but I don't know what I need to put in it and what not. Right now I'm using this command line: """%application:x264%"" --pass 1 --bitrate %video_bitrate% --stats ""%working_dir%%target_name%.stats"" --threads auto --keyint 240 --min-keyint 24 --bframes 3 --me dia --subme 1 --partitions none --output NUL ""%avs_file%""" + CrLf + """%application:x264%"" --pass 2 --bitrate %video_bitrate% --stats ""%working_dir%%target_name%.stats"" --threads auto --keyint 240 --min-keyint 24 --ref 3 --bframes 3 --weightb --subme 6 --trellis 1 --8x8dct --output ""%encoder_out_file%"" ""%avs_file%""" Someone here that can help me to create the preset thats using these settings?
CPU: i7 3930K @ 4.5Ghz MEM: 16GB GPU:NVIDIA GeForce GTX680 OS: Windows 7 64Bit Last edited by fabje; 26th March 2011 at 17:45. |
27th March 2011, 23:28 | #4089 | Link | |
If not I think I know how to fix that.
CPU: i7 3930K @ 4.5Ghz MEM: 16GB GPU:NVIDIA GeForce GTX680 OS: Windows 7 64Bit |
27th March 2011, 23:43 | #4091 | Link | |
Now try to open this new .ts file with Staxrip.
27th March 2011, 23:56 | #4092 | Link |
the new ts file has size of 30,5 mb while the original had 66mb size. I tried a different ts file than the one I posted.
I get errors again mate... Now even if I don't load any file in StaxRip when I right click on the Filters area of Staxrip gui I get an error again. See the attached image. thank you for your help though. |
29th March 2011, 20:40 | #4093 | Link |
I've moved over to Staxrip from the excellent HDConverttoX(project appears to be finished?) and must say I am very impressed. There was an Avisynth filter I used in HDC and got marvellous results with every avi encoding: SoftSharpen(preset="film") I tried to isolate it, but could not find it in the filter folder(maybe part of a package of scripts?), as I would really like to use it with Staxrip.
The results using this filter combined with hq3dn_denoise filter with Xvid encodings were quite startling and deserve to be in the options of Staxrip. |
30th March 2011, 04:46 | #4094 | Link | |
Practising Schemer
You can then simply edit your profiles in staxrip to add as many filters in as many configurations as you like. |
30th March 2011, 12:47 | #4095 | Link |
Excellent idea! I'm really glad I posted here, as people give superb practical tips which at the time you never seem to think of yourself when struggling for a solution. I originally wrongly thought you would have to place the filters directly into the Staxrip avisynth plugin folder rather than AviSynth's own program folder installed in the system.
You wouldn't have any additional user friendly tutorial handy on editing avisynth profiles specifically in Staxrip would you as I am newish to it? I found one below and it mentions plugins: http://sourceforge.net/apps/mediawik...ding_directory I found the script for SoftSharpen 7.8(after opening in notepad) and apparently it is a list of tools, so it will be a bit trickier to make the profile. Incidentally I see Fluxsmooth is in Staxrip. I could never get that one to work in HDC as it kept crashing, but it works fine in Staxrip. I used to use Fairusewizard 2.11b after AutoGK. FUW produces good quality, but could do with additional filters built in like the avisynth denoise ones and AutoGK is dated now. Thankyou very much for your help flebber. Last edited by datauser; 30th March 2011 at 17:22. |
30th March 2011, 21:26 | #4096 | Link |
Is it possible to use CoreAVC with Staxrip, and if so how?
What do I need to do on my system and in Staxrip to get it working?
31st March 2011, 20:53 | #4097 | Link |
I added to my chosen plugins in editing of profile:
[Additional] Advanced | SoftSharpen = SoftSharpen(preset="film") The avi 2 pass Xvid transcoded/encoded well and the Aviscript in temp files showed this editing of mine to the profile, but how do I really know it worked 100%, is the real question? |
1st April 2011, 10:16 | #4099 | Link |
any solution on the SUB issue "I've found that Staxrip 1.1.7.0 won't automatically rip the subtitles if you change the default Temp Files Directory. "
i have changed my temp directory, had no choice, my C drive is only 12GB, i have other drives for my video, films, music, pictures and games etc. (not sure if NTFSLink (junction point) will work), will have to try that out now i think about it. if anyone could share some light on this however....appreciate it. |
1st April 2011, 12:16 | #4100 | Link | |
I have no problems with temp; i have StaxRip on D partition, movie for rip also, temp is where movie directory is (as default). |
gui, h.264, h.265, hevc, mkv, x264, x265 |
