Old 15th June 2007, 13:24   #181  |  Link
Zenitram
Originally Posted by JoeBG View Post
I want to use the commandline tool to get variables for the stream length or the aspect ratio but I always fail.
For example: I have a AC3 stream and I want to have the lenght of it. Can someone give me a working commandline - many thanks.
For AC3 :
Command : MediaInfo --Inform=General;%PlayTime% FileName.ac3
Command : MediaInfo --Inform=Audio;%PlayTime% FileName.avi
Result : 1256960 (in milliseconds)
Command : MediaInfo --Inform=Audio;%PlayTime/String% FileName.avi
Result : 20mn 56s
Note : during the verification of the command, I noticed that lenght in the audio part (MediaInfo --Inform=Audio;%PlayTime%) for an AC3 file is lacking. I will correct this.
For AspectRatio :
Command : MediaInfo.exe --Inform=Video;%AspectRatio% FileName.avi
Result : 1.777
Command : MediaInfo.exe --Inform=Video;%AspectRatio/String% FileName.avi
Result : 16/9
Command : MediaInfo --Info-Parameters
Result : list the available parameters (between %)
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 16th June 2007, 09:17   #182  |  Link
JoeBG
stupid
JoeBG's Avatar
First of all thanks for your help.
Here the results from my test.
I used the following commandline:
mediainfo --Inform=Video;%AspectRatio% C:\files\****\Daten\VTS_01_1.VOB
The result is the same as if I would have used
mediainfo --Inform C:\files\****\Daten\VTS_01_1.VOB
=> mediainfo.exe shows all informations and ignores *Video;%AspectRatio%*
I do have the same result with AC3 streams. mediainfo.exe shows always all informations and not the selected ones.
Maybe Im doing it wrong, but I used exactly your commandlines
Herewith my versions of mediainfo.exe and mediainfo.dll
cu
Joe
freedom is just another word for nothing left to loose
JoeBG is offline   Reply With Quote
Old 16th June 2007, 10:17   #183  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
You do have to use the command-line version; the command-line commands don't work with the GUI. (They have the same name, which makes it unnecessarily confusing. I always rename mine mediainfo-cli.exe. Even nicer would be if the GUI recognized cli commands and emulated it, removing the need for two executables...)
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 16th June 2007, 10:31   #184  |  Link
JoeBG
stupid
JoeBG's Avatar
I do use the commandline version
cu
Joe
Old 16th June 2007, 10:56   #185  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Weird then, because the commands work on any files I can find. (With the exception of the error Zenitram already found.)
Old 16th June 2007, 11:06   #186  |  Link
Zenitram
I tested *your* version of MediaInfo on my files, and it works
Maybe a problem with your OS, your localization, I don't know.
I don't know what to do more
I propose you contact me at zen@mediaarea.net for giving me an access to your computer, and I will do more tests.
Yes, weird... Sometimes, I hate programming
I already tested to have different names, GUI users want a short name rather than mediainfo-gui, CLI users too, so impossible to have all people happy (and you are the first user I know who use both! )
But yes, the GUI version will parse CLI options in the future.
(but I didn't plan my software would become so used and this is my first program, I must work a lot to have a all people happy, with a good programming, and whith the time I have...)
Old 16th June 2007, 16:44   #187  |  Link
JoeBG
stupid
JoeBG's Avatar
I used a bat-file in my tests. When I type everything in my cmd-box without using a batchfile everything works for me too. Very strange everything
My plan is to use the variable %PlayTime% for further actions in DOS. But I think I cannot use it as %PlayTime% for further calculations isnt it?
cu
Joe
Old 9th October 2007, 08:52   #188  |  Link
mihakase
The current syntax to get particular parameters using Inform is a little odd in Linux. Bash interprets the semicolon as the end of a command/line and tries to execute whatever comes after it.
Workaround is currently:
MediaInfo --Inform=xxx\;%param% file.ext
mihakase is offline   Reply With Quote
Old 9th October 2007, 09:21   #189  |  Link
Zenitram
the ";" is useful because I use internaly CSV format (semi-colomn, as in Europe...).
I don't plan to change this soon.
You can use a file too:
MediaInfo --Inform=file://SpecFile file.ext
And SpecFile contains "xxx;%param%"
If I add an option for accepting commas too, will it be better?
Old 9th October 2007, 09:33   #190  |  Link
mihakase
Commas would be nice. I personally don't mind the semicolon but I figured the behaviour was worth noting anyway.
On a side note, I'm looking through mediainfo lib's source; trying to figure out how it gets an FLV's dimensions since I kind of need to implement that in php. It would probably help if I were a bit more competent though... no go as of yet.
Old 9th October 2007, 11:18   #191  |  Link
Zenitram
In PHP, it will be diffucult to call MediaInfo library (written in C/C++), why don't you use mediainfo command line?
I heard about several user who call mediainfo from PHP without problems.
./mediainfo --Inform=Video;%Width% %Height% for example.
Old 9th October 2007, 15:36   #192  |  Link
GrofLuigi
Member of a Library
On another note, since many programs use MediaInfo dll now, can it be placed in a path directory to avoid multiple copies and for better updating? (On Windows)
Will that affect these programs (I guess only their authors would know)?
GL
GrofLuigi is offline   Reply With Quote
Old 9th October 2007, 15:40   #193  |  Link
Zenitram
GL
How DLL works on Windows:
- Search in the .exe directory
- Search in the path
If you delete yourself the .dll in the porgram directory, the program will search in the path.
this is not a problem from the DLL, but from any third-party programs mainteners.
For MediaInfo (the GUI), the status of MediaInfo.dll is not "stable", so I prefer to not force updating. After, others do what they want.
When MediaInfo.dll is more stable, I may propose to install in a shared directory. Not now. (the version 0.x, not 1.x ;-) )
Old 22nd November 2007, 18:37   #194  |  Link
ficofico
edit, sorry
ficofico is offline   Reply With Quote
Old 25th November 2007, 22:11   #195  |  Link
vlada
I was using MediaInfo in my PHP-GTK application from command line. No I decided to move a little further and switch to Python. I heard somewhere it should be possible to use a C/C++ dll in Python. Does anyone have any idea (or code sample) how to use the mediainfo.dll in Python?
vlada is offline   Reply With Quote
Old 26th November 2007, 02:30   #196  |  Link
Thunderbolt8
would it be possible that mediainfo could give the length of both, audio and video stream inside a container file? dont know which of these 2 is meant with the general "length" info of the file.
Old 27th November 2007, 23:57   #197  |  Link
vlada
I made Python load MediaInfo.dll through ctypes. But when I try to call the function result = lib.MediaInfo_Open("video.avi"), then Python complains there are not enough parameters for the function. What other parameters should be there?
Sorry for probably stupid questions, I'm just a beginner.
Old 28th November 2007, 03:56   #198  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
You have to use:
handle=lib.MediaInfo_New();
result=lib.MediaInfo_Open(handle,"video.avi")
MediaInfo_Delete(handle)
now.
Old 29th November 2007, 15:09   #199  |  Link
vlada
I've already tried this, but it gives me the same error:
Any ideas what's wrong?
Old 2nd December 2007, 22:27   #200  |  Link
vlada
A friend of mine wrote a Python wrapper for the .dll so it is solved. I didn't have the time to dive into the code yet, I just verified it works. If anyone's interested in it, let me know.
Anyway I have another problem. I'm not sure if MediaInfo is supposed to handle elemantary streams, but I think it usually does. I have a h.264 stream demuxed from AVCHD camcorder. MediaInfo 0.7.5.5 reports it as an AC3 audio. A sample can be downloaded here (7 MB).
