Old 24th September 2018, 13:49   #741  |  Link
DMD
DMD's Avatar
Good morning.
I'm using version 3.5.7, when I load a ".sup" file to create the srt file via OCR, I get this message.
This does not happen with the previous version 3.5.6, how can you solve?
I noticed that in the installation folder, there is a new folder "Tesseract4" instead of "Tesseract", present in the previous version.
Thank you
DMD is offline   Reply With Quote
Old 24th September 2018, 14:44   #742  |  Link
jpsdr
The last beta linked seems to behave like 3.5.6 with tesseract 3.02.
My github.
Old 24th September 2018, 17:49   #743  |  Link
DMD
DMD's Avatar
In version 3.5.7 I have set in the section
Engine mode> Default, based on what is available, it works regularly.
If I select Original Tesseract only (can detect italic) I get the error message.
Old 26th September 2018, 06:14   #744  |  Link
mood
we need a fix version soon to remove Tesseract 4 and folders, to many bugs on Tesseract4
mood is offline   Reply With Quote
Old 14th October 2018, 13:37   #745  |  Link
sneaker_ger
In the MPC-BE thread an mp4 sample was posted. SubtitleEdit (latest beta) handles it differently than ffmpeg and I think ffmpeg is correct.
ffmpeg:
SubtitleEdit Beta:
I'm not 100% sure the file isn't broken but maybe you want to take a look at it.
Old 14th October 2018, 14:12   #746  |  Link
mkver
I vaguely remember that there is something odd with ffmpeg and timed text in mp4: The last subtitle would continue until the end of the file. So I would not count (or even bet) on ffmpeg being correct. But I was too lazy to open an issue for it.
mkver is offline   Reply With Quote
Old 14th October 2018, 14:14   #747  |  Link
sneaker_ger
https://trac.ffmpeg.org/ticket/6341
But this problem is not specifically about the last line.
Old 14th October 2018, 14:30   #748  |  Link
mkver
Yes, that seems to be it. I have already encountered files (which have been created by ffmpeg according to their metadata) whose last line continued for several minutes and for which ffmpeg and SubtitleEdit differed in their timings just like in your screenshots. Therefore they might be related somehow.
Old 25th October 2018, 08:42   #749  |  Link
von Suppé
von Suppé's Avatar
Hi Nikse,
It seems a few old bugs have sneaked in again in version 3.5.7.
The "Dialogue one hyphen only" plugin also removed the hyphen in a single line subtitle.
Also I encountered several times (not always, though) that, after running "Tools --> Fix common errors", the changes previously made by the "Dialogue one hyphen only" plugin are undone. So I would have to run the plugin again.
In version 3.5.6 I didn't run into these issues.
Can you please take a look?
Thanks
Old 28th October 2018, 16:10   #750  |  Link
DMD
DMD's Avatar
Good morning
I ask if it is possible to enable the font color panel to the hexadecimal code.
The possibility is to copy a color with photoshop in hexadecimal code and the possibility to insert it in the appropriate box.
What I currently do not allow, but only RGB values.
Thank you
Old 3rd December 2018, 01:12   #751  |  Link
Zetti
Hello.
Both version 3.5.6 and 3.5.7 wont auto translate with Google Translate.
The lastest beta can only translate about 37 lines with Google Translate but without API Key.
And the Microsoft Translator wont working at all without API Key.
I have tried to get a free API Key to both Google Translate and Microsoft Translator, but it seems to hard for me.
Zetti is offline   Reply With Quote
Old 4th December 2018, 19:18   #752  |  Link
Nikse555
@DMD: Where is this font dialog?
@Zetti: I've tried to squeeze a few more lines through (by using larger chunks) in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip
How many lines do you get now?
Nikse555 is offline   Reply With Quote
Old 4th December 2018, 21:04   #753  |  Link
Zetti
I getting a full subtitle now.
Edit: The subtitle have 2099 lines.
Old 9th December 2018, 07:20   #754  |  Link
kenzofabio
For everybody in using subtitle edit 3.57 i dont know what happen what this program.i just can use one translate for subtitle.and it said that api quota acess.thx
kenzofabio is offline   Reply With Quote
Old 9th December 2018, 15:15   #755  |  Link
Zetti
@kenzofabio
Check this github link: https://github.com/SubtitleEdit/subt...it/issues/3209
Old 17th December 2018, 17:41   #756  |  Link
orion44
None
orion44's Avatar
Thanks to the developer for this excellent program.
A feature request: When exporting subtitles to VobSub (sub/idx) format, could you add the 'character spacing' option,
to set in pixels the space/distance between characters?
Preferably, under the "Line height" option.
It is a really needed option when setting the look of the subtitles, especially when viewing them on TV.
orion44 is offline   Reply With Quote
Old 20th December 2018, 17:26   #757  |  Link
Nikse555
@orion44: The default libraries with c#/winforms don't have any 'character spacing' options as far as I know... anybody got any ideas?
Also, SE 3.5.8 is out - Now again includes Tesseract 3.02 per default and an in-program option to download the new Tesseract 4 (Tesseract 4 is pretty slow and do not have italic detection - but it has more languages + works better for small difficult fonts).
Also the translate works somewhat again...
Link to release page on github: https://github.com/SubtitleEdit/subtitleedit/releases
Old 7th January 2019, 15:43   #758  |  Link
FLX90
Thank you for the great program. I used it for many BluRays and it worked like a charm.
Now I have a strange problem with the german Oldboy (2003) BluRay
I extracted idx&sub and the srt output would be:
00:00:50,800 --> 00:00:51,005
Was soll das?
2
00:00:51,009 --> 00:00:51,214
Was soll das?
3
00:00:51,217 --> 00:00:52,378
Was soll das?
4
00:00:52,802 --> 00:00:53,007
Hast du nicht verstanden?
Ich will nur mit dir reden.
5
00:00:53,011 --> 00:00:53,216
6
00:00:53,219 --> 00:00:53,424
7
00:00:53,428 --> 00:00:53,633
8
00:00:53,636 --> 00:00:53,841
9
00:00:53,845 --> 00:00:54,050
10
00:00:54,054 --> 00:00:54,259
11
00:00:54,262 --> 00:00:54,467
12
00:00:54,471 --> 00:00:54,676
13
00:00:54,679 --> 00:00:54,884
14
00:00:54,888 --> 00:00:55,093
15
00:00:55,096 --> 00:00:55,301
16
00:00:55,305 --> 00:00:55,510
17
00:00:55,513 --> 00:00:55,718
18
00:00:55,722 --> 00:00:55,927
19
00:00:55,930 --> 00:00:56,135
20
00:00:56,139 --> 00:00:56,344
21
00:00:56,347 --> 00:00:56,552
22
00:00:56,556 --> 00:00:57,671
Is this a bug on the BluRay?
I think it would be the best to do something like this:
00:00:50,800 --> 00:00:52,378
Was soll das?
2
00:00:52,802 --> 00:00:57,671
But the output has 38564 lines.
Would be kind of sisyphean challenge.
I had to write a script.
Is there another workaround?
FLX90 is offline   Reply With Quote
Old 7th January 2019, 15:51   #759  |  Link
sneaker_ger
Tools->Merge lines with same text
Old 7th January 2019, 21:44   #760  |  Link
FLX90
Oh, don’t saw that.
Thank you.
Awesome tool.
