24th September 2018, 04:44 | #27741 | Link | |
2) How to tell BDRB to display the menu text at the end of the video? Take a look at this motion video. As can be seen, displaying the menu text when the video starts to play is not good. This is the type of video where the menu text needs to be displayed at the end. Maybe a hidden option: DISPLAY_MOTION_TEXT=0 where 0 means at the start and 1 means at the end. Before anyone asks, the three seconds of black at the start is to allow the audio amp to detect the type of audio stream. |
24th September 2018, 04:54 | #27742 | Link | |
2. No way to do that right now. I had just planned to provide motion video as the background. That’d be outside the scope of what I intended for it. |
24th September 2018, 09:38 | #27743 | Link | |
That I can easily work around.
25th September 2018, 00:14 | #27744 | Link |
Just a note: I think I'm close on the UHD-BD reencodes. I found some interesting information that has (at least on one title) gotten rid of the issues I was having. I think its a combination X265/TSMUXER thing. More to come.
By the way... if anyone has any information they've gathered on the UHD-BD standard they can share (extensions etc. for HEVC and UHD), it would sure help me out. Last edited by jdobbs; 25th September 2018 at 00:22. |
25th September 2018, 05:21 | #27747 | Link | |
For MPC-HC which is also not getting enough donations..but an excellent program - Start the video, Pause it (click once in screen), Right Click anywhere, and from Menu at the TOP hover over Fire and then Save Image. There it is...
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 25th September 2018 at 05:24. |
25th September 2018, 14:01 | #27749 | Link |
Starfish
After a long time I tried to use BD-RB today again.
I just wanted to blank some annoying warnings and keep the rest as is. Even though the option FORCE_NOENCODE=1 is set, BD-RB reencodes the video. So I tried a dryrun with all extras, movie and warnings enabled. I also set the target size to 55000 MB. At first it was promising, the short warnings were not reencoded. But as soon as the movie kicked in BD-RB startet reencodeing. I aborted the process. I am not sure if I am missing something. The BD has multiangle (3 angles). Code:
---------------------- [09.25.18] BD Rebuilder v0.50.25 [14:39:38] Source: - Input BD size: 40,89 GB - Approximate total content: [02:31:47.906] - Target BD size: 53,71 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:39:38] PHASE ONE, Encoding - [14:39:38] Processing: VID_00006 (1 of 99) - [14:39:38] Extracting A/V streams [VID_00006] - [14:39:42] Reencoding video [VID_00006] - [14:39:42] Keeping original video (no reencode) - [14:39:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:39:43] Multiplexing M2TS - [14:39:46] Processing: VID_00100 (2 of 99) - [14:39:46] Extracting A/V streams [VID_00100] - [14:39:50] Reencoding video [VID_00100] - [14:39:50] Keeping original video (no reencode) - [14:39:50] Processing audio tracks - [14:39:50] Multiplexing M2TS . . . - [14:50:26] Processing: VID_00339 (89 of 99) - [14:50:26] Extracting A/V streams [VID_00339] - [14:50:29] Reencoding video [VID_00339] - [14:50:29] Keeping original video (no reencode) - [14:50:29] Processing audio tracks - [14:50:29] Multiplexing M2TS - [14:50:33] Processing: VID_00340 (90 of 99) - [14:50:33] Extracting A/V streams [VID_00340] - [14:50:37] Reencoding video [VID_00340] - [14:50:37] Keeping original video (no reencode) - [14:50:37] Processing audio tracks - [14:50:37] Multiplexing M2TS - [14:50:40] Processing: VID_00341 (91 of 99) - [14:50:40] Extracting A/V streams [VID_00341] - [14:50:44] Reencoding video [VID_00341] - [14:50:44] Keeping original video (no reencode) - [14:50:44] Processing audio tracks - [14:50:44] Multiplexing M2TS - [14:50:48] Processing: VID_00810 (92 of 99) - [14:50:48] Extracting A/V streams [VID_00810] - [14:50:53] Reencoding video [VID_00810] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.214 frames - Bitrate: 28.750 Kbs - [14:50:53] Reencoding: VID_00810, Pass 1 of 2 - [14:51:11] Reencoding: VID_00810, Pass 2 of 2 [14:51:16]PHASE ONE aborted by user request Code:
[Options] VERSION=0.50.0.24 MODE=0 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=1 UNMASK_CHAPTER=1 COMPLETION_BEEP=0 DGDECNV=0 OUTPUT_3D=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=55000 ENABLE_TEST=1 ENABLE_BLANKING=1 DTSX_ENABLE=1 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=deu;eng;ger; MIN_M2TS_SIZE=1 BLANK_THRESHOLD=10 TARGET_SIZE=55000 FORCE_NOENCODE=1 ENCODER=0 IGNORE_3D=0 AUDIO_DRC=0 DECODER=2 FRIMSOURCE=0 OUTPUT_SBS=0 PGSTOSRT=0 |
25th September 2018, 23:41 | #27753 | Link |
Role Models update.
Paranoid isn't really my thing. Nor is having advertising and other tracking happening because of their Email and Chrome. Conspiracy stuff isn't my bag either.
Many people use the quickest and most common methods to many things - unaware of what's happening in the background. Anyway, JD... Update to Role Models extra (Deleted Scenes)... I did a little skimming with the extras...and the "work-around", of making a BD out of the extras didn't go as well as I thought. So I ripped it again, same error... This is using the default config with the new release. Code:
[09/25/18] BD Rebuilder v0.60.01 [14:48:42] Source: ROLE_MODELS_00100 - Input BD size: 5.84 GB - Approximate total content: [00:49:49.819] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [14:48:45] PHASE ONE, Encoding - [14:48:45] Processing: VID_00361 (1 of 81) - [14:48:45] Extracting A/V streams [VID_00361] - [14:49:14] Reencoding video [VID_00361] - [14:49:14] Keeping original video (no reencode) - [14:49:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:49:15] Processing: VID_00362 (2 of 81) [...] - [14:54:53] Processing: VID_00442 (81 of 81) - [14:54:53] Extracting A/V streams [VID_00442] - [14:54:57] Reencoding video [VID_00442] - [14:54:57] Keeping original video (no reencode) [14:54:57]PHASE ONE complete [14:54:57]PHASE TWO - Rebuild Started - [14:54:57] Building ALTERNATE OUTPUT Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Not enought buffer for parse video stream. Current frame num 0 [14:56:02] - Failed to REBUILD
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
26th September 2018, 08:20 | #27755 | Link | |
Starfish
Secondly, the log is too long so I cut some stuff which seemed unnecessary. And last but not least I was not sure if it is allowed to post the Volumename. Code:
---------------------- [09.25.18] BD Rebuilder v0.50.25 [14:39:38] Source: SOLO_A_STAR_WARS_STORY - Input BD size: 40,89 GB - Approximate total content: [02:31:47.906] - Target BD size: 53,71 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:39:38] PHASE ONE, Encoding - [14:39:38] Processing: VID_00006 (1 of 99) - [14:39:38] Extracting A/V streams [VID_00006] - [14:39:42] Reencoding video [VID_00006] - [14:39:42] Keeping original video (no reencode) - [14:39:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:39:43] Multiplexing M2TS - [14:39:46] Processing: VID_00100 (2 of 99) - [14:39:46] Extracting A/V streams [VID_00100] - [14:39:50] Reencoding video [VID_00100] - [14:39:50] Keeping original video (no reencode) - [14:39:50] Processing audio tracks - [14:39:50] Multiplexing M2TS - [14:39:53] Processing: VID_00101 (3 of 99) - [14:39:53] Extracting A/V streams [VID_00101] - [14:39:57] Reencoding video [VID_00101] - [14:39:57] Keeping original video (no reencode) - [14:39:57] Processing audio tracks - [14:39:57] Multiplexing M2TS - [14:40:01] Processing: VID_00102 (4 of 99) - [14:40:01] Extracting A/V streams [VID_00102] - [14:40:04] Reencoding video [VID_00102] - [14:40:04] Keeping original video (no reencode) - [14:40:04] Processing audio tracks - [14:40:04] Multiplexing M2TS - [14:40:08] Processing: VID_00103 (5 of 99) - [14:40:08] Extracting A/V streams [VID_00103] - [14:40:12] Reencoding video [VID_00103] - [14:40:12] Keeping original video (no reencode) - [14:40:12] Processing audio tracks - [14:40:12] Multiplexing M2TS - [14:40:15] Processing: VID_00104 (6 of 99) - [14:40:15] Extracting A/V streams [VID_00104] - [14:40:19] Reencoding video [VID_00104] - [14:40:19] Keeping original video (no reencode) - [14:40:19] Processing audio tracks - [14:40:19] Multiplexing M2TS - [14:40:23] Processing: VID_00105 (7 of 99) - [14:40:23] Extracting A/V streams [VID_00105] - [14:40:26] Reencoding video [VID_00105] - [14:40:26] Keeping original video (no reencode) - [14:40:26] Processing audio tracks - [14:40:26] Multiplexing M2TS - [14:40:30] Processing: VID_00106 (8 of 99) - [14:40:30] Extracting A/V streams [VID_00106] - [14:40:34] Reencoding video [VID_00106] - [14:40:34] Keeping original video (no reencode) - [14:40:34] Processing audio tracks - [14:40:34] Multiplexing M2TS - [14:40:37] Processing: VID_00107 (9 of 99) - [14:40:37] Extracting A/V streams [VID_00107] - [14:40:41] Reencoding video [VID_00107] - [14:40:41] Keeping original video (no reencode) - [14:40:41] Processing audio tracks - [14:40:41] Multiplexing M2TS - [14:40:45] Processing: VID_00108 (10 of 99) - [14:40:45] Extracting A/V streams [VID_00108] - [14:40:49] Reencoding video [VID_00108] - [14:40:49] Keeping original video (no reencode) - [14:40:49] Processing audio tracks - [14:40:49] Multiplexing M2TS - [14:40:52] Processing: VID_00109 (11 of 99) - [14:40:52] Extracting A/V streams [VID_00109] - [14:40:56] Reencoding video [VID_00109] - [14:40:56] Keeping original video (no reencode) - [14:40:56] Processing audio tracks - [14:40:56] Multiplexing M2TS - [14:41:00] Processing: VID_00110 (12 of 99) - [14:41:00] Extracting A/V streams [VID_00110] - [14:41:03] Reencoding video [VID_00110] - [14:41:03] Keeping original video (no reencode) - [14:41:03] Processing audio tracks - [14:41:03] Multiplexing M2TS - [14:41:07] Processing: VID_00111 (13 of 99) - [14:41:07] Extracting A/V streams [VID_00111] - [14:41:11] Reencoding video [VID_00111] - [14:41:11] Keeping original video (no reencode) - [14:41:11] Processing audio tracks - [14:41:11] Multiplexing M2TS - [14:41:15] Processing: VID_00112 (14 of 99) - [14:41:15] Extracting A/V streams [VID_00112] - [14:41:19] Reencoding video [VID_00112] - [14:41:19] Keeping original video (no reencode) - [14:41:19] Processing audio tracks - [14:41:19] Multiplexing M2TS - [14:41:22] Processing: VID_00113 (15 of 99) - [14:41:22] Extracting A/V streams [VID_00113] - [14:41:26] Reencoding video [VID_00113] - [14:41:26] Keeping original video (no reencode) - [14:41:26] Processing audio tracks - [14:41:26] Multiplexing M2TS - [14:41:29] Processing: VID_00114 (16 of 99) - [14:41:29] Extracting A/V streams [VID_00114] - [14:41:33] Reencoding video [VID_00114] - [14:41:33] Keeping original video (no reencode) - [14:41:33] Processing audio tracks - [14:41:33] Multiplexing M2TS - [14:41:37] Processing: VID_00115 (17 of 99) - [14:41:37] Extracting A/V streams [VID_00115] - [14:41:41] Reencoding video [VID_00115] - [14:41:41] Keeping original video (no reencode) - [14:41:41] Processing audio tracks - [14:41:41] Multiplexing M2TS - [14:41:44] Processing: VID_00116 (18 of 99) - [14:41:44] Extracting A/V streams [VID_00116] - [14:41:48] Reencoding video [VID_00116] - [14:41:48] Keeping original video (no reencode) - [14:41:48] Processing audio tracks - [14:41:48] Multiplexing M2TS - [14:41:52] Processing: VID_00117 (19 of 99) - [14:41:52] Extracting A/V streams [VID_00117] - [14:41:55] Reencoding video [VID_00117] - [14:41:55] Keeping original video (no reencode) - [14:41:55] Processing audio tracks - [14:41:55] Multiplexing M2TS |
26th September 2018, 08:20 | #27756 | Link |
Starfish
- [14:41:59] Processing: VID_00118 (20 of 99) - [14:41:59] Extracting A/V streams [VID_00118] - [14:42:03] Reencoding video [VID_00118] - [14:42:03] Keeping original video (no reencode) - [14:42:03] Processing audio tracks - [14:42:03] Multiplexing M2TS - [14:42:06] Processing: VID_00119 (21 of 99) - [14:42:06] Extracting A/V streams [VID_00119] - [14:42:10] Reencoding video [VID_00119] - [14:42:10] Keeping original video (no reencode) - [14:42:10] Processing audio tracks - [14:42:10] Multiplexing M2TS - [14:42:14] Processing: VID_00120 (22 of 99) - [14:42:14] Extracting A/V streams [VID_00120] - [14:42:17] Reencoding video [VID_00120] - [14:42:17] Keeping original video (no reencode) - [14:42:17] Processing audio tracks - [14:42:17] Multiplexing M2TS - [14:42:21] Processing: VID_00121 (23 of 99) - [14:42:21] Extracting A/V streams [VID_00121] - [14:42:25] Reencoding video [VID_00121] - [14:42:25] Keeping original video (no reencode) - [14:42:25] Processing audio tracks - [14:42:25] Multiplexing M2TS - [14:42:28] Processing: VID_00122 (24 of 99) - [14:42:28] Extracting A/V streams [VID_00122] - [14:42:32] Reencoding video [VID_00122] - [14:42:32] Keeping original video (no reencode) - [14:42:32] Processing audio tracks - [14:42:32] Multiplexing M2TS - [14:42:36] Processing: VID_00123 (25 of 99) - [14:42:36] Extracting A/V streams [VID_00123] - [14:42:39] Reencoding video [VID_00123] - [14:42:39] Keeping original video (no reencode) - [14:42:39] Processing audio tracks - [14:42:39] Multiplexing M2TS - [14:42:43] Processing: VID_00124 (26 of 99) - [14:42:43] Extracting A/V streams [VID_00124] - [14:42:47] Reencoding video [VID_00124] - [14:42:47] Keeping original video (no reencode) - [14:42:47] Processing audio tracks - [14:42:47] Multiplexing M2TS - [14:42:50] Processing: VID_00125 (27 of 99) - [14:42:50] Extracting A/V streams [VID_00125] - [14:42:54] Reencoding video [VID_00125] - [14:42:54] Keeping original video (no reencode) - [14:42:54] Processing audio tracks - [14:42:54] Multiplexing M2TS - [14:42:58] Processing: VID_00126 (28 of 99) - [14:42:58] Extracting A/V streams [VID_00126] - [14:43:01] Reencoding video [VID_00126] - [14:43:01] Keeping original video (no reencode) - [14:43:01] Processing audio tracks - [14:43:01] Multiplexing M2TS - [14:43:05] Processing: VID_00127 (29 of 99) - [14:43:05] Extracting A/V streams [VID_00127] - [14:43:09] Reencoding video [VID_00127] - [14:43:09] Keeping original video (no reencode) - [14:43:09] Processing audio tracks - [14:43:09] Multiplexing M2TS - [14:43:12] Processing: VID_00128 (30 of 99) - [14:43:12] Extracting A/V streams [VID_00128] - [14:43:16] Reencoding video [VID_00128] - [14:43:16] Keeping original video (no reencode) - [14:43:16] Processing audio tracks - [14:43:16] Multiplexing M2TS - [14:43:20] Processing: VID_00129 (31 of 99) - [14:43:20] Extracting A/V streams [VID_00129] - [14:43:24] Reencoding video [VID_00129] - [14:43:24] Keeping original video (no reencode) - [14:43:24] Processing audio tracks - [14:43:24] Multiplexing M2TS - [14:43:27] Processing: VID_00130 (32 of 99) - [14:43:27] Extracting A/V streams [VID_00130] - [14:43:31] Reencoding video [VID_00130] - [14:43:31] Keeping original video (no reencode) - [14:43:31] Processing audio tracks - [14:43:31] Multiplexing M2TS - [14:43:34] Processing: VID_00131 (33 of 99) - [14:43:34] Extracting A/V streams [VID_00131] - [14:43:38] Reencoding video [VID_00131] - [14:43:38] Keeping original video (no reencode) - [14:43:38] Processing audio tracks - [14:43:38] Multiplexing M2TS - [14:43:42] Processing: VID_00132 (34 of 99) - [14:43:42] Extracting A/V streams [VID_00132] - [14:43:46] Reencoding video [VID_00132] - [14:43:46] Keeping original video (no reencode) - [14:43:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:43:46] Multiplexing M2TS - [14:43:49] Processing: VID_00133 (35 of 99) - [14:43:49] Extracting A/V streams [VID_00133] - [14:43:53] Reencoding video [VID_00133] - [14:43:53] Keeping original video (no reencode) - [14:43:53] Processing audio tracks - [14:43:53] Multiplexing M2TS - [14:43:56] Processing: VID_00134 (36 of 99) - [14:43:56] Extracting A/V streams [VID_00134] - [14:44:00] Reencoding video [VID_00134] - [14:44:00] Keeping original video (no reencode) - [14:44:00] Processing audio tracks - [14:44:00] Multiplexing M2TS - [14:44:04] Processing: VID_00135 (37 of 99) - [14:44:04] Extracting A/V streams [VID_00135] - [14:44:08] Reencoding video [VID_00135] - [14:44:08] Keeping original video (no reencode) - [14:44:08] Processing audio tracks - [14:44:08] Multiplexing M2TS - [14:44:11] Processing: VID_00136 (38 of 99) - [14:44:11] Extracting A/V streams [VID_00136] - [14:44:15] Reencoding video [VID_00136] - [14:44:15] Keeping original video (no reencode) - [14:44:15] Processing audio tracks - [14:44:15] Multiplexing M2TS - [14:44:19] Processing: VID_00137 (39 of 99) - [14:44:19] Extracting A/V streams [VID_00137] - [14:44:22] Reencoding video [VID_00137] - [14:44:22] Keeping original video (no reencode) - [14:44:22] Processing audio tracks - [14:44:22] Multiplexing M2TS - [14:44:26] Processing: VID_00138 (40 of 99) - [14:44:26] Extracting A/V streams [VID_00138] - [14:44:30] Reencoding video [VID_00138] - [14:44:30] Keeping original video (no reencode) - [14:44:30] Processing audio tracks - [14:44:30] Multiplexing M2TS - [14:44:33] Processing: VID_00139 (41 of 99) - [14:44:33] Extracting A/V streams [VID_00139] - [14:44:37] Reencoding video [VID_00139] - [14:44:37] Keeping original video (no reencode) - [14:44:37] Processing audio tracks - [14:44:37] Multiplexing M2TS - [14:44:41] Processing: VID_00140 (42 of 99) - [14:44:41] Extracting A/V streams [VID_00140] - [14:44:44] Reencoding video [VID_00140] - [14:44:44] Keeping original video (no reencode) - [14:44:44] Processing audio tracks - [14:44:44] Multiplexing M2TS - [14:44:48] Processing: VID_00141 (43 of 99) - [14:44:48] Extracting A/V streams [VID_00141] - [14:44:52] Reencoding video [VID_00141] - [14:44:52] Keeping original video (no reencode) - [14:44:52] Processing audio tracks - [14:44:52] Multiplexing M2TS - [14:44:55] Processing: VID_00142 (44 of 99) - [14:44:55] Extracting A/V streams [VID_00142] - [14:44:59] Reencoding video [VID_00142] - [14:44:59] Keeping original video (no reencode) - [14:44:59] Processing audio tracks - [14:44:59] Multiplexing M2TS - [14:45:03] Processing: VID_00143 (45 of 99) - [14:45:03] Extracting A/V streams [VID_00143] - [14:45:06] Reencoding video [VID_00143] - [14:45:06] Keeping original video (no reencode) - [14:45:06] Processing audio tracks - [14:45:06] Multiplexing M2TS - [14:45:10] Processing: VID_00144 (46 of 99) - [14:45:10] Extracting A/V streams [VID_00144] - [14:45:14] Reencoding video [VID_00144] - [14:45:14] Keeping original video (no reencode) - [14:45:14] Processing audio tracks - [14:45:14] Multiplexing M2TS - [14:45:17] Processing: VID_00145 (47 of 99) - [14:45:17] Extracting A/V streams [VID_00145] - [14:45:21] Reencoding video [VID_00145] - [14:45:21] Keeping original video (no reencode) - [14:45:21] Processing audio tracks - [14:45:21] Multiplexing M2TS - [14:45:25] Processing: VID_00146 (48 of 99) - [14:45:25] Extracting A/V streams [VID_00146] - [14:45:28] Reencoding video [VID_00146] - [14:45:28] Keeping original video (no reencode) - [14:45:28] Processing audio tracks - [14:45:28] Multiplexing M2TS - [14:45:32] Processing: VID_00147 (49 of 99) - [14:45:32] Extracting A/V streams [VID_00147] - [14:45:36] Reencoding video [VID_00147] - [14:45:36] Keeping original video (no reencode) - [14:45:36] Processing audio tracks - [14:45:36] Multiplexing M2TS - [14:45:39] Processing: VID_00300 (50 of 99) - [14:45:39] Extracting A/V streams [VID_00300] - [14:45:43] Reencoding video [VID_00300] - [14:45:43] Keeping original video (no reencode) - [14:45:43] Processing audio tracks - [14:45:43] Multiplexing M2TS - [14:45:47] Processing: VID_00301 (51 of 99) - [14:45:47] Extracting A/V streams [VID_00301] - [14:45:50] Reencoding video [VID_00301] - [14:45:50] Keeping original video (no reencode) - [14:45:51] Processing audio tracks - [14:45:51] Multiplexing M2TS - [14:45:54] Processing: VID_00302 (52 of 99) - [14:45:54] Extracting A/V streams [VID_00302] - [14:45:58] Reencoding video [VID_00302] - [14:45:58] Keeping original video (no reencode) - [14:45:58] Processing audio tracks - [14:45:58] Multiplexing M2TS - [14:46:01] Processing: VID_00303 (53 of 99) - [14:46:01] Extracting A/V streams [VID_00303] - [14:46:05] Reencoding video [VID_00303] - [14:46:05] Keeping original video (no reencode) - [14:46:05] Processing audio tracks - [14:46:05] Multiplexing M2TS - [14:46:09] Processing: VID_00304 (54 of 99) - [14:46:09] Extracting A/V streams [VID_00304] - [14:46:12] Reencoding video [VID_00304] - [14:46:13] Keeping original video (no reencode) - [14:46:13] Processing audio tracks - [14:46:13] Multiplexing M2TS - [14:46:16] Processing: VID_00305 (55 of 99) - [14:46:16] Extracting A/V streams [VID_00305] - [14:46:20] Reencoding video [VID_00305] - [14:46:20] Keeping original video (no reencode) - [14:46:20] Processing audio tracks - [14:46:20] Multiplexing M2TS - [14:46:23] Processing: VID_00306 (56 of 99) - [14:46:23] Extracting A/V streams [VID_00306] - [14:46:27] Reencoding video [VID_00306] - [14:46:27] Keeping original video (no reencode) - [14:46:27] Processing audio tracks - [14:46:27] Multiplexing M2TS - [14:46:31] Processing: VID_00307 (57 of 99) - [14:46:31] Extracting A/V streams [VID_00307] - [14:46:34] Reencoding video [VID_00307] - [14:46:34] Keeping original video (no reencode) - [14:46:35] Processing audio tracks - [14:46:35] Multiplexing M2TS - [14:46:38] Processing: VID_00308 (58 of 99) - [14:46:38] Extracting A/V streams [VID_00308] - [14:46:42] Reencoding video [VID_00308] - [14:46:42] Keeping original video (no reencode) - [14:46:42] Processing audio tracks - [14:46:42] Multiplexing M2TS - [14:46:45] Processing: VID_00309 (59 of 99) - [14:46:45] Extracting A/V streams [VID_00309] - [14:46:49] Reencoding video [VID_00309] - [14:46:49] Keeping original video (no reencode) - [14:46:49] Processing audio tracks - [14:46:49] Multiplexing M2TS - [14:46:53] Processing: VID_00310 (60 of 99) - [14:46:53] Extracting A/V streams [VID_00310] - [14:46:56] Reencoding video [VID_00310] - [14:46:57] Keeping original video (no reencode) - [14:46:57] Processing audio tracks - [14:46:57] Multiplexing M2TS - [14:47:00] Processing: VID_00311 (61 of 99) - [14:47:00] Extracting A/V streams [VID_00311] - [14:47:04] Reencoding video [VID_00311] - [14:47:04] Keeping original video (no reencode) - [14:47:04] Processing audio tracks - [14:47:04] Multiplexing M2TS - [14:47:07] Processing: VID_00312 (62 of 99) - [14:47:07] Extracting A/V streams [VID_00312] - [14:47:11] Reencoding video [VID_00312] - [14:47:11] Keeping original video (no reencode) - [14:47:11] Processing audio tracks - [14:47:11] Multiplexing M2TS - [14:47:15] Processing: VID_00313 (63 of 99) - [14:47:15] Extracting A/V streams [VID_00313] - [14:47:18] Reencoding video [VID_00313] - [14:47:18] Keeping original video (no reencode) - [14:47:19] Processing audio tracks - [14:47:19] Multiplexing M2TS - [14:47:22] Processing: VID_00314 (64 of 99) - [14:47:22] Extracting A/V streams [VID_00314] - [14:47:26] Reencoding video [VID_00314] - [14:47:26] Keeping original video (no reencode) - [14:47:26] Processing audio tracks - [14:47:26] Multiplexing M2TS - [14:47:29] Processing: VID_00315 (65 of 99) - [14:47:29] Extracting A/V streams [VID_00315] - [14:47:33] Reencoding video [VID_00315] - [14:47:33] Keeping original video (no reencode) - [14:47:33] Processing audio tracks - [14:47:33] Multiplexing M2TS - [14:47:37] Processing: VID_00316 (66 of 99) - [14:47:37] Extracting A/V streams [VID_00316] - [14:47:41] Reencoding video [VID_00316] - [14:47:41] Keeping original video (no reencode) - [14:47:41] Processing audio tracks - [14:47:41] Multiplexing M2TS - [14:47:44] Processing: VID_00317 (67 of 99) - [14:47:44] Extracting A/V streams [VID_00317] - [14:47:48] Reencoding video [VID_00317] - [14:47:48] Keeping original video (no reencode) - [14:47:48] Processing audio tracks - [14:47:48] Multiplexing M2TS - [14:47:51] Processing: VID_00318 (68 of 99) - [14:47:51] Extracting A/V streams [VID_00318] - [14:47:55] Reencoding video [VID_00318] - [14:47:55] Keeping original video (no reencode) - [14:47:55] Processing audio tracks - [14:47:55] Multiplexing M2TS - [14:47:59] Processing: VID_00319 (69 of 99) - [14:47:59] Extracting A/V streams [VID_00319] - [14:48:03] Reencoding video [VID_00319] - [14:48:03] Keeping original video (no reencode) - [14:48:03] Processing audio tracks - [14:48:03] Multiplexing M2TS - [14:48:06] Processing: VID_00320 (70 of 99) - [14:48:06] Extracting A/V streams [VID_00320] - [14:48:10] Reencoding video [VID_00320] - [14:48:10] Keeping original video (no reencode) - [14:48:10] Processing audio tracks - [14:48:10] Multiplexing M2TS - [14:48:13] Processing: VID_00321 (71 of 99) - [14:48:13] Extracting A/V streams [VID_00321] - [14:48:17] Reencoding video [VID_00321] - [14:48:17] Keeping original video (no reencode) - [14:48:17] Processing audio tracks - [14:48:17] Multiplexing M2TS - [14:48:21] Processing: VID_00322 (72 of 99) - [14:48:21] Extracting A/V streams [VID_00322] - [14:48:25] Reencoding video [VID_00322] - [14:48:25] Keeping original video (no reencode) - [14:48:25] Processing audio tracks - [14:48:25] Multiplexing M2TS - [14:48:28] Processing: VID_00323 (73 of 99) - [14:48:28] Extracting A/V streams [VID_00323] - [14:48:32] Reencoding video [VID_00323] - [14:48:32] Keeping original video (no reencode) - [14:48:32] Processing audio tracks - [14:48:32] Multiplexing M2TS - [14:48:35] Processing: VID_00324 (74 of 99) - [14:48:35] Extracting A/V streams [VID_00324] - [14:48:39] Reencoding video [VID_00324] - [14:48:39] Keeping original video (no reencode) - [14:48:39] Processing audio tracks - [14:48:39] Multiplexing M2TS |
26th September 2018, 08:22 | #27757 | Link |
Starfish
- [14:48:43] Processing: VID_00325 (75 of 99) - [14:48:43] Extracting A/V streams [VID_00325] - [14:48:47] Reencoding video [VID_00325] - [14:48:47] Keeping original video (no reencode) - [14:48:47] Processing audio tracks - [14:48:47] Multiplexing M2TS - [14:48:50] Processing: VID_00326 (76 of 99) - [14:48:50] Extracting A/V streams [VID_00326] - [14:48:54] Reencoding video [VID_00326] - [14:48:54] Keeping original video (no reencode) - [14:48:54] Processing audio tracks - [14:48:54] Multiplexing M2TS - [14:48:57] Processing: VID_00327 (77 of 99) - [14:48:57] Extracting A/V streams [VID_00327] - [14:49:01] Reencoding video [VID_00327] - [14:49:01] Keeping original video (no reencode) - [14:49:01] Processing audio tracks - [14:49:01] Multiplexing M2TS - [14:49:05] Processing: VID_00328 (78 of 99) - [14:49:05] Extracting A/V streams [VID_00328] - [14:49:09] Reencoding video [VID_00328] - [14:49:09] Keeping original video (no reencode) - [14:49:09] Processing audio tracks - [14:49:09] Multiplexing M2TS - [14:49:12] Processing: VID_00329 (79 of 99) - [14:49:12] Extracting A/V streams [VID_00329] - [14:49:16] Reencoding video [VID_00329] - [14:49:16] Keeping original video (no reencode) - [14:49:16] Processing audio tracks - [14:49:16] Multiplexing M2TS - [14:49:19] Processing: VID_00330 (80 of 99) - [14:49:19] Extracting A/V streams [VID_00330] - [14:49:23] Reencoding video [VID_00330] - [14:49:23] Keeping original video (no reencode) - [14:49:23] Processing audio tracks - [14:49:23] Multiplexing M2TS - [14:49:27] Processing: VID_00331 (81 of 99) - [14:49:27] Extracting A/V streams [VID_00331] - [14:49:31] Reencoding video [VID_00331] - [14:49:31] Keeping original video (no reencode) - [14:49:31] Processing audio tracks - [14:49:31] Multiplexing M2TS - [14:49:34] Processing: VID_00332 (82 of 99) - [14:49:34] Extracting A/V streams [VID_00332] - [14:49:38] Reencoding video [VID_00332] - [14:49:38] Keeping original video (no reencode) - [14:49:38] Processing audio tracks - [14:49:38] Multiplexing M2TS - [14:49:41] Processing: VID_00333 (83 of 99) - [14:49:41] Extracting A/V streams [VID_00333] - [14:49:45] Reencoding video [VID_00333] - [14:49:45] Keeping original video (no reencode) - [14:49:45] Processing audio tracks - [14:49:45] Multiplexing M2TS - [14:49:49] Processing: VID_00334 (84 of 99) - [14:49:49] Extracting A/V streams [VID_00334] - [14:49:53] Reencoding video [VID_00334] - [14:49:53] Keeping original video (no reencode) - [14:49:53] Processing audio tracks - [14:49:53] Multiplexing M2TS - [14:49:56] Processing: VID_00335 (85 of 99) - [14:49:56] Extracting A/V streams [VID_00335] - [14:50:00] Reencoding video [VID_00335] - [14:50:00] Keeping original video (no reencode) - [14:50:00] Processing audio tracks - [14:50:00] Multiplexing M2TS - [14:50:04] Processing: VID_00336 (86 of 99) - [14:50:04] Extracting A/V streams [VID_00336] - [14:50:07] Reencoding video [VID_00336] - [14:50:07] Keeping original video (no reencode) - [14:50:07] Processing audio tracks - [14:50:07] Multiplexing M2TS - [14:50:11] Processing: VID_00337 (87 of 99) - [14:50:11] Extracting A/V streams [VID_00337] - [14:50:15] Reencoding video [VID_00337] - [14:50:15] Keeping original video (no reencode) - [14:50:15] Processing audio tracks - [14:50:15] Multiplexing M2TS - [14:50:18] Processing: VID_00338 (88 of 99) - [14:50:18] Extracting A/V streams [VID_00338] - [14:50:22] Reencoding video [VID_00338] - [14:50:22] Keeping original video (no reencode) - [14:50:22] Processing audio tracks - [14:50:22] Multiplexing M2TS - [14:50:26] Processing: VID_00339 (89 of 99) - [14:50:26] Extracting A/V streams [VID_00339] - [14:50:29] Reencoding video [VID_00339] - [14:50:29] Keeping original video (no reencode) - [14:50:29] Processing audio tracks - [14:50:29] Multiplexing M2TS - [14:50:33] Processing: VID_00340 (90 of 99) - [14:50:33] Extracting A/V streams [VID_00340] - [14:50:37] Reencoding video [VID_00340] - [14:50:37] Keeping original video (no reencode) - [14:50:37] Processing audio tracks - [14:50:37] Multiplexing M2TS - [14:50:40] Processing: VID_00341 (91 of 99) - [14:50:40] Extracting A/V streams [VID_00341] - [14:50:44] Reencoding video [VID_00341] - [14:50:44] Keeping original video (no reencode) - [14:50:44] Processing audio tracks - [14:50:44] Multiplexing M2TS - [14:50:48] Processing: VID_00810 (92 of 99) - [14:50:48] Extracting A/V streams [VID_00810] - [14:50:53] Reencoding video [VID_00810] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.214 frames - Bitrate: 28.750 Kbs - [14:50:53] Reencoding: VID_00810, Pass 1 of 2 - [14:51:11] Reencoding: VID_00810, Pass 2 of 2 [14:51:16]PHASE ONE aborted by user request |
26th September 2018, 08:51 | #27758 | Link |
There's nothing rude about it. Just an observation of vital missing info. I'm always direct, always have been. Don't like beating around the bush or tread super careful :-) The volume name is in fact required, how would jdobbs test things if he doesn't know what movie you're processing ;-)
No info is useless in a log, for any software. Think about it. If it was useless it wouldn't be logged in the first place right ;-)? Verstuurd vanaf mijn Nexus 6P met Tapatalk Last edited by Ch3vr0n; 26th September 2018 at 08:55. |
26th September 2018, 12:02 | #27760 | Link |
jdobbs
i tried to do Avengers Infinity War UHD and at the very end i got this dont know if it helps you but hope it does
---------------------- [09 21 18] BD Rebuilder v0.60.01 [14:03:52] Source: AVENGERS_INFINITY_WAR_00004 - Input BD size: 60.76 GB - Approximate total content: [02:29:21.952] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:03:52] PHASE ONE, Encoding - [14:03:52] Processing: VID_00042 (1 of 1) - [14:03:52] Extracting A/V streams [VID_00042] - [14:17:42] Reencoding video [VID_00042] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 214,872 frames - Bitrate: 33,502 Kbs - [14:17:42] Reencoding: VID_00042, Pass 1 of 1 - [15:44:18] Video Encode complete - [15:44:18] Processing audio tracks - Track 4352 (eng): Keeping original audio [15:44:18]PHASE ONE complete [15:44:18]PHASE TWO - Rebuild Started - [15:44:18] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information. [15:55:51] - Failed to REBUILD ---------------------- [09 23 18] BD Rebuilder v0.60.01 [16:20:47] Source: AVENGERS_INFINITY_WAR_00004 - Input BD size: 60.76 GB - Approximate total content: [02:29:21.952] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [16:20:51] PHASE ONE, Encoding [16:20:51]PHASE ONE complete [16:20:51]PHASE TWO - Rebuild Started - [16:20:51] Rebuilding BD file Structure [16:21:02] - Aborted per user request ---------------------- [09 23 18] BD Rebuilder v0.60.01 [16:21:28] Source: AVENGERS_INFINITY_WAR_00004 - Input BD size: 60.76 GB - Approximate total content: [02:29:21.952] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [16:21:39] PHASE ONE, Encoding [16:21:39]PHASE ONE complete [16:21:39]PHASE TWO - Rebuild Started - [16:21:39] Rebuilding BD file Structure [16:22:00] - Aborted per user request ---------------------- [09 23 18] BD Rebuilder v0.60.01 [16:22:13] Source: AVENGERS_INFINITY_WAR_00004 - Input BD size: 60.76 GB - Approximate total content: [02:29:21.952] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [16:22:14] PHASE ONE, Encoding [16:22:14]PHASE ONE complete [16:22:14]PHASE TWO - Rebuild Started - [16:22:14] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Bitstream exception Unknown exception. It does not have to be! Please contact application support team for more information. [16:33:08] - Failed to REBUILD |
