Old 26th January 2018, 23:12   #241  |  Link
ErichV
Originally Posted by nalor View Post
Found the bug - introduced an endless loop when parsing a keydb.cfg file with multi-line entries ...
Will be fixed in next release (hopefully ready this evening)
ErichV is offline   Reply With Quote
Old 27th January 2018, 11:03   #242  |  Link
candela
CloseAtTheEnd (after pressing Esc to quit Findvuk) doesn't seem to work in 1.05 (only tried with mediaplayer) . It doesn't even try so it seems to ignore the parameter. It works with 1.02
Also how can the database detect the "VUKNOTVAL" in case of busencryption , there's a comment attribute for the keys or separate comment tag?
Same question for manual title entry in case no meta title
candela is offline   Reply With Quote
Old 28th January 2018, 15:47   #243  |  Link
nalor
Uploaded new Release 1.06 - please test and report your findings
; feature: new mode 'KeyDB_ListDuplicates' to show duplicates in specified keydb.cfg
; change: HashValues are not uppercase in MetaXML
; fix: get disc size with GetDiskFreeSpaceEx instead of 'READ CAPACITY' (produces different results for original disc or iso in virtual drive)
; change: enabled to write all possible kinds of values to keydb.cfg
; fix: do not generally write _DebugDifference entries to log (only in case DEBUG loglevel is set)
; change: delete existing entries from main/backup keydb.cfg file (and add them to a 'deletedlines' file for safety)
; fix: endless loop when parsing a keydb.cfg file with multi-line entries
; fix: take UnitKeys into account when deciding if a new/changed entry should be written to keydb.cfg
; 1.06 release - 20180128
hopefully it's better than the previous release
nalor is offline   Reply With Quote
Old 28th January 2018, 15:53   #244  |  Link
nalor
Only validated entries are uploaded - in case of VUKNOTVAL there's no upload.
For manual title there's an additional attribute present in the 'MetaTitle' node named Manual=1 and the specified language is the preferred one as defined in the ini file.
Old 28th January 2018, 15:56   #245  |  Link
nalor
And I changed the keydb.cfg available on my temp-online-db site to the last one posted from Relight.
(but please backup your local keydb.cfg before testing the synchronization ... just to be on the safe side )
Old 28th January 2018, 23:19   #246  |  Link
candela
I think there's something wrong
23:10:59 - Disc with ID >B2E1058AAB619B748278A03655D9E52AF4FFE44F< is already >2< times in the keydb-file
23:10:59 - -------------------------------------------------------
23:10:59 - KEYDB: Nearly identical entry already present in keydb-file (line 78585)
23:10:59 -  >> Identical:  TITLE, VUK, COMMENT - Different:  DATE, MEDIAKEY, VOLUMEID, UNITKEYS >> write new entry in keydb-file
23:10:59 - KEYDB: entry for this disc already present in keydb-file (line 54947)
23:10:59 -  >> but VUK is NOT identical!!
23:10:59 -  >> The new VUK has been successfully validated, please report in the forum (http://forum.doom9.org/showthread.php?t=171298) that the old entry is definitely wrong!
23:10:59 - Final decision: write new entry
23:10:59 - There are >2< existing entries for DiscID >B2E1058AAB619B748278A03655D9E52AF4FFE44F< - remove them now
23:11:03 - Added line with VUK to file >C:\Users\\AppData\Roaming\aacs\KEYDB.cfg<
Old Lines
; Backup of deleted lines - DiscId >B2E1058AAB619B748278A03655D9E52AF4FFE44F< Date >2018.01.28 23:11:03<
0xB2E1058AAB619B748278A03655D9E52AF4FFE44F = GILDA [Gilda] | U | 1-0xD60D3E7B884C9F1B74870CE533E2E792 | I | 0x425E11297AF4A9960BD2B193B18AE61A ;
0xB2E1058AAB619B748278A03655D9E52AF4FFE44F = GILDA (Gilda) | V | 0x31767D2FA2228037F7DB30EC7C1F7A5C ; MKBv57/FindVUK 1.05
New line
0xB2E1058AAB619B748278A03655D9E52AF4FFE44F = GILDA (Gilda) | D | 2015-11-05 | V | 0x31767D2FA2228037F7DB30EC7C1F7A5C | M | 0x4C06290CC1A2C974BD9A7B1D5FF7099B | I | 0x425E11297AF4A9960BD2B193B18AE61A | U | 1-0xD60D3E7B884C9F1B74870CE533E2E792 ; MKBv57/FindVUK 1.06
Don't know why it detected a "wrong" VUK
Old 28th January 2018, 23:24   #247  |  Link
candela
Also upload still fails when I try to do a second disc without closing FindVUK first (writing to keydb seems to work now)
23:22:22 - ERROR! Couldn't post the BlurayMetaXML to the OnlineDB! (http://fvonline-db.bplaced.net/fv_upload.php) >< (0)
Old 28th January 2018, 23:42   #248  |  Link
nalor
Because there's no VUK present in the first entry ... so it compared an 'empty' VUK against an existing and noticed it's different ... I think I will change the message in case there's no VUK available.
Old 28th January 2018, 23:43   #249  |  Link
nalor
Will check tomorrow.
Old 29th January 2018, 11:48   #250  |  Link
nalor
Fixed both issues in 1.07
Old 2nd February 2018, 21:06   #251  |  Link
BRC85sYrg
wonderful program, I find it very useful.
thanks nalor for your hard work.
I know VUK validation if BEE is present is not yet implemented.
But is this also interconnected with unit keys not being written to the keydb file if BEE is detected?
BRC85sYrg is offline   Reply With Quote
Old 3rd February 2018, 17:38   #252  |  Link
nalor
I think you are right, will change it with the next release.
Unit keys are decoded during the validation at the moment.
Gesendet von meinem E5823 mit Tapatalk
Old 5th February 2018, 20:25   #253  |  Link
BRC85sYrg
thank you for looking into it.
some suggestions for the next release:
- BD+ with its generation number in the KEYDB comment section (like "BD+v1")
- "VOLUME_ID" as an additional MeaninglessVolumeName in the config file
another bug report:
- FindVUK 1.07 detected a disc with a BD+ generation of 254. Passkey reports the following: "BD+ protection (Irdeto) is removed. (gen21)"
(FindVUK log: "BD+ : 1 - Date 2015.12.22 / Gen 254")
Old 5th February 2018, 20:44   #254  |  Link
candela
another bug report:
I don't think the BD+ generation should be added. As far as I can tell, there is isn't such thing as an official "BD+ generation" or version number. In Videolan's libbdplus code, you can see the initial version numbers were simply based on supposed release dates when some new BD+ behaviour first appeared. I think DVDFab kept adding a nr whenever they had to update their BDplus code. It's better to simply look at the date of the DiscID file, which is already being extrated by FindVUK. This is similar to what MakeMKV shows in it's UI (YEAR.MONTH) for BD+.
And as far as bugs, CloseAtTheEnd still doesn't work
PS: any discs you own with BD+, please load them in Pavtube at least once
Old 5th February 2018, 21:27   #255  |  Link
nalor
I've used 2 different sources to define the first BD+ generations:
http://forum.dvdfab.cn/showthread.php?t=5175
and the libbdplus source - and beginning with date 2013.07.01 it's returned as gen254 just because I cannot find anything 'official' about this.
Old 5th February 2018, 21:40   #256  |  Link
BRC85sYrg
big thanks for clarifying this
Old 5th February 2018, 22:32   #257  |  Link
nalor
Just noticed that even the Windows API command GetDiskFreeSpaceEx returns different volume size results for an ISO in a virtual drive or the original disc in a physical drive.
Need to think about it....
Old 5th February 2018, 23:01   #258  |  Link
BRC85sYrg
could you explain why this should be done?
Old 6th February 2018, 18:58   #259  |  Link
candela
Shouldn't you simply discard data from a virtual drive? Or you cannot detect it's virtual? All the other FindVUK data cannot be verified/trusted either if it's not the original disc
so later we can make a database of BD+ tables, similar to keydb.cfg for keys. The ultimate goal will be real-time playback of BD+ protected titles using VLC. We just need to find a decent C programmer to update Videolan's libbdplus to load these tables
Old 6th February 2018, 21:28   #260  |  Link
nalor
Just released 1.08 - fixes the Problem with CloseOnExit, decrypts the UnitKeys earlier so they are written to keydb.cfg even in case the VUK cannot be validated and fixes a stupid bug I noticed when I checked the MetaXML files I've uploaded into the online-db: in case a few discs are uploaded one after the other, the 2nd disc includes 2 hashed, the 3rd disc 3 of them ... and so on. never cleared the previous hash values in 1.07
And on my notebook didn't detect mediaplayer properly - enhanced the detection.
But another strange thing: MediaPlayer 3.2.0.0 is working without problems on my main computer - but does not include the VUK on my notebook. Had to downgrade to 3.1.0.0 to get it work there ...
