16th March 2013, 08:34 | #741 | Link | |
unsigned int
fade_input = # your source here blank = core.std.BlankClip(clip=fade_input, length=1, color=[255, 128, 128]) # assumes you're working with 8 bit YUV fade_frames = [] for i in range(fade_input.num_frames): fade_frames.append(core.std.Merge(clips=[fade_input[i], blank], weight=i/(fade_input.num_frames-1))) fade_output = core.std.Splice(clips=fade_frames) Tweak the parameters of range() to make it fade /in/, rather than out (make it count backwards). Replace blank with some other clip, say fade_input2[i], to make it fade from one scene to another. ~~~~~ I don't know what "dissolve" should look like.
Buy me a "coffee" and/or hire me to write code! |
28th April 2013, 20:14 | #743 | Link |
Hi @all,
is it happening further development of Vapoursynth in the background?. I read in Vapoursynth project page that Myrsloik had a new job (sort of?) and development would slow down. That was published in the beginning of March. Was just Myrsloik developing Vapoursynth?. It would be sad, since this project looks really promising, specially for those of us living in the Linux world, and missing avisynth natively. I wish I could be of a help, but I'm in the "Hello world!" phase of Python... I just can help testing. |
28th April 2013, 20:18 | #744 | Link |
Professional Code Monkey
I've only written a few more lines of code since the last post. It's not dead but I spend all day programming other things... for money. It's actually not that much more code needed to make the core part complete so it'll definitely happen some day.
Also, real life takes time.
28th April 2013, 21:42 | #745 | Link | ||
I really admire, respect and thank the time programmers like you and many others in this site spend creating projects and sharing them with everybody. |
1st May 2013, 21:42 | #746 | Link |
Fighting spam with a fish
@digitall.h
Is there something missing from Vapoursynth that you'd like to see? I ask because you speak of the project being promising, which just sounds to me personally like it's missing something you want. And I'm totally with you on the Linux support. I do all of my Vapoursynth development and usage on Linux. |
1st May 2013, 22:07 | #747 | Link |
Yes:
-native QTGMC or at least yadifmod -better "support" for interlaced video -better source filters (ffms2, avisource still have problems) -8bit+ support for core filters- like deinterlacing, etc -frame prefetching support for avs filters -many more Example of great vapoursynth filter implementation is fmtconv from Cretindesalpes. Last edited by kolak; 1st May 2013 at 22:09. |
1st May 2013, 22:24 | #748 | Link |
Pajas Mentales...
in my knowledge: (a mode of information)
cross plataform plugins: convo2d d2vsource ffms2 fmtconv genericfilters histogram lsmashsource nnedi3 scenechange scxvid temporalsoften vsimagereader vsrawsource windows plugins: VS_AvsReader (work with avisynth plugins) vscolormatrix (?) (don't build on my linux) mixed plugins (use avisynth plugins to work) havsfunc Last edited by sl1pkn07; 1st May 2013 at 23:08. |
1st May 2013, 22:28 | #749 | Link |
I suppose I should have been a bit more clear, as I ment develop to the actual Vapoursynth project.
Almost everything that you have listed can be done in a plugin or script format for Vapoursynth's use, which can be done by any willing developer, not just Myrsloik. The biggest hurdle for QTGMC at this point is the MC part. I know that Myrsloik wanted to look into a new version of MVTools for Vapoursynth, but that is a large task. Currently all of the core filters support 8/9/10/16 bit video (with some even supporting float). But I agree, lack of a proper deinterlacer is a bit of a problem. As for the "better source filters", what problems do you have with FFMS2? I've used it in numerous tests before and I've had no problems. |
1st May 2013, 22:42 | #750 | Link |
Except fmtconv and some source filters I don't think anything else supports 8bit+.
Avisource has speed problem (not a big deal for now), ffms2- well it sort of works, but far from being reliable. There is no official build, some random builds etc. I think vapoursynth needs reliable and well written source filter, as without it rest of the engine can't be used properly. I know Myrsloik is busy, which is shame, but he needs real life and money |
7th May 2013, 17:15 | #751 | Link |
soy sauce buyer
Myrsloik, I met some strange results from Lut and Expr for YUV420P16.
I used a simple script to reproduce it: PHP Code:
PHP Code:
Some other filters which support YUV420P16 like generic.Blur gives expected results, so I suppose something went wrong in Lut and Expr, or in my script. Naturally, Expr(clip, '') works as it should, so does specifying planes[] to preserve data in certain planes. Using a const in expression like lut.append(32768) or Expr(clip, '32768') also works well. Did I make any mistakes, or do these two functions need special workaround like re-order bytes, or is there any regression in the filters? Env: Win Server 2012 Datacenter (x64) python 3.3 win32 vapoursynth r18 Any video, any source filter, any resizer for 8->16 conversion, and any other pre-filters, as long as the input clip for Lut/Expr is YUV420P16. Viewed by vfw dithered by fmtc.bitdepth, or encoded by FFmpeg/x264 with y4m or raw with specified format/input-depth/csp, or raw yuv generated by clip.output() function. Didn't test other csps, as I'm still using masktools for 8-bit stuffs :P Last edited by 06_taro; 7th May 2013 at 17:33. |
8th May 2013, 01:56 | #752 | Link | |
Hmm, good spot, 06_taro.
Just looking at the code, with no testing done what so ever, it may be due to the fact that the srcp pointer is not being cast to uint16_t when being read in LUT. Ex: Code:
((uint16_t *)dstp)[x] = lut[srcp[x]]; Code:
((uint16_t *)dstp)[x] = lut[((const uint16_t *)srcp)[x]]; It might be good to add a regression test in the Python tests, just for good maintenance sake. Hell, I can write one when I get home. Edit: Looks like the same issue exists in LUT2: Quote:
8th May 2013, 07:29 | #753 | Link |
Here's a patch to simplefilters.c which should fix LUT and LUT2
diff --git a/src/core/simplefilters.c b/src/core/simplefilters.c index 9ea2a97..738c337 100644 --- a/src/core/simplefilters.c +++ b/src/core/simplefilters.c @@ -1885,7 +1885,7 @@ static const VSFrameRef *VS_CC lutGetframe(int n, int activationReason, void **i for (hl = 0; hl < h; hl++) { for (x = 0; x < w; x++) - ((uint16_t *)dstp)[x] = lut[srcp[x]]; + ((uint16_t *)dstp)[x] = lut[((uint16_t *)srcp)[x]]; dstp += dst_stride; srcp += src_stride; @@ -2052,7 +2052,7 @@ static const VSFrameRef *VS_CC lut2Getframe(int n, int activationReason, void ** for (hl = 0; hl < h; hl++) { for (x = 0; x < w; x++) - ((uint16_t *)dstp)[x] = lut[(srcpy[x] << shift) + srcpx[x]]; + ((uint16_t *)dstp)[x] = lut[(((uint16_t *)srcpy)[x] << shift) + ((uint16_t *)srcpx)[x]]; dstp += dst_stride; srcpx += src_stride; Code:
import unittest import vapoursynth as vs class RegressionTestSequence(unittest.TestCase): def setUp(self): self.core = vs.Core() def checkDifference(self, cpu, gpu): diff = self.core.std.PlaneDifference([cpu, gpu], 0, prop="PlaneDifference0") diff = self.core.std.PlaneDifference([diff, gpu], 1, prop="PlaneDifference1") diff = self.core.std.PlaneDifference([diff, gpu], 2, prop="PlaneDifference2") for i in range(diff.num_frames): frame = diff.get_frame(i) self.assertEqual(frame.props.PlaneDifference0[0], 0) self.assertEqual(frame.props.PlaneDifference1[0], 0) self.assertEqual(frame.props.PlaneDifference2[0], 0) def testLUT16Bit(self): clip = self.core.std.BlankClip(format=vs.YUV420P16, color=[69, 242, 115]) lut = [] for x in range(2 ** clip.format.bits_per_sample): lut.append(x) ret = self.core.std.Lut(clip, lut, [0, 1, 2]) self.checkDifference(clip, ret) if __name__ == '__main__': unittest.main() |
8th May 2013, 13:35 | #755 | Link | |
Here's what I tried to get Vapoursynth working in my Linux Mint 64bit 13.04 (inside a Virtualbox) working:
1. Installing a bunch of dependencies. Code:
sudo apt-get install build-essential libqtcore4 python3 python3-dev wget subversion yasm libswscale-dev libavcodec-dev libass-dev autoconf libavformat-dev mplayer Code:
sudo python3 setup.py install 3.1 checkout [code]svn checkout http://vapoursynth.googlecode.com/svn/trunk vapoursynth cd vapoursynth 3.2 fixing typo in include/VSScript.h: Code:
#include "vapoursynth.h" Code:
#include "VapourSynth.h" Code:
./bootstrap.py && ./waf configure && ./waf build && sudo ./waf install sudo ./setup.py install sudo ldconfig 5. checking out and building ffms2 Code:
svn checkout http://ffmpegsource.googlecode.com/svn/trunk ffms2 cd ffms2 ./autogen.sh ./configure --enable-shared make Code:
#!/usr/bin/python3 import vapoursynth as vs import sys core = vs.Core() core.std.LoadPlugin("/usr/local/lib/libffms2.so") ret = core.ffms2.Source("/home/selur/Desktop/test.avi") ret.output(sys.stdout, y4m=True) Code:
chmod +x vstestscrpt.vpy Code:
$ ./vstestscript.vpy | mplayer Quote:
Cu Selur |
8th May 2013, 14:07 | #758 | Link |
Pajas Mentales...
for Archlinux users: https://aur.archlinux.org/packages/?O=0&K=vapoursynth
one little question, cpython is dependency for run or only for build? greetings Last edited by sl1pkn07; 8th May 2013 at 14:12. |
8th May 2013, 14:39 | #759 | Link |
Nooooooooooooooob
can i use avisynth runtime functions in a vapoursynth script? i.e., can i let core.avs.IsCombedTIVTC() work in vapoursynth, either using it in core.std.SelectClip(), or just return a boolean list, or do anything else?
if can't, what else could be used to replace IsCombedTIVTC for above usage? |
8th May 2013, 21:16 | #760 | Link |
@Selur,
Just a heads up, Mplayer/MPV might prefer that you disable the "y4m" setting on output, as setting it to true outputs an extended Y4M format that requires specific support by the reader, such as X264. Setting y4m=False still outputs standard y4m, and should be quite compatible with any command line player. |
speed, vaporware, vapoursynth |
