Old 14th August 2019, 16:14   #28721  |  Link
cartman0208
BTW, if you still have a Dolby Vision job on your hard drive that oversized, just rebuilding with this new version may get it to within your target.
Aww ... I should have read that this morning, before I restarted the 51GB Encode
BTW: Don't worry about diskspace on the server, there's like 13TB free
cartman0208 is offline   Reply With Quote
Old 14th August 2019, 17:49   #28722  |  Link
jdobbs
Great! I probably won't need more than 12TB! (ok... kidding). Thanks again.
Website: www.jdobbs.net
Old 14th August 2019, 18:35   #28723  |  Link
inge70
Originally Posted by Ch3vr0n View Post
I literally posted that 3 posts above yours. Reading helps The "Wrong version" is normal. jdobbs forgot to update the "inspect" hashes it relies on to report ok or wrong version. It'll get fixed in the next update
shit, I've read over
With version 0.60.23 "inspect" fits again and outputs correct values.
@jdobbs,
Thanks for great work
inge70 is offline   Reply With Quote
Old 14th August 2019, 19:31   #28724  |  Link
Ch3vr0n
12TB is nothin. I'm sitting on 36.5 TB. Yeah, not a typo.
Here's my plex streamer / gamer / video processing rig specs
Summary
		Operating System
			Windows 10 Pro 64-bit
		CPU
			Intel Core i9 @ 3.60GHz	40 °C
			Kaby Lake 14nm Technology
		RAM
			16,0GB
		Motherboard
			ASUSTeK COMPUTER INC. ROG MAXIMUS XI FORMULA (LGA1151)	37 °C
		Graphics
			ASUS VG278HR (1920x1080@60Hz)
			ASUS VK278 (1920x1080@60Hz)
			4095MB NVIDIA GeForce GTX 1080 (ASUStek Computer Inc)	54 °C
		Storage
			9314GB Hitachi HGST HDN721010ALE604 (SATA )	37 °C
			9314GB Hitachi HGST HUH721010ALN600 (SATA )	35 °C
			9314GB Hitachi HGST HUH721010ALN600 (SATA )	41 °C
			3726GB Hitachi HGST HDS724040ALE640 (SATA )	47 °C
			476GB Samsung SSD 960 PRO 512GB (Unknown (SSD))
			1863GB Samsung SSD 970 EVO 2TB (Unknown (SSD))
		Optical Drives
			HL-DT-ST BD-RE BH16NS40
			HL-DT-ST DVDRAM GH20NS10
			HL-DT-ST BD-RE BH10LS30
Sitting in (classic) CoolerMaster Cosmos II case with custom airbrush and lots of RGB
Oh and @jdobbs did you include your bdrebuilder.ini settings file? Some of my audio encoding were undone (keep hd audio), frameserver switched from DGDecNV to DSS, all subtitles enabled, remove workfiles and output folder undone, keep only bdmv undone, beep removed. And i've also lost the switches to enable blanking mode. Luckily i had and old folder of bdrb still lying around in recycle bin, so just copied it over
Ch3vr0n is offline   Reply With Quote
Old 14th August 2019, 21:18   #28725  |  Link
cartman0208
Well ... it's whats FREE on my rackmounted Synology in the datacenter
No need for a big CPU or GPU there because I urge everyone who is "plexing" to use direct play
That i9 would be a nice upgrade for the encoding box, but I would need a new board, probably new RAM ... nah ...
Next big expense will be a bigger TV and I'll wait for my company to sort out the 28core Xeons which incidentally fit on my mainboard
@jdobbs:
the colorspace in Mortal Engine's extras seems to be different (ITU-R BT.2020 encoded vs. ITU-R BT.709 original)
Or is this some side effect of the dolby vision stuff?
Main movie seems fine.
Old 14th August 2019, 23:27   #28726  |  Link
Michi
You may want to try rerunning that job with the new version. With the disc upon which I got that error, the issue went away with the BD-RB update to X265.
With 60.23 the same error.
Michi is offline   Reply With Quote
Old 15th August 2019, 16:18   #28727  |  Link
Michi
Reencoding and muxing of the main file of the Dolby Vision Disk Cold Pursuit, but muxing error on a other file from this disc:
[08.15.19] BD Rebuilder v0.60.23
[13:13:42] Source:  COLD_PURSUIT
  - Input BD size: 78,62 GB
  - Approximate total content: [02:04:46.291]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: Good (Fastest, BD-25+), ABR
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[13:13:46] PHASE ONE, Encoding
 - [13:13:46] Processing: VID_00000 (1 of 14)
 - [13:13:46] Extracting A/V streams [VID_00000]
 - [13:13:51] Reencoding video [VID_00000]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 24,000fps, 1.046 frames
   - Bitrate: 24.020 Kbs
 - [13:13:51] Reencoding: VID_00000, Pass 1 of 1
 - [13:14:48] Video Encode complete
 - [13:14:48] Processing audio tracks
   - Track 4356 (deu): Keeping original audio
 - [13:14:48] Multiplexing M2TS
 - [13:14:56] Processing: VID_00001 (2 of 14)
 - [13:14:56] Extracting A/V streams [VID_00001]
 - [13:15:00] Reencoding video [VID_00001]
   - Rate/Length: 24,000fps, 631 frames
   - Bitrate: 9.355 Kbs
 - [13:15:00] Reencoding: VID_00001, Pass 1 of 1
 - [13:15:34] Video Encode complete
 - [13:15:34] Processing audio tracks
 - [13:15:34] Multiplexing M2TS
 - [13:15:38] Processing: VID_00002 (3 of 14)
 - [13:15:38] Extracting A/V streams [VID_00002]
 - [13:16:01] Reencoding video [VID_00002]
   - Rate/Length: 24,000fps, 8.582 frames
   - Bitrate: 35.000 Kbs
 - [13:16:01] Reencoding: VID_00002, Pass 1 of 1
 - [13:23:55] Video Encode complete
 - [13:23:55] Processing audio tracks
 - [13:23:55] Multiplexing M2TS
 - [13:24:52] Processing: VID_00003 (4 of 14)
 - [13:24:52] Extracting A/V streams [VID_00003]
 - [13:24:56] Reencoding video [VID_00003]
   - Rate/Length: 24,000fps, 211 frames
 - [13:24:56] Reencoding: VID_00003, Pass 1 of 1
 - [13:25:08] Video Encode complete
 - [13:25:08] Processing audio tracks
 - [13:25:08] Multiplexing M2TS
 - [13:25:13] Processing: VID_00008 (5 of 14)
 - [13:25:13] Extracting A/V streams [VID_00008]
   - Extracting video streams [VID_00008]
   - Extracting secondary video [VID_00008]
   - Extracting audio/subtitle streams [VID_00008]
 - [13:43:38] Reencoding video [VID_00008]
   - Rate/Length: 24,000fps, 160.215 frames
 - [13:43:38] Reencoding: VID_00008, Pass 1 of 1
 - [16:54:38] Video Encode complete
 - [16:54:38] Processing audio tracks
 - [16:54:38] Multiplexing M2TS
 - [17:11:11] Processing: VID_00020 (6 of 14)
 - [17:11:11] Extracting A/V streams [VID_00020]
 - [17:11:14] Reencoding video [VID_00020]
   - Rate/Length: 24,000fps, 240 frames
   - Bitrate: 1.489 Kbs
 - [17:11:14] Reencoding: VID_00020, Pass 1 of 1
 - [17:11:29] Video Encode complete
 - [17:11:29] Processing audio tracks
 - [17:11:29] Multiplexing M2TS
 - [17:11:33] Processing: VID_00021 (7 of 14)
 - [17:11:33] Extracting A/V streams [VID_00021]
 - [17:11:37] Reencoding video [VID_00021]
   - Rate/Length: 24,000fps, 167 frames
   - Bitrate: 1.244 Kbs
 - [17:11:37] Reencoding: VID_00021, Pass 1 of 1
 - [17:11:47] Video Encode complete
 - [17:11:47] Processing audio tracks
 - [17:11:47] Multiplexing M2TS
 - [17:11:52] Processing: VID_00022 (8 of 14)
 - [17:11:52] Extracting A/V streams [VID_00022]
 - [17:11:55] Reencoding video [VID_00022]
   - Rate/Length: 24,000fps, 168 frames
   - Bitrate: 1.339 Kbs
 - [17:11:55] Reencoding: VID_00022, Pass 1 of 1
 - [17:12:05] Video Encode complete
 - [17:12:05] Processing audio tracks
 - [17:12:05] Multiplexing M2TS
 - [17:12:11] Processing: VID_00025 (9 of 14)
 - [17:12:11] Extracting A/V streams [VID_00025]
 - [17:12:14] Reencoding video [VID_00025]
   - Rate/Length: 24,000fps, 120 frames
   - Bitrate: 791 Kbs
 - [17:12:14] Reencoding: VID_00025, Pass 1 of 1
 - [17:12:22] Video Encode complete
 - [17:12:22] Processing audio tracks
 - [17:12:22] Multiplexing M2TS
 - [17:12:30] UHD_Correct_M2TS() 00005  8102
[17:12:48]PHASE ONE aborted by user request
Old 15th August 2019, 19:08   #28728  |  Link
jdobbs
Summary
		Operating System
		CPU
		RAM
			16,0GB
		Motherboard
		Graphics
		Storage
		Optical Drives
Apparently I did include the INI in the zip file... although I haven't a clue how it got there. That's in a folder that should never had been executed. I'll remove it and post it again.
Old 15th August 2019, 19:11   #28729  |  Link
jdobbs
@jdobbs:
Is it 2160p? I was under the impression that's supposed to always be BT.2020.
Old 15th August 2019, 19:56   #28730  |  Link
cartman0208
Thats what VLC player shows me, when I play one of the original extra files
Old 15th August 2019, 22:14   #28731  |  Link
gonca
Can confirm that the extras on Mortal Engines are 4K BT.709, HEVC, 10 bit
There are two discs where the main features are also BT.709
gonca is offline   Reply With Quote
Old 18th August 2019, 23:25   #28732  |  Link
Michi
All reauthored und reencoded discs with BD-Rebuilder plays on Sony X800 and Sony X800M2 not complete. The film stops, before the last chapter begin.
This m2ts-files plays on PC complete.
The first picture show 15 chapter and the second only 14 chapter.
Old 19th August 2019, 09:10   #28733  |  Link
Michi
The bug is in the mpls-file. the mpls-file is shorter than the m2ts-file.
Old 23rd August 2019, 22:24   #28734  |  Link
jdobbs
I’m away from my office for the next several days. I’ll look at it when I return
Old 26th August 2019, 20:53   #28735  |  Link
SquallMX
Special SeeD
CRF mode is not working when using UHD mode, looks like its using x264 settings...
SquallMX is offline   Reply With Quote
Old 27th August 2019, 01:10   #28736  |  Link
jdobbs
I'll look at it.
Old 27th August 2019, 19:21   #28737  |  Link
Ch3vr0n
Hey @jdobbs, their may be hope for your software and any other wanting to implement dolby vision etc
https://www.audioholics.com/audio-te...-for-consumers
literally fresh of the press today!
Old 28th August 2019, 02:26   #28738  |  Link
MrVideo
MrVideo's Avatar
Oh Boy! I just couldn't let this slide. The old their, they're and there issue. Since their is incorrect, which one should it really be?
Old 28th August 2019, 06:32   #28739  |  Link
Ch3vr0n
There
Sent from my Pixel 3 XL using Tapatalk
Old 28th August 2019, 11:58   #28740  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Their you go ;-)))
