4th May 2009, 20:21 | #2081 | Link |
Mr. Sandman
"as soon as i get home" means it will be one of the first things i will do when i get home...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 4th May 2009 at 20:30. |
4th May 2009, 23:17 | #2082 | Link | |
And yes, I could have searched through the forums (wasting far more time than the 5 seconds it would have taken you to answer it) but my question was a simple one and your answer should have been a polite one. I believe that this is the appropriate thread anyway, as it was something related to MeGUI updating not DGAVCDec itself. By the way, that's one long trip home... Last edited by Ryu77; 4th May 2009 at 23:22. |
5th May 2009, 03:56 | #2083 | Link |
Mr. Sandman
sorry, i didnt mean to be rude.
it's just i'm too much stressed...
5th May 2009, 16:24 | #2084 | Link |
契約者
Little bug report.
If I start MeGui -> open x264 configuration dialog -> set Const. Quality 0.1 and then switch to Const. Quantizer, I get this error: UPD: the same when I click on Lossless checkbox instead of swithing to Const. Quantizer. Last edited by Keiyakusha; 5th May 2009 at 16:41. |
7th May 2009, 02:55 | #2088 | Link |
I have created a custom x264 profile (2-Pass) in MeGUI. However, I would like pass 1 to be slightly different than pass 2, but every time I make changes to pass 1, save it, then fix pass 2, pass 1 gets overwritten and becomes identical to pass 2. Anyway to fix this?
7th May 2009, 07:50 | #2090 | Link |
Alright, I created 2 profiles, one for each pass. I'm assuming you have to overwrite the --output NUL statement for pass 1, so that you actually have an output, which you have to set up as your input for the 2nd pass?
You'd think there'd be an easier way to have different settings for each pass...hopefully the MeGUI developers will design a way to do this in a later revision. |
7th May 2009, 10:41 | #2091 | Link |
You don't need to store the output of pass 1. The input of pass 2 is the same as it was for pass 1. It is the stats file which stores the information needed for pass 2.
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
7th May 2009, 15:10 | #2092 | Link |
Ok so then I can set up pass 1 with the .avs input I have and not care about the output (job 1). Then I can setup pass 2 with the same .avs input, but this time i'll get an output and it'll automatically use the .stats file created from pass 1? Also, can I queue pass 1 and pass 2 at the same time, or do I have to wait for pass 1 to complete, before I can setup & run pass 2?
11th May 2009, 07:16 | #2094 | Link |
HDConvertToX author
m2ts has an overhead of 7% (near) of total size , while avi/mkv is something like 24 bytes for frames
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
11th May 2009, 09:59 | #2095 | Link |
So if it s VC-1 stream i must calculate like this formula
Total size 1400MB - 7%MB (98MB), so total size in megui must be cca 1302MB? If it s h264 or AVC stream in mkv or m2ts the calculated file size is ok in output file xvid, avi. I have trouble only with VC-1 streams. |
12th May 2009, 01:27 | #2096 | Link |
Mr. Sandman
m2ts has simply a huge overhead and since bitrate calc still doesnt support m2ts you should take that 7% into account.
14th May 2009, 06:06 | #2097 | Link |
Weird issue: Using the same versions of MEGUI and identical x264 profiles on two different computer, I get different qualities from the same vobs I am trying to encode. AVS scripts and D2V were created in the same exact manner on the different PCs. But my old Dell 1.5ghz 1GB ram Radeon 9500 does a cleaner, better looking encode than my Q6600 2GB ram 8800gts, although the Q6600 finishes much faster than the Dell. I am a newb at encoding, so I have no clue why the quality varies between my two comps.
14th May 2009, 07:37 | #2098 | Link | |
14th May 2009, 08:40 | #2099 | Link | |
and the same decoder for playback on both machines? Which decoder for playback; deblocking en/disabled? Same bitrate, same filesizes of your encoded files? To much variables to guess without log files and avisynth scripts.... |
