1st May 2011, 16:23 | #11881 | Link |
I ran into some problems with subtitles streams.
The extracted files seemed OK, but when everything was done, when playing the file, many lines were missing, then they came back normally (not easy when the audio is Japanese). Tried the file in BDSup2Sub, only 45 lines were found instead of 343. Tried to extract the same sup file with MeGui (HD Streams extractor), and the sup file was valid with BDSup2Sub. I don't know if this will work, but I tried switching the sup file with the one I got, but it's not cool to stay by your comp to switch files before the remux. Is there a way to solve this problem ? Thanks. |
1st May 2011, 17:18 | #11882 | Link |
@Kane;
If you kept the Workfiles folder, then just rename the subtitle stream you want, or demuxed outside of BD-RB, that you believe is good, to the exact name of the one you want to replace, and replace it. Then as long as you have all the settings EXACTLY the same as your original backup, BD-RB will rebuild it again with this newly renamed subtitle stream instead of the original one it demuxed. But more important for jdobbs is the title and region of this original Blu-ray so he can determine the problem and correct it! |
1st May 2011, 17:32 | #11883 | Link |
Oh, good to know. I thought it would re-encode it again. Yay for time saving.
BTW, the blurays are Clannad After Story, Japanese versions (the problem occurs on almost every bluray). Last edited by Kane; 1st May 2011 at 17:37. |
1st May 2011, 17:37 | #11884 | Link | |
Is it happening on Blu-Ray-to-DVD transfers or blu-ray backups? Was there any resizing involved? Was this an original commercial disc? Last edited by jdobbs; 1st May 2011 at 17:41. |
1st May 2011, 17:42 | #11885 | Link |
Nope, no error at all (same for every m2ts)
- [16:52:11] Reencoding: VID_00001 (4 of 8) - [16:52:11] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 34.800 frames - Bitrate: 19.555 Kbs - [16:52:11] Reencoding: VID_00001, Pass 1 of 1 - [17:27:46] Video Encode complete - [17:27:48] Reencoding audio tracks (if req'd) - [17:27:48] Multiplexing M2TS It's a BD-25 backup, no resize, no audio re-encoding, and it's iso from commercial discs (~40 GB each) |
1st May 2011, 18:13 | #11886 | Link | |
@All Has anyone else experienced this? |
1st May 2011, 19:53 | #11887 | Link |
Though I do not usually use the subtitles, on occasion I use them when it is hard to hear or understand an actor / actress accent. On these, BD5/9 and BD-25 discs they always work perfectly. I have never experienced only some subtitles missing or not displayed. I am region A though, so maybe other regions / languages experience this.
1st May 2011, 20:05 | #11888 | Link |
Well, I think Japan is also Region A (even if those discs are region free).
And my problem only happens on English subs, Japanese were fine (even if I didn't keep them). @jdobbs, I also think it's a Tsmuxer problem, as extracting them with eac3to work flawlessly. |
2nd May 2011, 11:01 | #11889 | Link |
You may already be aware of this jdobbs, but I've confirmed that 0.37.08 is still allocating space for ripped content outside the BDMV and CERTIFICATE folders, even when the option is set to exclude this material in the rebuild.
2nd May 2011, 14:18 | #11891 | Link |
[HTML][/HTML]I have just experienced my first error in years! Same as reported by another reporter, rccland, and on the exact same movie, Die Another Day. I was remaking this BD-25 full movie backup, which I had done successfully a long time ago, but after checking my backup I discovered my Ritek BR2-00 media / disc was no longer good.
Was this error resolved for the next release? If not and you have this disc, give it a run and see what you find. [HTML]----------------------- [21:18:12] BD Rebuilder v0.37.08 (beta) - Source: DIE_ANOTHER_DAY - Input BD size: 36.90 GB - Approximate total content: [04:35:31.163] - Target BD size: 23.29 GB - Windows Version: 6.1 [7601] - SHUTDOWN at completion enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:18:12] PHASE ONE, Encoding - [21:18:12] Extracting A/V streams [VID_00028] - [21:19:06] Reencoding: VID_00028 (1 of 56) - [21:19:06] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 92,908 frames - Bitrate: 3,308 Kbs - [21:19:06] Reencoding: VID_00028, Pass 1 of 2 - [21:27:23] Reencoding: VID_00028, Pass 2 of 2 - [21:46:50] Video Encode complete - [21:46:50] Reencoding audio tracks (if req'd) - [21:46:50] Multiplexing M2TS - [21:47:39] Extracting A/V streams [VID_00029] - [21:48:02] Reencoding: VID_00029 (2 of 56) - [21:48:02] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 42,408 frames - Bitrate: 3,314 Kbs - [21:48:02] Reencoding: VID_00029, Pass 1 of 2 - [21:51:45] Reencoding: VID_00029, Pass 2 of 2 - [22:00:37] Video Encode complete - [22:00:37] Reencoding audio tracks (if req'd) - [22:00:37] Multiplexing M2TS - [22:00:46] Extracting A/V streams [VID_00030] - [22:01:09] Reencoding: VID_00030 (3 of 56) - [22:01:09] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 40,730 frames - Bitrate: 3,369 Kbs - [22:01:10] Reencoding: VID_00030, Pass 1 of 2 - [22:04:38] Reencoding: VID_00030, Pass 2 of 2 - [22:12:55] Video Encode complete - [22:12:55] Reencoding audio tracks (if req'd) - [22:12:55] Multiplexing M2TS - [22:13:04] Extracting A/V streams [VID_00031] - [22:13:08] Reencoding: VID_00031 (4 of 56) - [22:13:08] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 6,354 frames - Bitrate: 3,306 Kbs - [22:13:08] Reencoding: VID_00031, Pass 1 of 2 - [22:13:43] Reencoding: VID_00031, Pass 2 of 2 - [22:14:59] Video Encode complete - [22:14:59] Reencoding audio tracks (if req'd) - [22:14:59] Multiplexing M2TS - [22:15:01] Extracting A/V streams [VID_00032] - [22:15:14] Reencoding: VID_00032 (5 of 56) - [22:15:14] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 24,934 frames - Bitrate: 3,309 Kbs - [22:15:14] Reencoding: VID_00032, Pass 1 of 2 - [22:17:42] Reencoding: VID_00032, Pass 2 of 2 - [22:23:44] Video Encode complete - [22:23:44] Reencoding audio tracks (if req'd) - [22:23:44] Multiplexing M2TS - [22:23:49] Extracting A/V streams [VID_00034] - [22:23:55] Reencoding: VID_00034 (6 of 56) - [22:23:55] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,824 frames - Bitrate: 11,968 Kbs - [22:23:55] Reencoding: VID_00034, Pass 1 of 2 - [22:26:10] Reencoding: VID_00034, Pass 2 of 2 - [22:31:53] Video Encode complete - [22:31:53] Reencoding audio tracks (if req'd) - [22:31:53] Multiplexing M2TS - [22:31:58] Extracting A/V streams [VID_00035] - [22:32:03] Reencoding: VID_00035 (7 of 56) - [22:32:03] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,551 frames - Bitrate: 10,871 Kbs - [22:32:03] Reencoding: VID_00035, Pass 1 of 2 - [22:34:22] Reencoding: VID_00035, Pass 2 of 2 - [22:39:15] Video Encode complete - [22:39:15] Reencoding audio tracks (if req'd) - [22:39:15] Multiplexing M2TS - [22:39:18] Extracting A/V streams [VID_00130] - [22:39:50] Reencoding: VID_00130 (8 of 56) - [22:39:50] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 16,438 frames - Bitrate: 12,412 Kbs - [22:39:50] Reencoding: VID_00130, Pass 1 of 2 - [22:48:15] Reencoding: VID_00130, Pass 2 of 2 - [23:08:02] Video Encode complete - [23:08:02] Reencoding audio tracks (if req'd) - [23:08:02] Multiplexing M2TS - [23:08:43] Extracting A/V streams [VID_00131] - [23:08:46] Reencoding: VID_00131 (9 of 56) - [23:08:46] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,140 frames - Bitrate: 12,300 Kbs - [23:08:46] Reencoding: VID_00131, Pass 1 of 2 - [23:09:21] Reencoding: VID_00131, Pass 2 of 2 - [23:10:46] Video Encode complete - [23:10:46] Reencoding audio tracks (if req'd) - [23:10:46] Multiplexing M2TS - [23:10:48] Extracting A/V streams [VID_00132] - [23:10:51] Reencoding: VID_00132 (10 of 56) - [23:10:51] Collecting video information - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.37.08 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [23:10:53] - Failed video encode, aborted[/HTML] [HTML][Status] LABEL=DIE_ANOTHER_DAY VERSION=v0.37.08 (beta) SOURCE_SIZE=39618532809 SOURCE_VIDEO_SIZE=38822092800 TARGET_SIZE=25008537600 REDUCTION=.623668015934473 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=0 ENCODE_STEP=1 COMPLETED=9 [00028] AUDIO=1 PGS= HYBRID=0 M2TS_TARGET=1480636805 RATE=3308 NSTART=27000000 NEND=166500000 NSIZE=1453867008 FLINK=0 MLINK=0 [00029] AUDIO=1 PGS= HYBRID=0 M2TS_TARGET=676809879 RATE=3314 NSTART=27000000 NEND=90675360 NSIZE=664621056 FLINK=0 MLINK=0 [00030] AUDIO=1 PGS= HYBRID=0 M2TS_TARGET=660141479 RATE=3369 NSTART=27000000 NEND=88155360 NSIZE=648026112 FLINK=0 MLINK=0 [00031] AUDIO=1 PGS= HYBRID=0 M2TS_TARGET=101205932 RATE=3306 NSTART=27000000 NEND=36540000 NSIZE=98856960 FLINK=0 MLINK=0 [00032] AUDIO=1 PGS= HYBRID=0 M2TS_TARGET=397451313 RATE=3309 NSTART=27000000 NEND=64437120 NSIZE=390279168 FLINK=0 MLINK=0 [00034] AUDIO=1 PGS= M2TS_TARGET=336946934 RATE=11968 NSTART=27000000 NEND=36053280 NSIZE=327333888 FLINK=0 MLINK=0 [00035] AUDIO=1 PGS= M2TS_TARGET=283654033 RATE=10871 NSTART=27000000 NEND=35540640 NSIZE=276492288 FLINK=0 MLINK=0 [00130] AUDIO=100111 PGS=11111 M2TS_TARGET=1466639180 RATE=12412 NSTART=27000000 NEND=57852000 NSIZE=1425512448 FLINK=-1 MLINK=0 [00131] AUDIO=100111 PGS=11111 M2TS_TARGET=102439777 RATE=12300 NSTART=27000000 NEND=29139360 NSIZE=98568192 FLINK=-1 MLINK=0 [00132] AUDIO=100111 PGS=11111 M2TS_TARGET=94626703[/HTML] [HTML][Options] VERSION=0.37.0.8 MODE=0 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 QUICK_EXTRAS=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23850 TARGET_SIZE=23750 [Paths] SOURCE_PATH=I:\DIE_ANOTHER_DAY\ WORKING_PATH=G:\DIE_ANOTHER_DAY BDRB\[/HTML] |
2nd May 2011, 15:36 | #11893 | Link | |
EDIT: Just some info: If I set MIN_M2TS_SIZE=250, this VID_00132 is removed from the to be encoded list. This is a multi-m2ts movie, with three playlists. This VID_00132 is part of only one playlist. If I check the contents of this playlist with BDInfo, it shows 2 MPEG-4, AVC, 1080P clips for the several .m2ts files of this playlist. It is the same as VID_00131, but with this additional footage of how the scene was made. There are several of these double 1080P video within one m2ts file for this movie, it's just VID_00132 came up first in the to be reencoded list, causing the failure. Last edited by Capsbackup; 2nd May 2011 at 15:52. |
2nd May 2011, 16:16 | #11894 | Link | |
2nd May 2011, 17:54 | #11895 | Link |
Sorry to do that to you, but your library must be impressive!
Is there any info: playlists, clpi, etc... that I could provide that might help? The 00132.m2ts file is 144 MB. If I zip and upload the playlist and clpi, would this be of help? |
2nd May 2011, 18:10 | #11897 | Link | |
If the files mentioned above could help, and possibly avoid your purchasing this one, I would be happy to send them. Just for testing, I have added MIN_M2TS_SIZE=800, which is greater than the largest .m2ts file of this playlist, and now none of these offending m2ts files are on the reencode list. BD-RB is running now, and I will let it continue and update the results. More info: Interestingly, the total reencode time is identical with and without MIN_M2TS_SIZE=800. ( 04:35:31.163 ) The additional files in the first failed run, of which VID_00132 is the first of 16 files, are NOT included in the second test with MIN_M2TS_SIZE=800. Last edited by Capsbackup; 2nd May 2011 at 18:26. |
2nd May 2011, 19:00 | #11898 | Link | |
2nd May 2011, 19:40 | #11899 | Link | |
Here's how I determined this: I started a backup to BD25 of The Thirteenth Floor, saw that it was proceeding as normal after a minute or so, and aborted. I created a subfolder in the root of the rip, alongside BDMV and CERTIFICATE, labled "PS3 UPDATE" and just dumped a ~20GB file into it. I restarted BD-RB, pointed it to a different directory for another rip, then back to The Thirteenth Floor rip directory to make sure it rescanned it, and started the backup: it failed quickly, reporting that there wasn't enough room. |
2nd May 2011, 21:43 | #11900 | Link | ||
