Old 28th February 2013, 21:32   #1  |  Link
sumawo13
Learning Avisynth user
sumawo13's Avatar
SixLineResizer; DVD<->BD Conversion script
function slr(clip c,float par,float dar,int resx,int resy,float left,float top,float right,float bottom){
modx=isrgb(c)?1:2
mody=isrgb(c)||isyuy2(c)||isyv16(c)?1:2
lr=round((((c.height()*dar)-(c.width()*par))/2)/float(modx))*modx
tb=round(((((c.width()*par)/dar)-c.height())/2)/float(mody))*mody
c.addborders(lr,tb,lr,tb).bicubicresize(resx,resy,0,1,left,top,right,bottom)}
I'm working on a function to automate the process of converting the aspect ratio and frame size of Blu-ray material to DVD and back. I'm thinking of adding options for NNEDI and other HQ resamplers and possible even incorporating QTGMC and various IVTC filters into the function.
Right now the DAR, PAR and resolution are set directly, but I'm going to improve that with options for 'NTSC/PAL/HD720/HD1080', et cetera.
I have a lot of plans but I'm starting out small. I'd appreciate advisory on best practices, what I can do to improve my code, and any other criticism.
sumawo13 is offline   Reply With Quote
Old 16th March 2013, 06:17   #2  |  Link
Jenyok
Warm and fuzzy
There is no good way to add borders to video.
There is no good way to use any resizers, if upscaling video to 2 or more times, instead of NNEDI, NNEDI2, NNEDI3.
Maybe you will use function Panorama(...) instead of AddBorders(...) function, when converting 4:3 -> 16:9 or 16:9 -> 4:3, see web link.
http://forum.doom9.org/showthread.php?t=165911
http://forum.ixbt.com/topic.cgi?id=29:33007-9
This is a very good description of DAR, PAR, SAR with examples and pictures, see web link upper, but in Russian.
Warm and fuzzy (white and fluffy)
Jenyok is offline   Reply With Quote
Old 16th March 2013, 12:48   #3  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
also there is warpedresize() out there, which lets you specify any arbitrary warping-factor for aspect-ratio conversion.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 16th March 2013, 15:53   #4  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
Exactly. One can also try these my ugly and probably not usable functions .. --> 4:3 to 16:9 -> PanoramaWR / PanoramaWR2
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline   Reply With Quote
blu-ray, conversion, dvd, script, sixlineresizer
