1st January 2010, 22:38 | #421 | Link |
No, you are cheated by your cache, delete your cache and re-download the beta-version. The alpha-version is expired.
The Next Generation Internet Video Codec project.[/url]. |
1st January 2010, 22:43 | #422 | Link | |
Software Developer
However as soon as I update to the latest Beta (file date 2010-01-02) I get the problem described above. I switched the versions several times (also unregistred and re-registred the filter every time) and clearly the Alpha works, the Beta not I'm using MPC-HC with EVR renderer and I tested various H.264 files. They all show the same behavior... (BTW: I can record the screen output with my digicam, if you want) Code:
MD5 of DiAVC.ax (2009-12-14): b5e002c7ff8e0525bb5fd57bbe0190f4 MD5 of DiAVC.ax (2010-01-02): 96140b5a86b294584bc7fc7f23ad8486
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 1st January 2010 at 22:56. |
1st January 2010, 23:04 | #423 | Link | |
1st January 2010, 23:11 | #424 | Link | ||
Software Developer
Yes, some of the software I'm developing includes "Auto Update" features, so I sometimes have to adjust the global system to some future date for testing/debugging. I hope you won't tell me that DiAVC prohibits the user to adjust the global system time... (Note: I always sync my global system time with the Windows timeserver after I had to adjust it for testing purpose, so unless DiAVC installs some "hidden" daemon/driver that contentiously monitors the global system time, it shouldn't have seen any date after 2010-01-01 until now ^^)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 1st January 2010 at 23:13. |
1st January 2010, 23:17 | #425 | Link | |
The DiAVC is a pure ring3 application and have not any "hidden" daemon/driver that contentiously monitors the global system time, and the DiAVC have none access to internet.
The Next Generation Internet Video Codec project.[/url]. Last edited by schweinsz; 1st January 2010 at 23:31. |
1st January 2010, 23:29 | #426 | Link |
Software Developer
Wait, so DiAVC scans the Event Log for events of "future" date and will expire if it finds such entries?
Anyway, I scanned the local event history and I couldn't find any events that have a later date than 2010-01-01. Well, most likely DiAVC has more sophisticated methods to find the latest date ever configured on a system and you probably won't tell us too many details It seems that means I won't be able to use the Beta version then...
1st January 2010, 23:33 | #427 | Link | |
The Next Generation Internet Video Codec project.[/url]. Last edited by schweinsz; 1st January 2010 at 23:42. |
1st January 2010, 23:51 | #428 | Link |
Software Developer
D'oh! I indeed found a process that was started at a "future" date. Damn TortoiseSVNCache process again
Problem is resolved now, thanks BTW: Why that strange behavior when DiAVC expires? Wouldn't a message box that tells the user what is going on be more adequate? Especially if you want to motivate people to buy the full version
1st January 2010, 23:57 | #429 | Link | |
2nd January 2010, 00:10 | #430 | Link | |
4:2:0 hater
However it's slower than both ffmpeg-mt and CoreAVC. I have not tested timecodec, but in real world scenarios the CPU usage is higher and videos that are in the verge of stuttering because of not enough CPU power with those decoders do stutter with DiAVC. Last edited by STaRGaZeR; 2nd January 2010 at 00:12. |
2nd January 2010, 00:15 | #431 | Link |
I disable multi-thread for single-core old cpu and I don't know if it help or hurt the performance. You can test it using the timecodec then I can improve it. The current design of the DiAVC never drop any frames except the playbacking start and the start after a seeking. I can do some trick to improve the performance when hard.
The Next Generation Internet Video Codec project.[/url]. Last edited by schweinsz; 2nd January 2010 at 00:21. |
2nd January 2010, 01:11 | #432 | Link |
With all those protections I wonder, what protections will there be on the final version? I hope you don't add stupid things like online activation to it. The date checks are only for the beta versions and will be removed in the final (paid) version I guess? Is the anti debug code gone for good? Anything else we should know?
2nd January 2010, 01:13 | #433 | Link |
4:2:0 hater
DiAVC: User: 13s, kernel: 0s, total: 13s, real: 132s, fps: 303.4, dfps: 31.8 CoreAVC 1.9.5: User: 99s, kernel: 0s, total: 99s, real: 104s, fps: 42.3, dfps: 40.3 ffmpeg-mt, 1 thread: User: 116s, kernel: 0s, total: 117s, real: 121s, fps: 36.0, dfps: 34.6 ffmpeg-mt, 4 threads: User: 12s, kernel: 0s, total: 12s, real: 139s, fps: 343.2, dfps: 30.3 libavcodec: User: 115s, kernel: 0s, total: 115s, real: 121s, fps: 36.6, dfps: 34.8 Last edited by STaRGaZeR; 2nd January 2010 at 01:17. |
2nd January 2010, 02:16 | #435 | Link |
Latest beta works. The problem with subtitles still there.
1080p clip at L5.1 on a Core 2 Duo E8400. DiAVC beta: User: 2s, kernel: 0s, total: 2s, real: 18s, fps: 637.4, dfps: 79.7 User: 2s, kernel: 0s, total: 2s, real: 18s, fps: 604.0, dfps: 80.2 User: 2s, kernel: 0s, total: 2s, real: 18s, fps: 655.4, dfps: 79.7 CoreAVC2: User: 1s, kernel: 0s, total: 1s, real: 22s, fps: 770.1, dfps: 63.1 User: 1s, kernel: 0s, total: 1s, real: 23s, fps: 733.5, dfps: 62.7 User: 2s, kernel: 0s, total: 2s, real: 22s, fps: 655.4, dfps: 63.1 Same clip, Athlon 64 3500+. DiAVC beta: User: 2s, kernel: 0s, total: 2s, real: 56s, fps: 532.1, dfps: 25.5 User: 2s, kernel: 0s, total: 2s, real: 56s, fps: 536.0, dfps: 25.6 User: 2s, kernel: 0s, total: 2s, real: 56s, fps: 530.1, dfps: 25.6 CoreAVC2: User: 64s, kernel: 0s, total: 64s, real: 64s, fps: 22.5, dfps: 22.4 User: 64s, kernel: 0s, total: 64s, real: 64s, fps: 22.4, dfps: 22.3 User: 64s, kernel: 0s, total: 64s, real: 64s, fps: 22.4, dfps: 22.3 The real CPU usage on the Athlon is very similar to CoreAVC, I only had problems making subtitles works since DirectVobSub gets loaded before DiAVC and I only see the first frame of a video and nothing else (time moves but the video is freezed). CoreAVC works and the problem with DiAVC clears if I block DirectVobSub. On the Core 2 Duo subtitles load correctly, but there's the problem with them being delayed in respect to the video/audio. |
2nd January 2010, 02:30 | #436 | Link |
4:2:0 hater
Possible explanation of the low perfomance of DiAVC with PentiumM: http://forum.doom9.org/showpost.php?...postcount=5508
2nd January 2010, 06:41 | #437 | Link | |
2nd January 2010, 06:50 | #438 | Link | |
2nd January 2010, 19:12 | #440 | Link |
It is in plan, but currently I am working on others.
avc, diavc, fastest decoder, h.264, software |
