Old 13th July 2010, 06:52   #2061  |  Link
tormento
Acid fr0g
tormento's Avatar
My home generic use PC:
[Schermo]
Processore:		Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz (3399 MHz)
Sistema operativo:	Windows 7 Ultimate, 64-bit
Versione DirectX:	11.0
Processore GPU:		GeForce GTX 275
Versione del driver:	257.21
Nuclei CUDA:		240
Clock principale:	666 MHz
Clock ombreggiatore:	1476 MHz
Clock memoria:		1161 MHz (frequenza dei dati 2322 MHz)
Interfaccia memoria:	448 bit
Memoria grafica totale disponibile:	4095 MB
Memoria video dedicata:	896 MB GDDR3
Memoria video di sistema:	0 MB
Memoria di sistema condivisa:	3199 MB
Versione BIOS video:	62.00.60.00.01
IRQ:			16
Bus:			PCI Express x16 Gen2
My office PC:
[Schermo]
Processore:		Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz (3601 MHz)
Processore GPU:		Quadro FX 3700
Versione del driver:	258.96
Nuclei CUDA:		112
Clock principale:	675 MHz
Clock ombreggiatore:	1600 MHz
Clock memoria:		975 MHz (frequenza dei dati 1950 MHz)
Interfaccia memoria:	256 bit
Memoria grafica totale disponibile:	3323 MB
Memoria video dedicata:	512 MB GDDR3
Memoria di sistema condivisa:	2811 MB
Versione BIOS video:	62.92.16.00.04
IRQ:			24
I think I should kill the NVidia italian translator.
P.S: 258.96 works ok.
@turment on Telegram
Old 13th July 2010, 08:11   #2062  |  Link
lych_necross
ZZZzzzz...
lych_necross's Avatar
My Specs:
[Display]
Processor: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz (2133 MHz)
Operating System: Windows 7 Ultimate, 64-bit
DirectX version: 11.0
GPU processor: GeForce 9800 GTX/9800 GTX+
Driver version: 258.96
CUDA Cores: 128
Core clock: 760 MHz
Shader clock: 1890 MHz
Memory clock: 1125 MHz (2250 MHz data rate)
Memory interface: 256-bit
Total available graphics memory: 2303 MB
Dedicated video memory: 512 MB GDDR3
System video memory: 0 MB
Shared system memory: 1791 MB
Video BIOS version: 62.92.62.00.61
IRQ: 16
I might upgrade my video card soon. (I'm thinking about replacing it with the GeForce GTX 460 1GB)
lych_necross is offline   Reply With Quote
Old 13th July 2010, 08:25   #2063  |  Link
tormento
Acid fr0g
tormento's Avatar
@neuron2
Just a crazy idea. Do you think you could implement (by your internal nvidia contacts) some compatibility between DGNV and VReveal?
Nvidia is offering a free SD version and the HD is paying available.
The destination should be feeding AviSynth with stabilized video from VReveal... A dream...
Old 13th July 2010, 11:21   #2064  |  Link
Clumpco
Clumpco's Avatar
Hi Neuron 2,
Just been reading all the changes and hard work that you have been doing while I have been sunning myself on holiday. Thanks!
Using the x86 version under Windows7 I see the 'slowdown' if I leave the windows visible, if I minimise I get a 2x speed gain. Thanks for the tip/workaround.
I wonder if it isn't your progress bar that slows things down, it seems to flash a lot while indexing (indicating that the control is being redrawn rather often?) - have you tried disabling that but leaving the frames/time elapsed/remaining active?
Cheers
Clumpco is offline   Reply With Quote
Old 13th July 2010, 13:42   #2065  |  Link
Thanks for the information and suggestion. I will look into it as I now have a Win7 system.
Old 13th July 2010, 15:01   #2066  |  Link
stax76
stax76's Avatar
The latest build still crashes arbitrary opening/closing scripts in fast sequence, maybe it's just my system (GT 9400 card rather new driver). The server thing was working good. There is a new StaxRip build with some changes, removed DGSource, added DGMultiSource etc., I hope you can fix it.
http://forum.doom9.org/showthread.ph...64#post1417164
Old 13th July 2010, 15:06   #2067  |  Link
Please give me explicit instructions for making the problem happen.
Old 13th July 2010, 15:08   #2068  |  Link
stax76
stax76's Avatar
Well, maybe I found something, instead of only querying frame count etc. actually querying a image seem to help.
Old 13th July 2010, 15:14   #2069  |  Link
stax76
stax76's Avatar
That seem to help indeed, not a single crash yet and before it was almost always crashing, yesterday only sometimes. It must be some initialization problem.
Old 13th July 2010, 15:19   #2070  |  Link
I don't understand what you are talking about here.
I'll wait then for you to tell me whether to proceed on a bug hunt.
I can hold down the F2 key in VirtualDub.
Old 13th July 2010, 15:38   #2071  |  Link
stax76
stax76's Avatar
Solved I would say, it was as simple as just querying a image.
Dim a As New AVIFile
a.Open(Path)
a.GetBitmap()
Framerate = a.FrameRate
Frames = a.FrameCount
FourCC = a.FourCC
Size = a.FrameSize
ErrorMessage = a.ErrorMessage
a.Close()
Because VD always queries a image frame.
Old 13th July 2010, 18:10   #2072  |  Link
Turtleggjp
I think VirtualDub always loads the first frame immediately, which is why Stax76's loading of the first frame works better for him.
Turtleggjp is offline   Reply With Quote
Old 14th July 2010, 04:54   #2073  |  Link
Now that DGDecodeNV.dll and the CUVID Server are decomposing gracefully in their new earthy abode, will anyone go postal if I rename DGMultiSource() to just DGSource()?
Maybe I can make then synonymous so both are accepted.
Old 14th July 2010, 05:39   #2074  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Good idea. I think synonymous is the way to go. I've been through that particular headache in the past with other functions
Old 14th July 2010, 07:29   #2075  |  Link
lych_necross
ZZZzzzz...
I don't have a problem with that as long as you could make them synonymous.
Old 14th July 2010, 10:36   #2076  |  Link
mikeyakame
lookin for my sanity
Location: it all depends on the day and which country comes to mind
Here's a capture from GPU-Z, has some more detailed info.
I actually had to clock my memory down to 1250mhz, because 1300mhz was giving occasional decoder crashes over long encodes, like say a 6-8hr x264 encode.
And heres a sensor screen shot while doing a source/resize from an indexed mkv (1280x720 x264 ~2mbps bitrate) that I encoded.
This is basically the contents of the avs and running a video analysis pass in virtualdub for a filter output.
SetMTMode(0,4)
DGMultiSource("G:\temp\encoding\angel\dgi\ep01_mkv.dgi",resize_w=704,resize_h=400)
And here's a load shot using 64-bit Virtual Dub doing a video analysis pass. The indexed source is a 1080p24 M2TS from a japanese anime blu-ray that I own. If I recall average bitrate was around the 37-38mbps mark. I'm not too sure if this is a factor on video engine load though? Maybe you might know the answer to that. I know higher bitrate results in higher decode load, but not sure if it applies for frameserving or not.
Video Memory use for this 1080p source was ~230mb. It jumped from 210mb -> ~443mb.
And one final one. Vdub 64-bit + same source, but using 4 multisource inputs in the avs.
Vram usage is 210mb -> 583mb, so ~ 370mb for 4 dgi source inputs at 1920x1080. Just in case you ask "Why 4 sources!"
DGMultiSource("G:\temp\encoding\angel\dgi\bd\ep01-02.dgi").Trim(37488, 72767)
pt2 = last.Trim(2160, 32759)
pt1 = DGMultiSource("G:\temp\encoding\angel\dgi\bd\ep02_cdop.dgi").Trim(24, 2183)
pt3 = DGMultiSource("G:\temp\encoding\angel\dgi\bd\ep02_cded.dgi").Trim(24, 2183)
pt4 = DGMultiSource("G:\temp\encoding\angel\dgi\bd\ep02_web_pv.dgi").Trim(24, 383)
pt1++pt2++pt3++pt4
Basically i've just trimmed out sections and spliced in bonus feature replacements (which are extras on the blu-ray and are same frame length as original ones). Since they need to be frame exact and I needed to output merged wavs, this is easier to work with than appending multiple m2ts files into 1 index.
Thought it might be interesting for you to see, Neuron.
mikeyakame is offline   Reply With Quote
Old 14th July 2010, 12:46   #2077  |  Link
Thanks, it is indeed interesting.
Old 14th July 2010, 12:57   #2078  |  Link
It turned out to be trivial to make them synonymous.
Next question: Will anyone go ballistic if I rename the DLL?
Old 14th July 2010, 13:04   #2079  |  Link
rack04
Nope.
rack04 is offline   Reply With Quote
Old 14th July 2010, 13:53   #2080  |  Link
Audionut
Self reminder to delete old dll's from plugin dir when Don renames.
http://www.7-zip.org/
