15th December 2015, 11:54 | #3021 | Link |
Current state:
x265 1.8+167-e951ab673b1c (GCC 4.9.2) x265 1.8+167-e951ab673b1c (GCC 5.2.0) New documented 'K' frametype ("keyframe", exact type depending on circumstances), several speedups and fixes (mostly in sao). |
16th December 2015, 00:48 | #3025 | Link |
I wanted to ask is it normal that me=star is faster than umh.
I tested two videos: 1a) Profil medium me= umh : 18.61 fps PSNR : 45.114 SSIM :0.971590 1b) Profil medium me= star : 19.14 fps PSNR : 45.113 SSIM : 0.971609 2a) Profil medium me= umh : 13.23 fps PSNR : 46.188 SSIM : 0.967780 2b) Profil medium me = star : 13.65 fps PSNR : 46.191 SSIM: 0.967778 On a video 2mn subme:star is 7s faster. Visually I see no difference. This is different from the x264 ? Last edited by Blowis; 16th December 2015 at 23:34. |
16th December 2015, 23:12 | #3027 | Link | |
I use CRF:23 which gives a bitrate 1 724 Kbps and 2 597 Kbps. After I tested rdpenalty:2 I lost 19% and 29% encoding time. Visually minimal difference. Last edited by Blowis; 16th December 2015 at 23:42. |
16th December 2015, 23:44 | #3028 | Link | |
Posts: n/a
command line options changed from default preset bit rate Global PSNR SSIM FPS It would also help to know the details of your input video sequence (is it available, what is the pixel resolution, frame rate, and does it have low, medium or high motion)? Lastly, it would help to know your computer system details (processor, memory, OS). |
17th December 2015, 15:41 | #3029 | Link | |
Video 1a Profil Medium and: wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=3 / tu-inter-depth=3 / me=2 / subme=2 / merange=32 / no-rect / no-amp / max-merge=2 / temporal-mvp / early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=23 / scenecut=40 / rc-lookahead=20 / lookahead-slices=5 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=0 / no-limit-modes / weightp / weightb / aq-mode=2 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=1.00 / rdoq-level=2 / psy-rdoq=1.10 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30 Video 1b unless such Me=3 The same for video 2a and 2b. My Cpu I7 4770K@4.3Ghz DDR 8Go@2.4Ghz SSD 512go Samsung 840Pro Windows 10 Last edited by Blowis; 17th December 2015 at 15:44. |
17th December 2015, 23:53 | #3031 | Link |
@ Blowis
That means the command line in your encoder call, not the whole set of internal parameters stored in the auxiliary data in the video stream (that's simply too much to recognize at one glance). |
21st December 2015, 19:30 | #3033 | Link |
The table shows 2 row for limit-refs, but I'm pretty sure the first was for limit-modes, and limit-modes there aren't at all in the code too, only defaulted at 0.
Anyway I didn't get how to enable the 2 pass mode for cfr+vbv, if I have to.
powered by Google Translator |
21st December 2015, 20:05 | #3035 | Link |
Just when I am away from my usual building PC ... well, I will try to publish one as soon as I rebuilt my compiling environments elsewhere.
P.S.: Oh, then I have a little time, ok. Last edited by LigH; 21st December 2015 at 20:11. |
23rd December 2015, 09:44 | #3036 | Link |
Merry Christmas (or similar holidays) with a current build with updated preset defaults (e.g. limit-modes/refs; please RTFM).
x265 1.8+187-da48f2690076 (GCC 4.9.2) x265 1.8+187-da48f2690076 (GCC 5.2.0) |
24th December 2015, 14:26 | #3038 | Link |
"what drastically changed", the presets changed, pme and pmode were added but those only seem to be only really useful on systems 4+ core systems, all in all I wouldn't call any changed 'drastic'
24th December 2015, 15:22 | #3039 | Link |
I just tested the last days made. I chose the Medium profile I modified all its: --crf 22 --early-skip --aq-mode 2 --me star --merange 44 --rc-lookahead 60 --keyint 240 --psy-rd 1.3. wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=3 / subme=2 / merange=44 / no-rect / no-amp / max-merge=2 / temporal-mvp / early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=23 / scenecut=40 / rc-lookahead=60 / lookahead-slices=5 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / weightb / aq-mode=2 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=1.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30 But I see --Limit-modes : 3 that normally there should be more than 0. You can set it to 0 or must be done manually. |
25th December 2015, 01:36 | #3040 | Link |
Angel of Night
--limit-modes has no argument, it's either on or off. --limit-refs is 0-3.
Changes since 1.8: Modified presets, most are faster, higher quality, or both. Limit-modes. Intra refresh. 2-pass CRF. Monochrome (i400). Big psy-rd changes, possibly improvements. Lots of 12-bit speedups & bug fixes, and some other misc speedups and fixes for 8 & 10. Analysis save/load fixes. Level 8.5 (unlimited) allowed. i64x64 disabled until it's fixed. See the 1.8 announcement for changes since 1.7. Last edited by foxyshadis; 25th December 2015 at 01:49. |
