23rd October 2005, 16:28 | #201 | Link |
I am having some trouble with Easy RealMedia Editor 1.73. I am trying to cut a portion from an rmvb file created with ERMP 1.92. When I play the cutout file using WMP 10 (using Real Alternative), it works fine until the second last frame. After it plays the second last frame, the player freezes there for about 2-3 seconds with a terrible "grrrrrrr" sound. I tried cutting out different portions of the video but still I have the same problem.
I tried the video in Crystal Player. What happens then is when the video reaches the 2nd last frame, Crystal stops the video and skips to the next in the playlist. Any idea? |
12th November 2005, 20:13 | #203 | Link | |
retired developer
Detritus Software |
4th December 2005, 12:54 | #208 | Link |
Pro Life
Easy RealMedia Producer(ERP) is good
The DIO's RealProducer GUI(DRG) is another choice because DRG is very simple for use and stable function Now DRG supports RealProducer Plus 11 Wish ERP goes better in the future Your Chinese Friend MediaRay |
5th December 2005, 13:27 | #211 | Link |
I didn't know it, the App seems to be very interesting.
Can you send to me the download link? Because the one wich I have downloaded there is no Ing English language (the file is "0", empty). I got it in http://dio1888.bokee.com/ Thank you.
[ ]'s, nmatos |
6th December 2005, 06:39 | #212 | Link |
Pro Life
The DRG download link is here
http://bbs.ktxp.com/job.php?action=d...714&aid=261153 The latest version of ERP V1.93 is here http://www.bbsftp.com/zyxsoft/erm/ermp_full.rar Now it supports Real Producer Plus 11 core and you can choose the English interface easily when you install the software |
6th December 2005, 12:38 | #213 | Link |
Thank you very much, but that version of DRG is the same that I have. Unfortunately, there isn't english.lng (or in another words, the file "english.lng" is empty). If the developer maybe translate the *.ini file, I believe it will be enough, if that changes the label of the buttons. So simple and so complicated.
Otherwise the ERP is newer than mine and I'm already using it Your friend from Brazil:
[ ]'s, nmatos Last edited by nmatos; 6th December 2005 at 15:05. |
6th December 2005, 14:59 | #214 | Link |
Could you help me in one question that I still didn't find the answer?
Supose you are encoding in the ERP and it was almost finishing (for example 99,6%) and suddenly occur a blackout. That "temp_7WN1QzgPCEWtevWRkr-eRA==.tmp" generated, can I recover it? I mean: how to convert it in *.rmvb? Considering that practically the whole file was encoded? P.S.: Forigive my poor english and my stupid question. Thank you
[ ]'s, nmatos Last edited by nmatos; 6th December 2005 at 15:10. |
7th December 2005, 08:38 | #216 | Link |
Pro Life
Yes,posix's answer is right.
I had the same question sometimes so I changed the ext name from .temp to .rmvb,it worked normally If you think the software's stable funtion is more important,you can install an old version for example V1.82,it is just my favorite version.The download link is http://www.softdownload.cn/down.asp?ID=37042 Introduce another RealVideo Tools in China---Batch RealMedia Producer(BRP) It is the my first RV tools ever used,but it doesn't have English interface .You can use language translation software to use it http://cool18.comicer.com/images/brp1531_chs.exe I think More Choice Is Better Advice:If you are interested in Rip skill,you should study x264(H.264) now,x264(H.264) is the trend in the future.I consider that x264(500k)+MP3(96k) is much better than Real10(600k) MediaRay from China |
9th December 2005, 18:35 | #218 | Link |
I moved the RealAnime LE discussion over to the MPEG-4 / AVC forum:
http://forum.doom9.org/showthread.php?t=103831
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
18th December 2005, 22:38 | #219 | Link |
Could somebody tell me how to make ERMP to work under WINE ???
It installs but I get black screen in the place were u can drag and drop files ... And when I try to add a file it freezes.... To tell u the truth if you know any rmvb encoder that will run under wine u can also tell me ... It is really irritaiting that there is no such software GNU/linux native |
18th December 2005, 22:46 | #220 | Link |
retired developer
Why not using producer commandline for linux?
Detritus Software |
