Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 3rd February 2008, 10:55   #1  |  Link
Kyle_Katarn
AudioGrail : Swiss Army Knife for Audio Files
AudioGrail is the 6th major version of the 'K-MP3' project.
AudioGrail is a complete toolbox for common tags (metadata such as artist name, album...) and files name operations. It is a easy to use swiss army knife, with a brand new GUI.
The main tool is automatic audio files identification (thanks to the FreeDB database), but many other tools are available.
2 versions :
AudioGrail Free : Unlimited access to all tools. The only limitation is a maximum of 30 files that can be loaded simultaneously. This will not affect album-per-album use of the product.
AudioGrail Expert : For the one who what to go beyond... No limitation, prioritary tech support. 19.99 Euros.
Tutorials are avaialble, as well as 24/7 technical support for everyone (email, forum...).
Official Web site : http://www.kcsoftwares.com/?kmp3
Tutorials : http://www.kcsoftwares.com/doc/kmp3
Download Link : ftp://ftp2.kcsoftwares.com/kcsoftwa/...audiograil.exe
KC Softwares
Kyle_Katarn is offline   Reply With Quote
Old 3rd February 2008, 10:56   #2  |  Link
Kyle_Katarn
Update : 6.12.0.151
Site : http://www.kcsoftwares.com/?kmp3
ChangeLog : http://kcsofts.dyndns.org/mantis
KC Softwares
Old 10th February 2008, 18:59   #3  |  Link
Kyle_Katarn
Update : 6.12.1.152
KC Softwares
Old 24th February 2008, 17:51   #4  |  Link
Kyle_Katarn
Update : 6.12.2.153
KC Softwares
Old 19th June 2008, 21:14   #5  |  Link
Kyle_Katarn
Update : 6.12.3.154
KC Softwares
Old 14th July 2008, 17:04   #6  |  Link
Kyle_Katarn
Update : 6.13.0.155
KC Softwares
Old 12th September 2008, 19:29   #7  |  Link
Kyle_Katarn
AudioGrail - 6.13.1
Web : http://www.kcsoftwares.com/?kmp3
- 0000766: [Refactoring] Context menu items shall be translated (Kyle_Katarn) - resolved.
- 0000777: [Refactoring] Album info Progress bar shall be standard (Kyle_Katarn) - resolved.
KC Softwares
Old 11th November 2008, 20:22   #8  |  Link
Kyle_Katarn
AudioGrail - 6.13.3
- 0000477: [Bug] Identification : Tag Mask not correctly applied
- 0000651: [Bug] Identification : unchecked tags format not removed if existing
- 0000863: [Refactoring] HTTP transfert errors shall be logged
- 0000652: [Refactoring] Tag removed : Check = Remove or Keep ?
- 0000861: [Bug] Track list not properly sorted after "remove tag"
KC Softwares
Old 24th December 2008, 09:20   #9  |  Link
Kyle_Katarn
AudioGrail - 6.14
- 0000906: [Bug] Can duplicate meta tags fields if not using the same case
- 0000905: [Refactoring] Meta tags optimization : no longer create empty fields
- 0000903: [New Feature] Tag Editor : Add Tag (per type)
- 0000904: [Refactoring] Tag Editor : Tag management refactoring (no func effect)
- 0000902: [Refactoring] Help & About to be accessible thru main menu
KC Softwares
Old 17th January 2009, 20:18   #10  |  Link
Kyle_Katarn
AudioGrail - 6.15
- 0000892: [New Feature] Shall detect multiple instance of the same APEv2 tag field
- 0000914: [Bug] Uninstall icon is incorrect, displays as recycling bin.
- 0000907: [New Feature] Tag Cleaner shall have a "Remove duplicated fields" option
- 0000964: [New Feature] Open log file accessible in menus
- 0000963: [Refactoring] Cleaner tool shall write in log file (at least for fix genre and fix duplicate)
KC Softwares
Old 12th April 2009, 18:34   #11  |  Link
Kyle_Katarn
AudioGrail - 6.16
- 0001004: [Bug] Temporary playlist created by "Search->Play" not Vista ready
- 0001003: [Refactoring] Organizer : settings shall be disabled while working
- 0000890: [Bug] Tag cleaner : settings shall be disabled while working
- 0000891: [Bug] Tag Remover : settings shall be disabled while working
- 0001002: [Bug] If APEv2 contains only RG data and ID3 only contains metadata, nothing's displayed
KC Softwares
Old 10th November 2009, 23:20   #12  |  Link
Kyle_Katarn
AudioGrail - 6.17.1
- 0001129: [Bug] Cover downloader shall not be sizeable
- 0001123: [Bug] Cover search no longer works
KC Softwares
Old 14th November 2009, 04:45   #13  |  Link
khat17
Not seeing a full features review. I've already purchased dbPowerAmp some time ago - so what would the plus be to getting AudioGrail instead? I do love the fact that there's a free version though.
khat17 is offline   Reply With Quote
Old 14th November 2009, 15:57   #14  |  Link
Kyle_Katarn
Well.... give a look at the free try out or at the official web site and make your own idea
KC Softwares
Old 17th August 2014, 21:01   #15  |  Link
Kyle_Katarn
AudioGrail - 7.3 (Released 2014-08-17)
- 0002357: [Refactoring] Sumo update self check is in AudioGrail log file? (Kyle_Katarn) - resolved.
- 0001807: [Bug] Error reported (log+pop-up) when identification query canceled by user (Kyle_Katarn) - resolved.
- 0002356: [Bug] Purchase button and get it free button still visable (Kyle_Katarn) - resolved.
- 0002224: [New Feature] Log shall indicate if administrator rights are granted (Kyle_Katarn) - resolved.
- 0002248: [New Feature] Windows 8.1 support in log file (Kyle_Katarn) - resolved.
- 0002128: [New Feature] Estonian language support (Kyle_Katarn) - resolved.
KC Softwares
Old 1st September 2014, 14:28   #16  |  Link
Kyle_Katarn
AudioGrail - 7.3.1 (Released 2014-09-01)
- 0002604: [Bug] FLAC files support broken (Kyle_Katarn) - resolved.
- 0002605: [Bug] Jukebox does not appear when only 1 file "unknown" is listed (Kyle_Katarn) - resolved.
KC Softwares
Old 18th December 2014, 22:08   #17  |  Link
Kyle_Katarn
AudioGrail - 7.3.3 (Released 2014-12-18)
- 0002661: [Bug] Misdetection of Windows 8.1 (Kyle_Katarn) - resolved.
KC Softwares
Old 4th April 2015, 22:08   #18  |  Link
Kyle_Katarn
AudioGrail - 7.4 (Released 2015-04-04)
- 0002735: [Bug] GUI problems with 120 DPI (Kyle_Katarn) - resolved.
- 0002136: [Bug] "Local files" change displayed even if ovewrite is refused (Kyle_Katarn) - resolved.
- 0002820: [Bug] Wrong behavior when "load local cover" is cancelled (error JPEG 0000053) (Kyle_Katarn) - resolved.
- 0001351: [Bug] "Abstract Error" when download cover window is opened more than once (Kyle_Katarn) - resolved.
KC Softwares
Old 12th December 2015, 20:17   #19  |  Link
Kyle_Katarn
AudioGrail - 7.6 (Released 2015-12-12)
- 0003224: [New Feature] ALSR (Address space layout randomization) (Kyle_Katarn) - resolved.
- 0003300: [Refactoring] Upgrade of internal JEDI Libraries (Kyle_Katarn) - resolved.
- 0003264: [Bug] Windows 10 support in log file (Kyle_Katarn) - resolved.
KC Softwares
Old 31st January 2016, 11:01   #20  |  Link
Kyle_Katarn
AudioGrail - 7.6.1 (Released 2016-01-31)
- 0003489: [Bug] Log of language + change (Kyle_Katarn) - resolved.
- 0003499: [Bug] Wrong language file used (Kyle_Katarn) - resolved.
- 0003526: [Bug] AG ask for an update (Kyle_Katarn) - resolved.
KC Softwares
