Old 13th April 2009, 10:48   #1  |  Link
bollemanneke
VobSub problem
Hi!
Is there a way to tell Vobsub to not meddle with the timing of subs when the cell (or whatever it's called) changes?
I know SubResync can fix timing problems, but when I save my fixed files, AutoGK keeps changing the files back to the wrong ones.
Please help.
Bollemanneke
bollemanneke is offline   Reply With Quote
Old 13th April 2009, 17:49   #2  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
Fix the timings, then export to an another subtitle format, that should do the trick.
AMD Athlon X2 QL-60 (1.9GHz) - 3GB DDR2-667 - ATi Radeon HD 3200 - Windows 7 Ultimate 32-bit
Encode to Vorbis at ultra high speed using SSE3 multithreaded encoder by Lancer!
DJ Bobo is offline   Reply With Quote
Old 14th April 2009, 11:41   #3  |  Link
bollemanneke
Sorry, I gave you too less details.
When I fix the timing and resave the idx files, or rename them or delete the old idx files, AutoGK can't find the subs anymore.
When I export the sbs to srt or another format, AutoGK keeps making the wrong idx files. So isn't there a way to change a setting in VobSub to make right idx files from the beginning?
autogk, vobsub
