22nd September 2015, 21:29 | #33061 | Link | |||||||||
Well, in that case I hope you can live with keeping that option enabled. Currently I can't fix this easily because it's not really a bug, but a side effect of a performance optimization. It will have to wait until I revisit the whole screenshot stuff. Quote:
Anyway, too late to dig into the log today, will do that tomorrow... |
22nd September 2015, 22:40 | #33063 | Link | |
http://www.rtings.com/tv/reviews/by-brand/sony/x930c See the video games part.
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H |
23rd September 2015, 01:21 | #33066 | Link | |
Kid for Today
Oops sorry, error message seemed identical so I wasn't sure whether a new log would help
Log files sent for 89.3b & 89.3e to your email. Quote:
I've also used it to rescan 15/9 to 16/9, I'm done in 5 clicks when it already takes 5 clicks to open mVR's control panel and reach the black bars section. |
23rd September 2015, 07:22 | #33067 | Link | |
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^ Last edited by AndreaMG; 23rd September 2015 at 07:26. |
23rd September 2015, 08:36 | #33068 | Link | |
and nvdia is using "double" FPS deinterlacing by default. the input for madVR is still 29.97 that's just how deinterlacing works 60 field in 29.97 frames. |
23rd September 2015, 09:14 | #33069 | Link | |
For some reason it just causes issues with madVRs image doubling. Maybe CUVID/CUDA in D3D9 mode doesn't like having OCL in D3D11 mode at the same time or something.
23rd September 2015, 09:16 | #33070 | Link | |||||
http://madshi.net/madVR893f.rar Seems to help at least on my PC. Quote:
I can see, maybe I can rerender the frame in paused mode once every second or so? That should solve the subtitle problem without burning the GPU too much, I suppose. Quote:
So, I had a quick look at your debug log, but I'm not totally sure what to look for. I can see that it contains about 30 seconds of runtime. So which was the problem exactly which you captured in this debug log? Quote:
23rd September 2015, 09:46 | #33071 | Link | |
Bye |
23rd September 2015, 09:57 | #33072 | Link |
Ouch. Then the problem you have must be a different problem to the one I saw here. Can you upload your madVR "settings.bin" (if madVR has write access to its own folder on your PC, otherwise "HKCU\Software\madshi\madVR\Settings", so that I can try with the same madVR settings? Also are you using any special LAV Video Decoder settings? You said earlier it occurs with both software and native DXVA decoding, so that doesn't seem to play much of a role here. Is there any way to copy the DVBViewer settings? Which GPU are you using, which display resolution and refresh rate? And which OS? Maybe if I try to match my playback as much as possible to yours, hopefully I can reproduce the same issue then...
23rd September 2015, 10:06 | #33073 | Link | |||||
setup.xml Quote:
Bye |
23rd September 2015, 11:20 | #33074 | Link |
Nvidia GTX 960, Windows 10. Enabling NNEDI3 does nothing but enable the Jinc3 AR fallback for some reason. Theres not even a hint of it trying to enable it and then failing. This is with the newest 0.89.3.
This is the same behaviour as the previous builds, not sure whats going on/what to do. Would somehow regenerating the NNEDI3 kernel in the registry help if there was a way? |
23rd September 2015, 11:34 | #33076 | Link |
@madshi
since I am ill at home, I took the oportunity to think a bit about how you could better be prepared for Live TV matters. I know we talked about it on the DVBViewer forums but I would like to give it another shot . Therefore I also tried out several things... (1) Dreambox As it turned, you can easily use any E2 STB as network frontend for the DVBViewer. I tried that out with my UNiBOX HD eco+ and OpenATV image. You will find a comprehensive tutorial here, which should apply to all E2 STBs. There is one catch which cost me a bit of time. Zapping via the URL is only possible when the STB is in Standby (not Deep Standby of course). Otherwise the STB is the master and does not allow external sources to change the channel/stream. This really works beautifully. (2) USB-Tuner I did an inventory and I have quite a lot of prototype DVB hardware, see attached image. They are all DVB-S2 USB2 devices. I tested their proper functionality right now. They have been in the closet for several years and are just catching dust. I would be more than happy to give something back and send you one for free. Or if you prefer PCIe, I also have 2 Tevii S470 and an S482.
Bye Last edited by CiNcH; 23rd September 2015 at 12:52. |
23rd September 2015, 11:42 | #33077 | Link |
How about making it optional (with rerendering being disabled by default, of course)? It's an ideal solution but the only and big downside is an additional option itself, which may contribute to options being overfilled (too much options). But I think it's better than rerendering paused mode for all, which most people will not need, and for ones who need every second may be too long, so it's a bad solution for both. The decision to make is up to you
23rd September 2015, 11:51 | #33078 | Link | |
23rd September 2015, 12:19 | #33079 | Link | |
Member
Many thanks for your support. |
23rd September 2015, 12:46 | #33080 | Link |
That's why SVP with HW deinterlacing behaves correctly...
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^ |
