6th November 2009, 18:19 | #10381 | Link |
Yes after more testing I can confirm that internal MPEG spitter it's stripping off the HD from DTS-HD but the internal Matroska splitter doesn't
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 6th November 2009 at 18:25. |
6th November 2009, 23:31 | #10386 | Link | |
Ok I found where the DTS-HD problem has started
@albain can you confirm this please ? And can someone revert this please ?
Intel UHD Graphics 750; Win 10 22H2 |
7th November 2009, 00:30 | #10388 | Link | |
Haali splitter + MPC-HC with default settings.
MPC-HC 2.2.1 |
7th November 2009, 00:37 | #10389 | Link | |
otherwise, someone with a dts receiver won't get the dts core. |
7th November 2009, 07:20 | #10392 | Link | |
ZZZzzzz...
7th November 2009, 12:40 | #10393 | Link | ||
And with the changes that AFAIU are coming ( MPC wasapi audio renderer and maybe bitstreaming ) "DTS-MA Pass-through" will be solve without breaking DTS-HD, I think. So for this things to have a chance to be implemented we need the HD for DTS to be working with the internal mpeg splitter EDIT Albain has find the solution Quote:
else if (m_mt.subtype == MEDIASUBTYPE_DTS || m_mt.subtype == MEDIASUBTYPE_WAVE_DTS) // DTS HD MA data is causing trouble, lets just remove it { #if 0
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 7th November 2009 at 13:12. |
7th November 2009, 13:50 | #10394 | Link |
How can i get ATIs Edge enhancement to work in MPC? I tried it with MPC - Video decoder in DXVA Mode and with coreavc in Software mode. Tried all Renderes (custom evr, standard evr, vmr9, vmr7 and overlay) It just doesn't work. But if i play the same Blu-Ray in PowerDVD 7/8 ATIs Edge enhancement works. Relevant Systemcomponents: mpc build 1.3.1290.0 (32 bit) catalyst 9.10 ATI 4870 Vista 64 Bit cya Last edited by amigenius; 7th November 2009 at 14:27. |
7th November 2009, 14:29 | #10395 | Link |
Maybe you have to output in the nv12 colorspace which seems to be necessary for things like hardware deinterlacing
unfortunately alone mpc can't output in this colorspace so u will need ffdshow perhaps to do this for you. Worth a shot trying it but maybe someone else will have a better solution |
7th November 2009, 15:49 | #10396 | Link |
I'm confused by the shader options. when I turn on pixel shaders, the "Toggle pixel shader" is unchecked; when I turn it off, it's checked, which seems backward. then there's also "Pixel shader disabled", which seems redundant and at any case mislabeled. It should be called "No pixel shader" since that's what happens when you select it. It's like you label power switch On and Off, you don't call it "Power turned on" "Power turned off". I know it's nit-picking but I think grammar correctness is next to godliness
What are screen space pixel shaders vs regular pixel shaders? I can't tell what it does. Toggling it on and off still shows a check next to "screen space pixel shaders disabled" and has no visible effect on the screen. |
