11th August 2009, 18:49 | #21 | Link |
Software Developer
I wouldn't expect slices to make such a difference. Not at BD bitrates (36 Mbit/s).
11th August 2009, 20:51 | #22 | Link |
The link given by LoRd_MuldeR applies to SD (480p). 1080p with 4 slices will suffer a slightly lower PSNR loss than 480p with 2 slices, thus 0.038dB, which roughly amounts to a 0.8% bitrate loss at same quality.
11th August 2009, 23:34 | #28 | Link |
Software Developer
So you can already tell whether there are any other problems with BD compliance in x264, in addition to the known slices issue?
12th August 2009, 04:26 | #31 | Link | |
Remember Blu-ray's peak bitrate was defined for MPEG-2 applications. It's rather overkill for modern codecs. |
12th August 2009, 06:05 | #32 | Link | |
User of free A/V tools
Now take into account we may use H.264 instead of older MPEG-2 and necessary video bitrate can be halved for the same visual quality I suppose. |
12th August 2009, 12:00 | #33 | Link | |
BluRay Maniac
1. What is max allowed vbv-buffersize and vbv-maxrate for Level 4.0 from blu-ray specification (i.e for 4.1 are 30000/40000 buffer/maxrate), not H264. 2. So definitly L 4.0 dosen't require slices? can be then L 4.0 video primary video? 3. What is max allowed vbv-buffersize and vbv-maxrate for Level 3.2 from blu-ray specification for SD content, and what resoultion and fps allowed for SD, and is L 3.2 maximum for SD? 4. Is there anything about BD5/9 and special restrictions such as VBV or other? That is for now. Thanks. |
12th August 2009, 13:16 | #34 | Link | |
Remember this thread? |
12th August 2009, 13:23 | #35 | Link |
Software Developer
That's probably not the result of the bitrate, but a result of bad encoders and/or bad authoring
12th August 2009, 14:34 | #36 | Link | |
Didn't Dark Shikari say even with x264, you need a lot more than 25mbps to reach transparency on 1080p videos (from a master)? Last edited by Chengbin; 12th August 2009 at 14:40. |
12th August 2009, 15:35 | #37 | Link |
Software Developer
This is highly source dependent. I'm pretty sure for most sources you will be fine with x264 and much lower bitrates...
12th August 2009, 16:20 | #38 | Link | |
Dark Shikari, do you mind clarifying this quote in terms of what kind of source are you referring to?
12th August 2009, 16:26 | #39 | Link |
Software Developer
He mans that if you were encoding from an original lossless source ("Master"), then you would need significant more bitrate to retain all detail, because there is so much detail/grain in that source.
However we usually don't have access to such sources. What we have are BluRay's, which have already been filtered and compressed in a lossy way. Many detail is already gone for good when we get the data! Re-encoding such lossy sources requires less bitrate to retain all details (the details that are still there) for obvious reasons...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 12th August 2009 at 16:35. |
12th August 2009, 16:40 | #40 | Link |
LoRd_MuldeR, I see you didn't finish reading my post, I said "from a master".
Anyway, I'm very excited to see what Lyris can do with his project using x264. BTW, p_l_e_a_s_e use the full 50GB of the disk. I've seen so many Blu-rays with low 20mbps bitrate and the disk still has 10-15GB free. But then truthfully this 40mbps cap is kind of a bottleneck. If you use high average bitrates (like Jumper's 33mbps), if you use bitrate viewer on it, it will probably look like CBR. Last edited by Chengbin; 12th August 2009 at 16:44. |
authoring, blu-ray, compliant, verified, x264 |
