Old 20th August 2008, 17:33   #81  |  Link
vlada
In MPlayer from 2008-07-18 should be PAFF implemented. I think it is supported at least for a half of year.
Now I'd like to ask you for help with my problem. On my work computer I can't run MPlayer. The CLI version MPlayer.exe always instantly exits without any output. I tried different versions and builds. I have a suspicion that a firewall or other "service" is blocking MPlayer. I tried to rename the .exe but it didn't help.
Do you have any idea how to check if my suspicion is correct? And more importantly do you have any idea how I could fool the service?
vlada is offline   Reply With Quote
Old 20th August 2008, 21:22   #82  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I don't see how a firewall could prevent MPlayer from starting up
I recommend you try to run MPlayer.exe from gdb and see what it reports. Maybe you get some useful output...
You can get latest gdb version here:
http://sourceforge.net/project/showf...ease_id=594520
Try like this:
"C:\MinGW\Bin\gdb.exe" "C:\Program Files\MPlayer for Windows\MPlayer.exe"
Then type "run" to start execution and see what will happen...
Old 21st August 2008, 06:49   #83  |  Link
Hogge
Originally Posted by dat720 View Post
There must be a problem elsewhere with your setup, the only time i ever have playback issues is if the video requires more processing power than my pc has!
Hi Dat!There is no problem with my setup,ive tried anything anbd everything,i mean what can i do wrong.Im running Vista AMD 64X2 2,3ghz ,4gb memory.Dat tell me how to setup then,ive never had problems befor it the latest build only.
Hogge is offline   Reply With Quote
Old 21st August 2008, 08:58   #84  |  Link
dat720
I have no idea what software or problems there could be with Your PC, my current setup is Vista x64 Intel Q9550 (this thing rocks!!!) 4gb ram, and mplayer and mencoder work perfectly!
On that note...
Mulder, one thing that anoys me about your Installer is no Mencoder!!!!
Could you do 2 packages.... one with mencoder and one without!
dat720 is offline   Reply With Quote
Old 21st August 2008, 15:10   #85  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
What's wrong with not bundling an encoding program in a playback package ?
You can get mencoder from here (bundled with mplayer) though
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 21st August 2008, 15:56   #86  |  Link
vlada
Originally Posted by LoRd_MuldeR View Post
Try like this:
Thanks for your help. This is the result I got:
Is it of any help? I'm afraid not. I think I might need a debug version of MPlayer.
Old 21st August 2008, 18:51   #87  |  Link
LoRd_MuldeR
Software Developer
Well, the debugger works even without a Debug build. In case of a crash a Debug build simply gives more useful info, that's it.
But you don't get any output at all. That really bizarre. Sure your MPlayer.exe file is okay ???
You should get something like this:
LoRd_MuldeR@MULDER_NEU ~
$ cd "/c/program files (x86)/MPlayer for Windows"
LoRd_MuldeR@MULDER_NEU /c/program files (x86)/MPlayer for Windows
$ gdb MPlayer.exe
GNU gdb 6.8
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-pc-mingw32"...
(no debugging symbols found)
(gdb) run
Starting program: c:\program files (x86)\MPlayer for Windows/MPlayer.exe
[New thread 4992.0x1384]
Error: dll starting at 0x77d40000 not found.
Error while mapping shared library sections:
NOT_AN_IMAGE: No such file or directory.
C:\WINDOWS\SysWOW64\ntdll32.dll: No such file or directory.
Error: dll starting at 0x77c20000 not found.
[New thread 4992.0x1388]
MPlayer Sherpya-SVN-r27323-4.2.4 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Core(TM)2 Quad CPU           @ 2.40GHz (Family: 6, Model: 15, Step
ping: 7)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Usage:   mplayer [options] [url|path/]filename
Basic options: (complete list in the man page)
 -vo <drv>        select video output driver ('-vo help' for a list)
 -ao <drv>        select audio output driver ('-ao help' for a list)
 vcd://<trackno>  play (S)VCD (Super Video CD) track (raw device, no mount)
 dvd://<titleno>  play DVD title from device instead of plain file
 -alang/-slang    select DVD audio/subtitle language (by 2-char country code)
 -ss <position>   seek to given (seconds or hh:mm:ss) position
 -nosound         do not play sound
 -fs              fullscreen playback (or -vm, -zoom, details in the man page)
 -x <x> -y <y>    set display resolution (for use with -vm or -zoom)
 -sub <file>      specify subtitle file to use (also see -subfps, -subdelay)
 -playlist <file> specify playlist file
 -vid x -aid y    select video (x) and audio (y) stream to play
 -fps x -srate y  change video (x fps) and audio (y Hz) rate
 -pp <quality>    enable postprocessing filter (details in the man page)
 -framedrop       enable frame dropping (for slow machines)
Basic keys: (complete list in the man page, also check input.conf)
 <-  or  ->       seek backward/forward 10 seconds
 down or up       seek backward/forward  1 minute
 pgdown or pgup   seek backward/forward 10 minutes
 < or >           step backward/forward in playlist
 p or SPACE       pause movie (press any key to continue)
 q or ESC         stop playing and quit program
 + or -           adjust audio delay by +/- 0.1 second
 o                cycle OSD mode:  none / seekbar / seekbar + timer
 * or /           increase or decrease PCM volume
 x or z           adjust subtitle delay by +/- 0.1 second
 r or t           adjust subtitle position up/down, also see -vf expand
 * * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * *
Program exited normally.
(gdb)
Old 21st August 2008, 18:53   #88  |  Link
LoRd_MuldeR
Software Developer
I don't see a reason to have MEncoder in a playback package. Also none of the front-end does use MEncoder.
So there is absolutely no difference if you download the MEncoder.exe alone. See the link provided by DarkZell666.
Old 21st August 2008, 19:59   #89  |  Link
vlada
LoRd_MuldeR> The same MPlayer.exe works on other computers without any problems. But it doesn't work on any computer at work. I also tried other builds with the same result. So my conclusion is that there must be something in our network which kills MPlayer as soon as it is started.
But I'm wondering how the "service" could recognize that the process is MPlayer. Do you have any idea?
Old 21st August 2008, 20:06   #90  |  Link
DarkZell666
aka XaS
Maybe a blacklist on the executable name ?
Or even a whitelist with authorised programs in which mplayer isn't listed ? What if you rename to somethingelse.exe ?
Old 21st August 2008, 20:06   #91  |  Link
LoRd_MuldeR
Software Developer
The network cannot cause the problem, because the MPlayer process won't open any network connections before writing the copyright notice and stuff to stdout.
Unless you try to open a web stream, it won't open any network connection at all...
I guess it's some "conflicting" software, which is installed on all the computers at work. Maybe some tool that prevents workers from stating up "entertainment" software or buggy A/V software ?!?!?
Old 21st August 2008, 21:40   #92  |  Link
vlada
DarkZell666> As I already wrote renaming the EXE doesn't help. Also almost all other programs (in portable versions) work without any problems.
LoRd_MuldeR> Yes, this is also what I think. Maybe antivirus (which I can't stop) is causing it. But I'm wondering how it can identify that the process is MPlayer.
Old 21st August 2008, 22:03   #93  |  Link
LoRd_MuldeR
Software Developer
Hash? Signature? Heuristics? ...
Old 21st August 2008, 22:11   #94  |  Link
DarkZell666
aka XaS
Ooops, I did read your posts though, I must have scrolled past that one
Well, antiviruses identify viruses directly by detecting "bytecode patterns", or so to say. It would be very farfetched to think they actually built a signature to forbid mplayer, but technically it's possible imho.
As MuldeR says, some companies use hidden processes to actually do just that sort of thing. They can even detect forbidden processes remotely (how cool is that ? ... lol).
How exactly they detect mplayer depends on the product. Right-click on mplayer.exe and check the "version" tab. Some of them maybe use the info from in there, dunno ... There's tons of meta-information to be used to identify a program, and the "version" tab is only part of it
Old 22nd August 2008, 09:27   #95  |  Link
dat720
I don't see a reason to have MEncoder in a playback package. Also none of the front-end does use MPlayer.
Fair enough... im just lazy.... im a public servant what do you expect
Old 22nd August 2008, 19:19   #96  |  Link
panzerino
LoRd_MuldeR
Thank you for your wonderful job.
Two question:
*if I put the mplayer window in some position on the screen there is an option to retain this position when the next title from my playlist is played?
*when i make some changes on brightness/contrast there is an option to retain these settings when the next title from my play list is played? when the next title is played MPlayer redraw some default values...
MPLayer is wonderful to play music too... sorry but i use one old 10/2007 version. All the newest mplayer versions have 40-50% more CPU using... i do not know why this happen, but anyway... great player... the best literally.
panzerino is offline   Reply With Quote
Old 23rd August 2008, 00:54   #97  |  Link
dat720
That seems strange that mplayer is using 40-50% for music........
I have the most current build and it only uses 20% CPU to playback a 21gb HD mkv
Old 23rd August 2008, 11:06   #98  |  Link
panzerino
I have Pentium 4 Northwood with only 1GB RAM...
Old 23rd August 2008, 12:19   #99  |  Link
Martin H
As i previously stated in this thread, then the MPlayer build that's included in the latest official MPUI package(dev-SVN-r26251-3.4.2 from the 15th of march '08 which is compiled with CPU runtime-detection), uses less CPU cycles and RAM while also being 1.8mb smaller than the P4 optimized "Sherpya" build(Sherpya-SVN-r27323-4.2.4) that's included in MuldeR's latest installer...
Direct-link to a zip archive with the lighter/smaller MPlayer-SVN-r26251: http://garr.dl.sourceforge.net/sourc...SVN-r26251.zip
Martin H is offline   Reply With Quote
Old 23rd August 2008, 12:58   #100  |  Link
LoRd_MuldeR
Software Developer
You must be kidding. This download is two years old now...
mplayer, mpui, player, smplayer, win32
