11th March 2012, 14:22 | #101 | Link |
mammo1789!
I try Your short clip with thicknessline=3,2,1 and see at some frames removing lines (not all). Script can remove no more than 2 sequential lines at time line. If have 4 sequential lines at time line need 2 or 3 pass. Also try new version Code:
Global thicknessline=2# thickness horizontal spike in pixels at field scale (not frame) Global radvertmed=2*thicknessline-1 Global distser=25# distance between short lines Global halflength=3# detect line longer 2*halflength+1 pixels #SetMemoryMax(768) #SetMTMode(3,4) source=AVISource("selnew.avi") #source file #SetMTMode(2,4) source=source.AssumeTFF().ConvertToYV12(interlaced=true) bobnn=source.nnedi3(field=-2,threads=1) # bobbing for better motion estimation bobnnmed=bobnn.mt_luts(bobnn,mode="median",pixels=mt_rectangle(0,radvertmed),U=3,V=3) # vertical median filter bobnnmedf=bobnnmed.dfttest(tbsize=1,ftype=1,sbsize=8,sosize=6,sigma=1000,U=false,V=false) #dft filter remove segregation after median vertical filter super=MSuper(bobnn) superf=MSuper(bobnnmedf,chroma=false) bw1 = MAnalyse(superf, blksize=8, isb = true, delta = 2, overlap=4, dct=5,chroma=false) bw2 = MAnalyse(superf, blksize=8, isb = true, delta = 4, overlap=4, dct=5,chroma=false) fw1 = MAnalyse(superf, blksize=8, isb = false,delta = 2, overlap=4, dct=5,chroma=false) fw2 = MAnalyse(superf, blksize=8, isb = false,delta = 4, overlap=4, dct=5,chroma=false) bc1 = MCompensate(bobnn, super, bw1, thSAD=16000, thSCD1=16000) bc2 = MCompensate(bobnn, super, bw2, thSAD=16000, thSCD1=16000) fc1 = MCompensate(bobnn, super, fw1, thSAD=16000, thSCD1=16000) fc2 = MCompensate(bobnn, super, fw2, thSAD=16000, thSCD1=16000) # motion estimation on filtered and compensating on source bwabs1=mt_lutxy(bobnn,bc1,"x y - abs") bwabs2=mt_lutxy(bobnn,bc2,"x y - abs") fwabs1=mt_lutxy(bobnn,fc1,"x y - abs") fwabs2=mt_lutxy(bobnn,fc2,"x y - abs") # calculation absolute difference between source and compensated SDIc=SDIAdapt(bwabs1,fwabs1) SDIb=SDIAdapt(bwabs1,bwabs2) SDIf=SDIAdapt(fwabs1,fwabs2) # calculation spike detection index for center, forwad and backward mb1sad=bobnnmedf.MMask(bw1,kind=1,ml=100,Ysc=255, thSCD1=16000) mb2sad=bobnnmedf.MMask(bw2,kind=1,ml=100,Ysc=255, thSCD1=16000) mf1sad=bobnnmedf.MMask(fw1,kind=1,ml=100,Ysc=255, thSCD1=16000) mf2sad=bobnnmedf.MMask(fw2,kind=1,ml=100,Ysc=255, thSCD1=16000) # calculating SAD for filtered for estimation better choice for motion compensation centersad=mt_logic(mf1sad,mb1sad,"max")#,U=2,V=2) # maximum SAD from forward and backward measure for quality center compensation bwsad=mt_logic(mb1sad,mb2sad,"max") #for backward compensation fwsad=mt_logic(mf1sad,mf2sad,"max") #for forward compensation centermask=mt_invert(centersad) bwmask=mt_invert(bwsad) fwmask=mt_invert(fwsad) # inverting mask for using mt_merge mcfcenter=clense(bc1, bobnn,fc1,increment=0, grey=false) mcfbw=clense(bc1, bobnn,bc2,increment=0, grey=false) mcffw=clense(fc1, bobnn,fc2,increment=0, grey=false) # motion compensated median filtering for center, backward and forward compensation # # sort SAD for finding better motion compensated median filtering, this approach can use without SDI for pixels and 1 line thickness stripes mt_logic(mt_lutxy(centersad,bwsad,"x y <= "), mt_lutxy(centersad,fwsad,"x y <="),"and") maskcentersad=mt_lutxy(last,centersad,"x 255 y - 0 ?") # center filtered mt_logic(mt_lutxy(bwsad,centersad,"x y < "), mt_lutxy(bwsad,fwsad,"x y <="),"and") maskbwsad=mt_lutxy(last,bwsad,"x 255 y - 0 ?") # backward filtered mt_logic(mt_lutxy(fwsad,centersad,"x y < "), mt_lutxy(fwsad,bwsad,"x y < "),"and") maskfwsad=mt_lutxy(last,fwsad,"x 255 y - 0 ?") # forward filtered # mcfmaskedsad=mt_merge(bobnnmed,mcfbw,maskbwsad,luma=true) mcfmaskedsad=mt_merge(mcfmaskedsad,mcffw,maskfwsad,luma=true) mcfcentersad=mt_merge(mcfmaskedsad,mcfcenter,maskcentersad,luma=true) #best value based on 3 motion compensated median time filtered value and spatial filtered # where motion compensation bad, work only for one sequintial frame with spike mcfbwsad=mt_merge(bobnnmed,mcfbw,maskbwsad,luma=true) mcffwsad=mt_merge(bobnnmed,mcffw,maskfwsad,luma=true) # backward and forward compensated full for SDI approach and spatial filtered where motion compensation bad #end sort SAD # # # sort SDI for choose center, forward or forward compensation work with 2 sequential frames, for 3 need 2 pass filtering, for 4 3 pass maskcentersdi=mt_logic(mt_logic(mt_lutxy(SDIc,SDIb,"x y >= "), mt_lutxy(SDIc,SDIf,"x y >="),"and"),SDIc,"and").mt_lut("x 255 0 ?") # center SDI maskbwsdi=mt_logic(mt_lutxy(SDIb,SDIc,"x y > "), mt_lutxy(SDIb,SDIf,"x y >="),"and").mt_lut("x 255 0 ?") # backward SDI maskfwsdi=mt_logic(mt_lutxy(SDIf,SDIc,"x y > "), mt_lutxy(SDIf,SDIb,"x y >"),"and").mt_lut("x 255 0 ?") # forward SDI # maskedsdi=mt_merge(bobnn,mcfcentersad,maskcentersdi,luma=true) maskedsdi=mt_merge(maskedsdi,mcffwsad,maskfwsdi,luma=true) maskedsdi=mt_merge(maskedsdi,mcfbwsad,maskbwsdi,luma=true) #end sort SDI # # this place for repair now I am thinking fieldmaskedsdi=maskedsdi.AssumeTFF().SeparateFields().SelectEvery(4,0,3) #fieldmaskedsdi=SDIc.AssumeTFF().SeparateFields().SelectEvery(4,0,3) StackVertical(Separatefields(source),fieldmaskedsdi,mt_makediff(fieldmaskedsdi,Separatefields(source),u=3,v=3)) #StackVertical(Separatefields(source),mt_makediff(fieldmaskedsdi,Separatefields(source),u=3,v=3)) #Weave(fieldmaskedsdi) # some kind comparing and weave for interlaced source, may be at double rate and for second pass not need bobbing # Spike Detection Function # function SDIAdapt(clip b1,clip b2) { threshsp=10 # threshold for pixels value absolute difference from 2 sequitial frames for spike detection THP=string(threshsp) threshavg=2 # threshold how much times actual SDI greater avearage and decimated SDI for remove false alarm for bad motion compensation THAVG=string(threshavg) SDI=mt_lutxy(b1,b2,"x "+THP+" > y "+THP+" > | 1 x y - x y + / abs - 255 * 0 ? ") # SDI calculation SDIavg=SDI.mt_luts(SDI,mode="avg",pixels=mt_square(5)) # SDI averaging SDIAvgblk=SDIavg.PointResize(90,72)# for PAL (90,72), FOR NTSC (90,60) # decimation SDIavgblkX=SDIAvgblk.mt_luts(SDIAvgblk,mode="median",pixels="1 -1 0 0 -1 1 1 1 -1 -1") # median point at X position SDIavgblkCross=SDIAvgblk.mt_luts(SDIAvgblk,mode="median",pixels="1 0 0 0 -1 0 0 1 0 -1") #median point at Cross position SDIAvgblk=clense(SDIAvgblk,SDIavgblkCross,SDIavgblkX,increment=0, grey=true).mt_lut("x") # multi median filtering for remove false alarm SDI SDIavg=SDIAvgblk.PointResize(720,576)# for PAL (720,576), FOR NTSC (720,480) # backward resize to original frame size SDIad=mt_lutxy(SDI,SDIavg,"x "+THAVG+" y * > x 128 > & 255 0 ?") # comparing with actual SDI and if greater it is real spike, value 128 can increase to 192 # be carefull I can not find this at original paper, big value can loose spike, small false alarm SDIad = (radvertmed>1) ? SDIad.mt_luts(SDIad,mode="median",pixels=mt_rectangle(0,radvertmed-1)) : SDIad # rectangle size could one less than for bobnnmed, for thinner lines need additional pass with thiknessline=thicknessline-1 until thicknessline=1 SDIad = SDIad.mt_luts(SDIad,mode="median",pixels=mt_rectangle(thicknessline,0)) #remove line shotter than thicknessline+1 SDIadleft=SDIad.mt_luts(SDIad,mode="max",pixels=mt_freerectangle(-distser,0,0,0)) # fill distser pixels from spike left side SDIadright=SDIad.mt_luts(SDIad,mode="max",pixels=mt_freerectangle(0,0,distser,0)) # fill distser pixels from spike right side SDIadser=mt_logic(SDIadleft,SDIadright,"min") # if pixels exist at SDIadleft and SDIadright fill pixels between 2 short lines SDIadser = (radvertmed>1) ? SDIadser.mt_luts(SDIadser,mode="median",pixels=mt_rectangle(0,radvertmed-1)) : SDIadser # ADDITIONAL VERTICAL MEDIAN FILTER FOR REMOVE THIN JOIN PART SDImask=SDIadser.mt_luts(SDIadser,mode="min",pixels=mt_rectangle(halflength,0)) # remove spikes shorter than 2*halflength+1 pixels tune for source SDImask=SDImask.mt_luts(SDImask,mode="max",pixels=mt_rectangle(halflength,0)) # expand after shrinking SDIad=mt_logic(SDIad,SDImask,"min") # combination source and adapting SDI for better robustness # SDIad = SDIad.mt_luts(SDIad,mode="median",pixels=mt_rectangle(thicknessline,0)) # additional remove short spikes which can be artefacts return(SDIad) } yup. |
14th March 2012, 15:13 | #103 | Link |
I suggest you try your script something like:
mergechroma (dctfun4b (5.5)) # set to your like or mergechroma (ReduceFlicker) or other function within the plugin with mergechroma |
14th March 2012, 17:00 | #104 | Link |
GMJCZP!
Now script find place for luma spike and repairing including chroma. I see that at place where luma spike exist also is chroma dig wider than luma spike. I am planing also find solution for this. yup. |
16th March 2012, 00:30 | #105 | Link |
I made the suggestions because you saw colored lines.
There are other alternatives to use: DeScratch, DeSpot, or the wonderful idea (the best) of John Meyer, RemoveDirtMC. Good luck, yup! |
16th August 2012, 07:32 | #106 | Link |
Hi all!
Upload avsi version of script with small changes (work little better with thicker lines 3 and 4 due to use gaussianblur instead of average filter before decimation SDI mask). See first post. yup. Last edited by yup; 16th August 2012 at 08:47. |
17th August 2012, 04:45 | #108 | Link |
Mounir!
Yes slow! for testing. Script based on motion compensated median filtering and analyzing not only current frame but 2 before and 2 ahead. It is spent CPU time. Short test with devcr, not remove all horizontal lines especially series (not solid with series short lines), introduce artifacts. I am sure that script can be optimized. For this we need help from guru script writers. yup. |
8th February 2018, 03:47 | #109 | Link |
hi Yup, was wondering if I could get some help with one of your scripts, it works as it should as it creates a mask with the lines I want to remove from each frame, but how do I apply the mask to actually remove the black lines?
Setmemorymax(512) AviSource("F:\Video-Capture\Home Improvement.avi") #ok AssumeBFF() ConvertToYV12(interlaced=true) fields=SeparateFields() backward_vec = fields.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=2, idx = 1,dct=1) forward_vec = fields.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=2, idx = 1,dct=1) fc = fields.MVFlow(forward_vec, idx=1, thSCD1=10000) bc = fields.MVFlow(backward_vec, idx=1, thSCD1=10000) masksdi=SDIPixelMask(bc, fields, fc, 50, 0.8) # define your thresholds here StackVertical(fields,masksdi) #Weave() # this is for Abs(p - f) or Abs(p - b) Function absdiff(clip c1, clip c2) { return mt_lutxy(c1, c2, "x y - abs") } # this build the expression for the SDI function Function SDI_RPN(string expr_d1, string expr_d2, string expr_t1, string expr_t2) { _d1 = expr_d1 + " " _d2 = expr_d2 + " " _t1 = expr_t1 + " " _t2 = expr_t2 + " " return _d1 + _t1 + "> " + _d2 + _t1 + "> | 1.0 " \ + _d1 + _d2 + "- " + _d1 + _d2 + "+ / abs - 0.0 ? " \ + _t2 + "> 1.0 " + _d1 + _t1 + "> " + _d2 + _t1 + "> | 1.0 " \ + _d1 + _d2 + "- " + _d1 + _d2 + "+ / abs - 0.0 ? " } # this creates the mask Function SDIPixelMask(clip prev, clip curr, clip next, float t1, float t2) { c_d1 = absdiff(curr, next) c_d2 = absdiff(curr, prev) # since SDI returns 0..1 we multiply with 255 mask = mt_lutxy(c_d1, c_d2, SDI_RPN("x", "y", String(t1), String(t2)) + " 255 *") return mask } |
8th February 2018, 19:05 | #114 | Link |
my thinking at the moment is to create a clip with only the mask, also create a 'fixed' clip which has all the black lines removed, then merge the two together, i guess they'll work? using overlay() and one of its parameters to "blend" etc the two together
9th February 2018, 12:13 | #116 | Link |
greymouse & poisondeathray!
Now I am out my working horse (after weekend). This spring I am little rewriting script for last version avisynth and plugin. For some source work relative good. yup. |
12th February 2018, 14:49 | #118 | Link |
greymouse!
See link for updated version: https://www.dropbox.com/s/3b4p4zr6cj...med3n.avs?dl=0 For script need Avisynth+ and all updated plugin. 32 bit version work like before with old variableblur plugin. Code:
SDIavg=SDI.mt_luts(SDI,mode="avg",pixels=mt_square(5)) #SDIavg=SDI.gaussianblur(varY=40) #SDIavg=SDI.dfttest(tbsize=1,ftype=1,sbsize=8,sosize=6,sigma=1000,U=false,V=false,threads=1) # SDI averaging If two other mt_luts or dffttest You can use 64 bit (some speed up and stability). Now I try Mohan plugin GBlur. One more improvement, support YV16 colorspace (lossless for YUY2 captured source), before only YV12. Any suggestion welcome. yup. Last edited by yup; 12th February 2018 at 15:52. |
