14th January 2020, 13:43 | #58361 | Link |
Gemini Man is 60p. Probably means that the 5700 XT isn't powerful enough for tone mapping at 60 fps.
Apart from setting highlight recovery to off, checking the boxes related to HDR in 'trade quality performance' is an option, but at that point you'll probably get better quality with passthrough anyway.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
15th January 2020, 04:22 | #58364 | Link |
QB the Slayer
I just test Gemini Man with my 5700XT... yeah, Tone Mapping is definitely a no go. I refuse to use any trade quality settings... so pass-through is the best option (for my tastes). I just setup a quick and simple hdr profile and now I am set for the very rare 60 FPS HDR content out there.
QB
15th January 2020, 08:48 | #58365 | Link | |
I don't agree, I saw the film both in PASSTHROUGH HDR and with Madvr's TONE MAPPING with the addition of a calibration in SDR DCI-P3 and sincerely watching the film with tone mapping is much better .... then with COMPROMISE ON HDR TONE & GAMUT MAPPING there is only a slight difference in colors that are a little less saturated, so I don't see what the problem is |
15th January 2020, 08:53 | #58366 | Link | |
On a 5700XT the only way to watch GEMINI MAN with Madvr tone mapping is to click on COMPROMISE ON HDR TONE & GAMUT MAPPING, if it is left disabled, even by lowering the CHROMA UPSCALING to CUBIC, or excluding HIGHLIGHT RECOVERY, the rendering will always be high .... or the other way is to use the PASSTHROUGH HDR |
15th January 2020, 09:07 | #58367 | Link |
Is it with d3d11 native in Lav?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
15th January 2020, 13:14 | #58368 | Link |
QB the Slayer
yes...
and I guess I should also say that I output to a 4k OLED (C8) so I don't "need" the tonemapping as much. It's easy for us with HDR displays to forget most users don't have this and need to tonemap to SDR or very low nits. QB
15th January 2020, 17:02 | #58371 | Link |
Soul Seeker
I noticed something little strange today, using NGU AA low for chroma, and image doubling with NGU Sharp medium, the render queue stays most of the time 7-8/8, but sometimes it shows 6-7/8. I'm using 3440x1440p display, the card is gtx 1050 ti. Rendering times are ~ 21 ms.
15th January 2020, 18:42 | #58373 | Link |
As long as you don't actually get any dropped frames, fluctuations in the queue are just normal operation.
15th January 2020, 21:09 | #58374 | Link | |
Hi, There is a bug for all 5700 users at the moment, AMD HDR API is broken and not sendin BT2020 colour space to HDR tv's, this is likely why you are seeing unsaturated colours? Turn on windows HDR, then Switch to passthrough and untick meta data in MADVR and have another look, can you report back what your see. thanks
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions |
16th January 2020, 15:16 | #58375 | Link |
after 7 years of excellent work my intel 2700k is finally going out to pasture (ebay) - i'm upgrading to a ryzen 5 3600, however i'm sure i've heard some issues about ryzen and video output / madvr etc, anyone know of any issues I need to be wary of with MADVR?
16th January 2020, 15:47 | #58376 | Link | |
the slightly unsaturated colors are due to the COMPROMISE ON HDR TONE & GAMUT MAPPING function, which I repeat is forced to click to take advantage of the madvr tone mapping at 60hz .... with the PASSTHROUGH HDR I do not need to click on COMPROMISE ON HDR ... . for 60hz and the colors are correct, even using the Windows API. The only difference I found between the AMD and the Windows API is that the latter is brighter .... but I always use Madvr tone mapping for 23.976 and 24hz, the vision is better with the addition also of a calibration in SDR DCI-P3 Last edited by stefanelli73; 16th January 2020 at 15:52. |
16th January 2020, 17:19 | #58378 | Link |
Don't know if they are that similar, but I have no issues using Ryzen 7 3700x, obviously with a discrete GPU.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
16th January 2020, 20:21 | #58380 | Link |
I just thought I'd read somewhere there was an issue, glad to be wrong.
