Old 6th January 2017, 15:43   #1  |  Link
Gew
Observer
Gew's Avatar
Android video player able to play ISO DVD?
Hi!
I know this has been discussed on several other boards on the net but I thought I'd see if there's any recent info on progress on the matter.
Are there really still no simple way of playing a dvd.iso on an Android device e.g. phone or tablet "as is" i.e. without re-encoding or appending MPEG2 streams and muxing them together in some widely accepted container, probably not without some audio sync issues being presented as well.
So, anything new? Anyone with insight on VLC development team? They somehow feel like the safest bet around.
Gew is offline   Reply With Quote
Old 7th January 2017, 12:40   #2  |  Link
Some filesystem/mounting type related stuff below
GingerBread+
Name	Size	Type	Date Modified
CifsManager(1.5a)(18)(ws.plattner.cifsmanager).apk	52 KB	APK File	23/11/2014 01:31
ISO_Extractor(1.1)(2)(se.qzx.isoextractor).apk	138 KB	APK File	26/04/2015 17:05
Mounts2SD(3.4.8)(33)(com.spazedog.mounts2sd).apk	2,247 KB	APK File	23/11/2014 01:31
Multi_Mount_SD-Card_Lite(2.50)(93)(com.rafoid.multimountsdcard.widget.free).apk	291 KB	APK File	20/02/2015 11:08
Paragon_NTFS&HFS+(1.14)(15)(com.paragon.mounter).apk	5,066 KB	APK File	20/02/2015 11:08
Paragon_NTFS&HFS+(1.18)(19)(com.paragon.mounter).apk	7,724 KB	APK File	13/09/2015 22:26
Remount(1.1)(2)(com.stericson.remount).apk	29 KB	APK File	20/02/2015 11:08
ICS+
DriveDroid(0.9.18)(49)(com.softwarebakery.drivedroid).apk	2,246 KB	APK File	26/04/2015 17:05
Iso_Mounter(2.0)(2)(com.iso.mounter).apk	159 KB	APK File	26/04/2015 17:05
Ntfs_Mounter(0.5)(5)(com.kwull.ntfsmounter).apk	1,825 KB	APK File	20/02/2015 11:08
Good luck
EDIT: I think I got at least one of the above mounting ISO OK, dont remember which.
EDIT:
https://play.google.com/store/apps/d...odplayer&hl=en
http://forums.androidcentral.com/and...r-android.html
https://play.google.com/store/apps/d...g.videolan.vlc
https://www.google.com/?gfe_rd=cr&ei...ore+iso+player
Old 9th January 2017, 19:44   #3  |  Link
mytbyte
Hmmm...I'm pretty sure installing Kodi would do the trick
mytbyte is offline   Reply With Quote
android, dvd, iso
