Old 5th June 2010, 22:38   #8521  |  Link
Sharc
From the first post in this thread .....
Please do not post any non-bug-related messages in this thread. I'd like to reserve it for bug reports only. If you want to start a "I wish" or "let's debate something" discussion, let's put it somewhere else, ok?
Old 5th June 2010, 23:29   #8522  |  Link
8ternity
8ternity's Avatar
Hi jdboos:
Suggestion: Is there a way to set an option to compress more the bonus features and previews to limit size compression for the movie?
If not, can it be a constructive suggestion ?
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 5th June 2010, 23:32   #8523  |  Link
jdobbs
I've had some strangeness happening on my Windows 7 64 bit machine and I'm wondering if anyone else has seen this. When I start an encode with BD Rebuilder (pass 2), my quad-cores are pegged with X264 using 99% of the CPU time as viewed from the Windows Task Manager/Processes dialog. After a short while of running I look at it again and the X264 process is then only at about 70-75% of the CPU time -- and the process SYSTEM ("NT Kernal and System) is using 23-29% of the CPU. My FPS reading on X264 has dropped equivalently.
Why would the system suddenly demand so much of my processor time?
This seems to have started only recently and the same thing happens if I just run X264 from the command line. Any ideas?
Website: www.jdobbs.net
Old 6th June 2010, 00:50   #8524  |  Link
8ternity
8ternity's Avatar
Hi jdboos:
Check with this:
In the process tab; the x264.exe *32 can have a priority changed for each process.
Right click; "Define Priority" i dont know if named like that in english because my windows are in french; and set to normal. You will see that windows have set the priority to "low". I have set to normal and the process stay over 90%.
I don't know why Windows appriopriate "low" priority but i think that is basic from windows to keep using windows for surfing, chat, etc. regular internet used.
Check with that if your process will be corrected.
8ternity
Old 6th June 2010, 00:57   #8525  |  Link
Capsbackup
@jdobbs;
Perhaps the latest .x264? You could try to go back to a previous version of .x264 and see if the results are the same.
Capsbackup is offline   Reply With Quote
Old 6th June 2010, 04:26   #8526  |  Link
DK
DK's Avatar
Does this occur each and every time or only occasionally?
I have experienced that when Seven runs its regular backups it creates heavy cpu load for this task.
For the first pass, however, i have taken it for granted that x264 runs way below full throttle.
DK is offline   Reply With Quote
Old 6th June 2010, 05:06   #8527  |  Link
jdobbs
Every time I run it -- and it happens on more than one disc.
Old 6th June 2010, 05:07   #8528  |  Link
jdobbs
Originally Posted by Capsbackup View Post
@jdobbs;
I went all the way back to r1570 and it acts the same. Weird... I have a bad feeling that one of the recent Windows updates are to blame.
Old 6th June 2010, 06:59   #8529  |  Link
Race Guy
I've had some strangeness happening on my Windows 7 64 bit machine and I'm wondering if anyone else has seen this. When I start an encode with BD Rebuilder (pass 2), my quad-cores are pegged with X264 using 99% of the CPU time as viewed from the Windows Task Manager/Processes dialog. After a short while of running I look at it again and the X264 process is then only at about 70-75% of the CPU time -- and the process SYSTEM ("NT Kernel and System) is using 23-29% of the CPU. My FPS reading on X264 has dropped equivalently.
Using a Q9550 CPU on a Win7/64 machine, I'm doing the 2nd pass of a movie only at highest Q. The bitrate is a little less than 10,000K & I'm getting 6.25fps.
Looking at "Resource Monitor", the CPU is averaging 86+% for x264. The second highest load is "System Interrupts" at 11%. If I look at Task Manager, those two numbers get combined at 97-98% for x264.
My "NT Kernel" is at 0%.
Race Guy is offline   Reply With Quote
Old 6th June 2010, 11:35   #8530  |  Link
pbeumer2001
I have troubles backing up Karate Kid:
[01:40:02] BD Rebuilder v0.33.09 (beta)
- Source: THE_KARATE_KID
- Input BD size: 37,72 GB
- Approximate total content: [02:18:25.225]
- Target BD size: 23,60 GB
- Windows Version: 6.1 [7600]
- One Pass ABR Mode enabled
[01:40:03] PHASE ONE, Encoding
- [01:40:03] Extracting A/V streams [VID_00011]
- [02:03:06] Reencoding: VID_00011 (1 of 3)
- [02:03:06] Collecting video information
- Rate/Length: 23,976fps, 196.674 frames
- Bitrate: 18.255 Kbs
- [02:03:07] Reencoding: VID_00011, Pass 1 of 1
- [11:43:07] Video Encode complete
- [11:43:07] Reencoding audio tracks (if req'd)
- [11:43:07] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00011.meta
- Can't open file: D:\BD REBUILDER\WORKFILES\VID_00011_2.AVS.MKV
[11:43:09] - Failed to build structure, aborted
I disabled the second video stream with the hidden option. The Mux_00011.meta looks like this,
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500
V_MPEG4/ISO/AVC, "D:\BD REBUILDER\WORKFILES\VID_00011.AVS.264", fps=23.976, insertSEI, contSPS
V_MPEG4/ISO/AVC, "D:\BD REBUILDER\WORKFILES\VID_00011_2.AVS.MKV", fps=23.976, track=1, secondary, insertSEI, contSPS
A_DTS, "D:\BD REBUILDER\WORKFILES\00011.track_4352.DTS", lang=eng
S_HDMV/PGS, "D:\BD REBUILDER\WORKFILES\00011.track_4609.sup", lang=nld
pbeumer2001 is offline   Reply With Quote
Old 6th June 2010, 15:33   #8531  |  Link
jdobbs
It turned out to be a heat problem. Apparently there is some safeguard in the system that trys to pull processor time away when the CPU gets hot. I vacuumed out the dust, cleaned off the old hardened heat-transfer goo, and reinstalled the heatsink and it's back to 99% processor for X264 again. Looks good.
[Added note] Wow. I guess this has been building for a while. I'm getting about 30-40% higher speed than I was a couple of weeks ago now. Cool.
Old 6th June 2010, 19:19   #8532  |  Link
gamete
bdrebuilder is it compatible with windows7 64 bit?
gamete is offline   Reply With Quote
Old 6th June 2010, 19:55   #8533  |  Link
jdobbs
Yes. In fact my main video processing computer is running Windows 7 64 bit.
Old 7th June 2010, 04:58   #8534  |  Link
ellusian
Sorry not sure if this is officially a 'bug report' or not...could be, you tell me:
Running a new install of Windows 7 Pro 64-bit (all latest patches/updates), had my BD-Rebuilder 'suite' working flawlessly for months under prev install XP Pro 32-bit on same hardware (Mac Pro quad-core, 10GB RAM, Boot Camp install of OS) along w/ SlySoft apps. Downloaded all the latest versions of the various software components per sticky instructions. Successfully get through all rebuild phases (1&2), but run into an error at the burn stage. Can't seem to get ImgBurn to launch properly to finish the job. Any ideas? I have both BD-Rebuilder and ImgBurn set to 'run as admin', btw. ImgBurn should be compatible w/ Win 7 64-bit--any clues as to errors in install, seemed straightforward before in XP, but I know Win 7 has gotchas I may not be familiar with aside from the admin issues...
Thanks!
UPDATE: ImgBurn launched via help below:
http://bit.ly/c8fRz9
Seems anti-virus that worked fine in XP now creates a conflict in Win7. Hmmm. Pain to have to shut down BitDefender before every BD-Rebuild w/ AutoBurn session, but if it works...
Nope. ImgBurn is not being launched properly from w/in the BD-Rebuilder app... nothing in the ImgBurn Log, either.
Here's are the LOGs:
[00:08:19] BD Rebuilder v0.34.02 (beta)
- Source: WHERE_THE_WILD_THINGS_ARE
- Input BD size: 17.67 GB
- Approximate total content: [01:41:01.930]
- Target BD size: 22.66 GB
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), One Pass
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
- Resuming from previously started job.
[00:08:22] PHASE ONE, Encoding
[00:08:22]PHASE ONE complete
[00:08:22]PHASE TWO - Rebuild Started
- [00:08:22] Rebuilding BD file Structure
[00:18:58] - Encode and Rebuild complete
[00:18:58] BURNING BD structure to disc
- ImgBurn WAS NOT COMPLETED successfully
[00:19:00]JOB: WHERE_THE_WILD_THINGS_ARE finished.
Here is the opening log for manually launched ImgBurn:
I 00:19:39 ImgBurn Version 2.5.1.0 started!
I 00:19:39 Microsoft Windows 7 Professional x64 Edition (6.1, Build 7600)
I 00:19:39 Total Physical Memory: 10,475,556 KB - Available: 8,670,132 KB
W 00:19:39 AnyDVD can interfere with ImgBurn's ability to verify accurately, please ensure it's disabled!
I 00:19:40 Initialising SPTI...
I 00:19:40 Searching for SCSI / ATAPI devices...
I 00:19:40 -> Drive 1 - Info: PIONEER DVD-RW DVR-112D BC14 (E (ATA)
I 00:19:40 -> Drive 2 - Info: ELBY CLONEDRIVE 1.4 (H (SCSI)
I 00:19:40 -> Drive 3 - Info: HL-DT-ST BD-RE GGW-H20N XJ03 (I (USB)
I 00:19:40 Found 1 DVD±RW, 1 BD-ROM/HD DVD-ROM and 1 HD DVD-ROM/BD-RE!
I turned off AnyDVD (much as I hadn't needed to turn off my anti-virus, BitDefender in XP, this is apparently a new needed step in Windows 7 pro 64-bit). Ran BD-Rebuilder once more...
Same result.
Any ideas on what to try next?
Note: Only difference between this Win 7 install and the identical software suite I'm running under my migrated XP Pro partition (running under Parallels on my OSX boot drive, fully functional but slower of course), is that the BD-Rebuilder folder is NOT in the Programs directory (as suggested by the sticky), it's on the Desktop, while ImgBurn is installed in the programs directory.
ellusian is offline   Reply With Quote
Old 7th June 2010, 10:00   #8535  |  Link
jagjockey
Rebuilder hangs computer
Installed v0.34.02 and now it continuously fails at the Disk Rebuild stage. No mater where the original files come from or where the new files are written to eg Sata.Ide.Network. Fails everytime.
PC runs perfectly fine other than this.
Vista 64. 8MB Mem.
jagjockey is offline   Reply With Quote
Old 7th June 2010, 14:04   #8536  |  Link
jdobbs
Vista 64. 8MB Mem.
Logs? Result of INSPECT.EXE?
Does it work to a local drive?
Old 7th June 2010, 14:07   #8537  |  Link
jagjockey
I connected it to a USB HD connected on a USB Bus all by itself and it has now worked. If I put it back to ANY other drive it fails at the Rebuilding stage.
I have to go out for a couple of hours, but I have left it running with the USB dive. so I wiill let you know what happens when I get back.
The previous version worked fine.
Al
Old 7th June 2010, 14:10   #8538  |  Link
jdobbs
Al
I do test backups using local, network, and USB drives. Are you sure your network drivers are correct?
Old 7th June 2010, 15:31   #8539  |  Link
jagjockey
Ok, back now.
The network drives have been working fine for ages.
I am now 50% way thru trying another disk. The one before this worked fine using a USB HD plugged straight into a MB socket.
Old 7th June 2010, 17:42   #8540  |  Link
hasaro
@ jdobbs
This is my new try about THE HANGOVER, I do a BD25 full backup, but the UNRATED VERSION has the audio desync. The teatrical version does not present any problem. I tried all the versions of BD-rebuilder for the last two months. But every backup has the same problem.
13:49:58] BD Rebuilder v0.34.02 (beta)
  - Source:  THE_HANGOVER
  - Input BD size: 37,39 GB
  - Approximate total content: [04:16:27.622]
  - Target BD size: 22,66 GB
  - Windows Version: 6.0 [6001]
[13:49:58] PHASE ONE, Encoding
 - [13:49:58] Extracting A/V streams [VID_00000]
 - [13:56:09] Reencoding: VID_00000 (1 of 18)
 - [13:56:09] Reencoding secondary video [TRK_02]
 - [14:16:06] Collecting video information
   - Source Video: VC-1, 1920x1080
   - Rate/Length: 23,976fps, 143.521 frames
   - Bitrate: 7.666 Kbs
 - [14:16:07] Reencoding: VID_00000, Pass 1 of 2
 - [16:30:30] Reencoding: VID_00000, Pass 2 of 2
 - [21:10:52] Video Encode complete
 - [21:10:52] Reencoding audio tracks (if req'd)
 - [21:10:52] Multiplexing M2TS
 - [21:18:42] Extracting A/V streams [VID_00001]
 - [21:23:36] Reencoding: VID_00001 (2 of 18)
 - [21:23:36] Collecting video information
   - Rate/Length: 23,976fps, 155.209 frames
   - Bitrate: 7.958 Kbs
 - [21:23:36] Reencoding: VID_00001, Pass 1 of 2
 - [23:45:53] Reencoding: VID_00001, Pass 2 of 2
 - [04:39:16] Video Encode complete
 - [04:39:16] Reencoding audio tracks (if req'd)
 - [04:39:16] Multiplexing M2TS
 - [04:46:42] Extracting A/V streams [VID_00004]
 - [04:46:45] Reencoding: VID_00004 (3 of 18)
 - [04:46:45] Collecting video information
   - Rate/Length: 23,976fps, 1.705 frames
   - Bitrate: 6.597 Kbs
 - [04:46:45] Reencoding: VID_00004, Pass 1 of 2
 - [04:48:20] Reencoding: VID_00004, Pass 2 of 2
 - [04:51:19] Video Encode complete
 - [04:51:19] Reencoding audio tracks (if req'd)
 - [04:51:20] Multiplexing M2TS
 - [04:51:22] Extracting A/V streams [VID_00005]
 - [04:51:36] Reencoding: VID_00005 (4 of 18)
 - [04:51:36] Collecting video information
   - Rate/Length: 23,976fps, 11.898 frames
   - Bitrate: 5.969 Kbs
 - [04:51:36] Reencoding: VID_00005, Pass 1 of 2
 - [05:02:20] Reencoding: VID_00005, Pass 2 of 2
 - [05:22:06] Video Encode complete
 - [05:22:06] Reencoding audio tracks (if req'd)
 - [05:22:06] Multiplexing M2TS
 - [05:22:18] Extracting A/V streams [VID_00006]
 - [05:22:30] Reencoding: VID_00006 (5 of 18)
 - [05:22:31] Collecting video information
   - Rate/Length: 23,976fps, 11.419 frames
   - Bitrate: 5.956 Kbs
 - [05:22:31] Reencoding: VID_00006, Pass 1 of 2
 - [05:32:26] Reencoding: VID_00006, Pass 2 of 2
 - [05:54:27] Video Encode complete
 - [05:54:27] Reencoding audio tracks (if req'd)
 - [05:54:27] Multiplexing M2TS
 - [05:54:44] Extracting A/V streams [VID_00007]
 - [05:54:46] Reencoding: VID_00007 (6 of 18)
 - [05:54:46] Collecting video information
   - Rate/Length: 23,976fps, 2.005 frames
   - Bitrate: 5.946 Kbs
 - [05:54:46] Reencoding: VID_00007, Pass 1 of 2
 - [05:56:50] Reencoding: VID_00007, Pass 2 of 2
 - [06:00:43] Video Encode complete
 - [06:00:43] Reencoding audio tracks (if req'd)
 - [06:00:43] Multiplexing M2TS
 - [06:00:45] Extracting A/V streams [VID_00010]
 - [06:00:57] Reencoding: VID_00010 (7 of 18)
 - [06:00:57] Reencoding secondary video [TRK_02]
 - [06:01:55] Collecting video information
   - Rate/Length: 23,976fps, 14.498 frames
   - Bitrate: 1.320 Kbs
 - [06:01:55] Reencoding: VID_00010, Pass 1 of 2
 - [06:12:59] Reencoding: VID_00010, Pass 2 of 2
 - [06:26:58] Video Encode complete
 - [06:26:58] Reencoding audio tracks (if req'd)
 - [06:26:58] Multiplexing M2TS
 - [06:27:01] Extracting A/V streams [VID_00012]
 - [06:27:04] Reencoding: VID_00012 (8 of 18)
 - [06:27:04] Collecting video information
   - Rate/Length: 23,976fps, 2.511 frames
   - Bitrate: 6.164 Kbs
 - [06:27:04] Reencoding: VID_00012, Pass 1 of 2
 - [06:29:34] Reencoding: VID_00012, Pass 2 of 2
 - [06:34:27] Video Encode complete
 - [06:34:27] Reencoding audio tracks (if req'd)
 - [06:34:27] Multiplexing M2TS
 - [06:34:30] Extracting A/V streams [VID_00013]
 - [06:34:32] Reencoding: VID_00013 (9 of 18)
 - [06:34:32] Collecting video information
   - Rate/Length: 23,976fps, 1.729 frames
   - Bitrate: 6.260 Kbs
 - [06:34:32] Reencoding: VID_00013, Pass 1 of 2
 - [06:36:13] Reencoding: VID_00013, Pass 2 of 2
 - [06:39:36] Video Encode complete
 - [06:39:36] Reencoding audio tracks (if req'd)
 - [06:39:36] Multiplexing M2TS
 - [06:39:38] Extracting A/V streams [VID_00015]
 - [06:39:41] Reencoding: VID_00015 (10 of 18)
 - [06:39:41] Collecting video information
   - Rate/Length: 23,976fps, 2.714 frames
   - Bitrate: 6.128 Kbs
 - [06:39:41] Reencoding: VID_00015, Pass 1 of 2
 - [06:42:12] Reencoding: VID_00015, Pass 2 of 2
 - [06:47:17] Video Encode complete
 - [06:47:17] Reencoding audio tracks (if req'd)
 - [06:47:17] Multiplexing M2TS
 - [06:47:20] Extracting A/V streams [VID_00016]
 - [06:47:23] Reencoding: VID_00016 (11 of 18)
 - [06:47:23] Collecting video information
   - Rate/Length: 23,976fps, 2.320 frames
   - Bitrate: 6.496 Kbs
 - [06:47:23] Reencoding: VID_00016, Pass 1 of 2
 - [06:49:26] Reencoding: VID_00016, Pass 2 of 2
 - [06:53:49] Video Encode complete
 - [06:53:49] Reencoding audio tracks (if req'd)
 - [06:53:49] Multiplexing M2TS
 - [06:53:52] Extracting A/V streams [VID_00017]
 - [06:53:55] Reencoding: VID_00017 (12 of 18)
 - [06:53:55] Collecting video information
   - Rate/Length: 23,976fps, 2.233 frames
   - Bitrate: 6.045 Kbs
 - [06:53:55] Reencoding: VID_00017, Pass 1 of 2
 - [06:56:05] Reencoding: VID_00017, Pass 2 of 2
 - [07:00:30] Video Encode complete
 - [07:00:30] Reencoding audio tracks (if req'd)
 - [07:00:30] Multiplexing M2TS
 - [07:00:32] Extracting A/V streams [VID_00020]
 - [07:00:36] Reencoding: VID_00020 (13 of 18)
 - [07:00:36] Collecting video information
   - Rate/Length: 23,976fps, 2.917 frames
   - Bitrate: 5.591 Kbs
 - [07:00:36] Reencoding: VID_00020, Pass 1 of 2
 - [07:02:59] Reencoding: VID_00020, Pass 2 of 2
 - [07:07:22] Video Encode complete
 - [07:07:23] Reencoding audio tracks (if req'd)
 - [07:07:23] Multiplexing M2TS
 - [07:07:25] Extracting A/V streams [VID_00026]
 - [07:07:30] Reencoding: VID_00026 (14 of 18)
 - [07:07:30] Collecting video information
   - Rate/Length: 23,976fps, 3.444 frames
   - Bitrate: 6.379 Kbs
 - [07:07:30] Reencoding: VID_00026, Pass 1 of 2
 - [07:10:28] Reencoding: VID_00026, Pass 2 of 2
 - [07:16:30] Video Encode complete
 - [07:16:30] Reencoding audio tracks (if req'd)
 - [07:16:30] Multiplexing M2TS
 - [07:16:33] Extracting A/V streams [VID_00027]
 - [07:16:37] Reencoding: VID_00027 (15 of 18)
 - [07:16:37] Collecting video information
   - Rate/Length: 23,976fps, 3.460 frames
   - Bitrate: 6.330 Kbs
 - [07:16:37] Reencoding: VID_00027, Pass 1 of 2
 - [07:19:54] Reencoding: VID_00027, Pass 2 of 2
 - [07:26:25] Video Encode complete
 - [07:26:25] Reencoding audio tracks (if req'd)
 - [07:26:25] Multiplexing M2TS
 - [07:26:29] Extracting A/V streams [VID_00028]
 - [07:26:32] Reencoding: VID_00028 (16 of 18)
 - [07:26:32] Collecting video information
   - Rate/Length: 23,976fps, 3.312 frames
   - Bitrate: 6.291 Kbs
 - [07:26:33] Reencoding: VID_00028, Pass 1 of 2
 - [07:29:36] Reencoding: VID_00028, Pass 2 of 2
 - [07:35:57] Video Encode complete
 - [07:35:57] Reencoding audio tracks (if req'd)
 - [07:35:57] Multiplexing M2TS
 - [07:36:00] Extracting A/V streams [VID_00029]
 - [07:36:02] Reencoding: VID_00029 (17 of 18)
 - [07:36:02] Collecting video information
   - Rate/Length: 23,976fps, 1.138 frames
   - Bitrate: 6.470 Kbs
 - [07:36:02] Reencoding: VID_00029, Pass 1 of 2
 - [07:37:00] Reencoding: VID_00029, Pass 2 of 2
 - [07:39:02] Video Encode complete
 - [07:39:02] Reencoding audio tracks (if req'd)
 - [07:39:02] Multiplexing M2TS
 - [07:39:03] Extracting A/V streams [VID_00030]
 - [07:39:07] Reencoding: VID_00030 (18 of 18)
 - [07:39:07] Collecting video information
   - Rate/Length: 23,976fps, 2.901 frames
   - Bitrate: 7.043 Kbs
 - [07:39:07] Reencoding: VID_00030, Pass 1 of 2
 - [07:41:36] Reencoding: VID_00030, Pass 2 of 2
 - [07:46:32] Video Encode complete
 - [07:46:32] Reencoding audio tracks (if req'd)
 - [07:46:32] Multiplexing M2TS
[07:46:35]PHASE ONE complete
[07:46:35]PHASE TWO - Rebuild Started
 - [07:46:35] Rebuilding BD file Structure
[07:47:04] - Encode and Rebuild complete
 - WORKFILES folder removed.
[07:47:05]JOB: THE_HANGOVER finished.
[Status]
LABEL=THE_HANGOVER
VERSION=v0.34.02 (beta)
SOURCE_SIZE=40152130398
SOURCE_VIDEO_SIZE=39101546496
TARGET_SIZE=24326963200
REDUCTION=.595280273642914
RESIZE_1080=0
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=18
REBUILD_COMPLETE=1
[00000]
AUDIO=11111
PGS=1111111
M2TS_TARGET=10924506167
RATE=7666
NSIZE=10651656192
FLINK=0
MLINK=0
[00001]
AUDIO=11
PGS=1111
M2TS_TARGET=10176417504
RATE=7958
NSIZE=9861249024
FLINK=0
MLINK=0
[00004]
AUDIO=1
PGS=1111
M2TS_TARGET=67226706
RATE=6597
NSIZE=65427456
FLINK=0
MLINK=0
[00005]
AUDIO=1
PGS=1111
M2TS_TARGET=424313493
RATE=5969
NSIZE=416704512
FLINK=0
MLINK=0
[00006]
AUDIO=1
PGS=1111
M2TS_TARGET=408879257
RATE=5956
NSIZE=402296832
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=1111
M2TS_TARGET=71970357
RATE=5946
NSIZE=71442432
FLINK=0
MLINK=0
[00010]
AUDIO=11
PGS=
M2TS_TARGET=137485399
RATE=1320
NSIZE=140888064
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=1111
M2TS_TARGET=93040650
RATE=6164
NSIZE=91373568
FLINK=0
MLINK=0
[00013]
AUDIO=1
PGS=1111
M2TS_TARGET=64933515
RATE=6260
NSIZE=64057344
FLINK=0
MLINK=0
[00015]
AUDIO=1
PGS=1111
M2TS_TARGET=100227444
RATE=6128
NSIZE=98199552
FLINK=0
MLINK=0
[00016]
AUDIO=1
PGS=1111
M2TS_TARGET=91255837
RATE=6496
NSIZE=89382912
FLINK=0
MLINK=0
[00017]
AUDIO=1
PGS=1111
M2TS_TARGET=82313489
RATE=6045
NSIZE=80209920
FLINK=0
MLINK=0
[00020]
AUDIO=1
PGS=1111
M2TS_TARGET=98373142
RATE=5591
NSIZE=97185792
FLINK=0
MLINK=0
[00026]
AUDIO=1
PGS=
M2TS_TARGET=127237358
RATE=6379
NSIZE=125122560
FLINK=0
MLINK=0
[00027]
AUDIO=1
PGS=
M2TS_TARGET=126871618
RATE=6330
NSIZE=124446720
FLINK=0
MLINK=0
[00028]
AUDIO=1
PGS=
M2TS_TARGET=120730840
RATE=6291
NSIZE=118548480
FLINK=0
MLINK=0
[00029]
AUDIO=1
PGS=
M2TS_TARGET=42623363
RATE=6470
NSIZE=42141696
FLINK=0
MLINK=0
[00030]
AUDIO=1
PGS=
M2TS_TARGET=117973159
RATE=7043
NSIZE=115998720
FLINK=0
MLINK=0
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3133, Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD Rebuilder v0.34.0.2, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
hasaro is offline   Reply With Quote
