Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 2nd July 2017, 23:34   #1  |  Link
jriker1
Scenarist SD jump immediately
I have a custom menu for a DVD that I want it to jump between the two images when I go up and down with the remote between menus. Trying to create a graphical set of selected buttons and not the standard primary color subscene process. So have two BMP files, one has one menu button highlighted with a glowing gradient, (start movie) the second BMP has the other button highlighted with a glowing gradient (chapter selection). I want my menu's to do the following:
1. When I am on Start Movie I want it to do nothing.
2. When I move down to chapter selection I want it to load the other BMP that has the Chapter Selection highlighted. Want this automatically.
3. If I move up to the Start Movie button I want it to automatically go to the first menu. If I physically click on either button want it to either start the movie or just to the Chapter Selection depending on which button I've highlighted.
Any help would be appreciated. Guess trying to understand how to have something take an immediate action when a particular button is highlighted but not pressed, vs pressing the OK button and having an action taken on the button.
Thoughts?
JR
jriker1 is offline   Reply With Quote
Old 3rd July 2017, 11:05   #2  |  Link
kolak
Look at auto action (or auto activate option- don't remember exact name). There is such a thing and when you select it button will be executed automatically.
It's not used a lot for actual navigation as it's very confusing for the user.
Old 5th July 2017, 01:23   #3  |  Link
jriker1
Thanks Kolak. Those terms were good enough to find what I was looking for!!!
JR
Old 25th August 2017, 11:06   #4  |  Link
neil wilkes
neil wilkes's Avatar
How are you managing gradients on buttons when we are restricted to 3 colours?
Just very curious on this, although I understand if you do not want to spill the beans!
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 29th August 2017, 19:22   #5  |  Link
mp3dom
He's using two different bitmaps so he don't have a real selection but an auto-action that jump to the other page
Old 29th August 2017, 23:11   #6  |  Link
jmsmarcelo
jmsmarcelo's Avatar
Hello, Take a look at this preview I made, see if it's what you're looking for:
https://www.youtube.com/watch?v=PFM6r9nJwmA
I will be posting more previews on that other channel about DVD/Bluray authoring with Scenarist:
https://www.youtube.com/channel/UCqs48R7J2FdkV1E6k4Kr0cw
jmsmarcelo is offline   Reply With Quote
Old 30th August 2017, 08:11   #7  |  Link
neil wilkes
Understood.
We did that for one disc, and it turned out looking great visually but really clunky to use and performance definitely varied across players. In our case it was an arm in a sleeve with a pointing finger going down a tracklist.
