10th October 2010, 21:48 | #1 | Link |
x264 10bit-depth
hello,
today a 10 bit backend was presented. I wanted to ask if I can replace this backend with current x264, and furthermore if 10bit backend adds some quality to video, or will the video be bigger only without additional quality? Mostly I encode from DVD and DVB(MPEG2). |
11th October 2010, 03:12 | #3 | Link |
Derek Prestegard IRL
Hi Anakunda,
10 bit is a tricky thing. Here are the main talking points currently, as I see them: (Take these with a grain of salt, as I'm not terribly knowledgable or experienced WRT 10 bit x264!) 1) 10 bit H.264 can only be decoded by payware decoders currently, like Mainconcept. 2) 10 bit encoding is best used with 10 bit sources, of which there are certainly none available to the average consumer 3) 10 bit gives better quality at the same bitrate AFAIK, due to greater precision 4) 10 bit is extremely slow currently, because ASM optimizations haven't been committed to the GIT yet. This WILL happen eventually So, my advice would be to skip it for now. This will certainly change in the future!! Derek
These are all my personal statements, not those of my employer :) |
11th October 2010, 06:02 | #6 | Link | |
11th October 2010, 06:15 | #7 | Link | |
x264 developer
Of course, widespread adoption will depend on libavcodec getting 10-bit support. |
11th October 2010, 09:05 | #9 | Link | |
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
11th October 2010, 18:56 | #15 | Link |
Software Developer
As the do not use GPU programs (shaders), which probably could be updated, but "hardwired" decoder chips integrated on the graphics board, which can not be updated, new hardware will be nedded
11th October 2010, 20:02 | #16 | Link |
Mr. Sandman
..why not add gradfun (in addition to the standard deblock) into the decoder specs? it would save a lot of headaches...
30th October 2010, 00:12 | #17 | Link |
What colorspace should be used for 10-bit encoding in x264? I have some 4:2:2 sources, but when I run them through they're being converted to yuv420.
x264_10 --pass 1 --preset veryslow --tune film --profile high10 --bitrate 30000 --stats ".stats" --keyint 96 --thread-input --sar 1:1 --output NUL "test.avs"avs [info]: 1920x1080p 1:1 @ 29970000/1250071 fps (cfr) resize [warning]: converting from yuyv422 to yuv422p resize [warning]: converting from yuv422p to yuv420p......... Last edited by UltraTV; 30th October 2010 at 00:12. Reason: added some info |
30th October 2010, 00:16 | #18 | Link |
x264 only supports 4:2:0
31st October 2010, 04:46 | #20 | Link |
actually DS perhaps you might ask Francois about the SB Decoder ?, i think it will/might, as its not a fixed ASIC fixed-function decoding device such as NV and amd seem to use now, and he could probably work it into the patch if not already there somehow if it ever goes through.
