5th January 2021, 16:23 | #1201 | Link |
Well, I asked for this because I use rather old version 1.6.8.7417 to playback movies on my tv. The reason for this is that this version is the last one which can be configured to have the player UI permanently on the first monitor while playing the fullscreen movie ( rendered by MadVR and the D3D Fullscreen option ticked ) on the second monitor, which is my tv. And this version does not have the "High precision" feature. All later versions have the D3D Fullscreen option greyed out when using MadVR.
In addition I use the actual 1.98 because there are a lot of improvements, but I never recognized the "high precision" option, which is very usefull when editing a video. |
5th January 2021, 20:28 | #1203 | Link |
I know that D3D exclusive mode can be enabled within the madVR settings. The reason to use the rather old version 1.6.8 is some kind of "side effect" of the "old" D3D setting within mpc-hc, which was no longer possible after 1.6.8. I like the configuration to have the main MPC-HC window with all the menus and controls always on the first monitor, and only the video output itself, when switched to fullscreen, is moved to the second monitor.
For clarification you might have a look here: https://forum.doom9.org/showthread.p...22#post1746922 |
8th January 2021, 09:54 | #1204 | Link |
When a .avs script with a syntax error is opened, mpc-hc displays a black frame with the "Cannot render the file" status bar message.
Would it be possible to catch and display the Avisynth exception if avisynth is installed ? This is the mpv output (in virtualdub2 you get a pop-up error message): [ffmpeg/demuxer] avisynth: I don't know what 'jhjklhl' means. [ffmpeg/demuxer] (B:\avs\test_version.avs, line 6) [lavf] avformat_open_input() failed Failed to recognize file format. Exiting... (Some errors happened)
bShaders: realtime Effects/filters for video players Last edited by butterw2; 8th January 2021 at 09:57. |
10th January 2021, 07:34 | #1208 | Link |
mp4's rotation meta tag doesn't work if the renderer is set to mpc-vr.
manual rotation with alt+numpad works though. all the other renderers which support rotation, evr-cp/sync/madvr/vmr9renderless seem to work. tried mpc-be with the same filter set and it works fine. my mpc-be/mpc-hc/mpc-vr are all latest dev versions. |
11th January 2021, 19:37 | #1213 | Link |
Rotation with MPCVR has been fixed.
Audio dithering only happens when the audio is decoded as 24 or 32-bit and the audio device/renderer only supports 16-bit. So it rarely happens and dithering is actually good for quality. Only reason to disable it is for performance if you have an ancient computer with super slow processor. |
15th January 2021, 15:31 | #1216 | Link |
@alleway:
See second note here: AMD, Intel and Nvidia driver issues and last recommended version |
15th January 2021, 16:49 | #1218 | Link | ||
VSync is the first step mentioned in my post, so ... |
21st January 2021, 17:11 | #1219 | Link |
Soul Seeker
clsid, thank you for the support of mpc-hc, I was wondering if it is not being asked, but could you make previews in the seekbar like in mpc-be and potplayer. It will be easier to navigate through a movie.
