16th August 2020, 13:20 | #1021 | Link | |
It correctly saves a the original size here. It may depend on the video renderer that is used. For example madVR has its own screenshot options. |
16th August 2020, 15:56 | #1022 | Link |
Use the EVR-CP video renderer for example, not the EVR.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
18th August 2020, 19:16 | #1024 | Link |
Inputting a Twitch VOD URL to watch it with Youtube-DL has broken recently.
Using Youtube-DL in CLI will download the video just fine. But with MPC-HC it generates a playlist of hundreds of .ts files that are cycled through in quick succession, all marked "invalid". Edit: Looking at MPC-HC Issues on Github, I am assuming all the M3U stuff will already fix this? If so, I hope we can get a new version soon! Last edited by Schwartz; 18th August 2020 at 19:28. |
18th August 2020, 21:39 | #1025 | Link |
That is already fixed in latest development build:
https://github.com/clsid2/mpc-hc/releases/tag/1.9.6.7 |
21st August 2020, 22:50 | #1026 | Link |
I have been using MPC-HC for years without any problems. I am currently on its latest version, 1.9.7. And I use it combined with LAV Splitter and FFDShow (clsid) also its latest versions. I use nVIDIA GTX 650 Ti 2GB video card.
Always leave MPC-HC set to "Playback Ouput >>> DirectShow >>> System Default" because the image rendering looks smoother and more pleasant when I make image adjustments by FFDShow. But I have noticed that since the nVIDIA 451.48 drivers, MPC-HC no longer works normally with "System Default". Now the video images look darker and too sharped than before, as if this were using "Enhanced Video Rendered (custom presenter)", now notice that this setting is the default. The problem with this is that my FFDSHOW presets of videos with my own settings now look really bad, because these were intended for "System Default", as this rendered before, and it is a real hell to have to recalibrate the color settings in each video again. Is there any way to set MPC-HC to re-render "Playback Ouput >>> DirectShow >>> System Default" as it did before? Or is it a bug in the nVIDIA drivers? It only happens with MPC-HC, the videos in the browser look normal, which I suspect may be the video player. |
22nd August 2020, 00:23 | #1027 | Link |
System Default does not mean what you think it means. It is not the recommended video renderer, nor is it the default setting of MPC-HC (default is EVR-CP). It is the default used by Windows for basic DirectShow applications. It equals the ancient "Video Mixing Renderer 7" which dates from Windows XP era. Basically it is one of the oldest and worst renderers available. It is default in Windows for backwards compatibility reasons only.
Your browser does not use DirectShow at all, so it doesn't use this old renderer. Windows Media Player uses "Enhanced Video Renderer". But to answer the question. If it doesn't work if may be the fault of your driver. It is certainly not the fault of MPC-HC. You should switch to EVR-CP. I also advice to get rid of ffdshow as it is totally outdated and unnecessary. |
22nd August 2020, 01:17 | #1028 | Link | |
OK. I will abandon FFDShow, but you have to recommend me an equally advanced set of filters that have: Posprocessing to clean macroblocks, Picture Properties for color control, Levels to contrast control, Blur & NR to clean image, Sharpen (with unsharp mask, asharp and swscaler ), Warpsharp, and Resize & Aspect with all its advanced settings, as has FFDShow. All managed by presets that know how to identify video conditions to auto-set presets. FDDSHOW will be old, but I have not seen in image quality control something so good with this. It even has audio quality control. It is too good and efficient to abandon this. It gave me optimal results. |
22nd August 2020, 01:41 | #1029 | Link |
Color controls:
Options > Miscellaneous Sharpen: Menu > Play > Shaders > LumaSharpen or Sharpen Complex 2 Resizing is done automatically by the video renderer. Doing it with ffdshow is pointless and can reduce quality. Aspect ratio can be modified in MPC-HC menu. |
22nd August 2020, 03:17 | #1031 | Link | ||
FFDShow still has much better filters and allows advanced control ... in fact it's amazing. Automatic resizing alters the sharpen balance in the videos, I never allow the window to do that automatically, it destroys the balance I achieve. Anyway, I'll keep using FFDShow until one day it stops working ... I see that everything tends to be more basic nowadays. A shame. It was a great idea. |
24th August 2020, 16:06 | #1032 | Link |
If you want good video post-processing, may I suggest madVR?
It has a lot of filter options, and a GPU is much more optimized for that kind of thing than a CPU ever will be. The only thing I wish it could do is dynamically adapt the strength of some filters depending on the source quality (based on codec + bits/pixel), but you'd need close integration with the source decoder for that. I don't know what software to replace FFDShow for audio though.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
26th August 2020, 18:55 | #1037 | Link |
I don't recommend using QuickTime and RealMedia frameworks in DirectShow players. These frameworks perform very poorly.
26th August 2020, 23:05 | #1039 | Link |
They aren't available in x64. Only the options are still visible because GUI is identical for x86 and x64 version. But they do not have any effect. I plan to remove the options and frameworks completely in an upcoming version.
