22nd March 2014, 22:47 | #25241 | Link | ||
Kid for Today
IIRC this is the article that led me to believe that DXVA would play nicer in mVR over 3.0:
23rd March 2014, 03:55 | #25244 | Link | |
23rd March 2014, 08:38 | #25247 | Link | |
Completely default madVR settings with madVR smooth motion enabled in Zoom Player. I also set my display to 60 Hz. I don't see any odd usage spikes in GPU, CPU, or IO meters. SLI off. |
23rd March 2014, 09:18 | #25249 | Link |
Those all improve motion quality instead of picture quality which seems like a similar goal to me.
@madshi Is this something easy to implement and actually worth it? I like profiles a lot but I would like the ability to multiply in the if statement or maybe a single new variable instead, pixels-per-second. This would help a lot with lower resolution interlaced material, I want to set higher neuron counts for 480p30 than 480p60 but I also don't want very complex or numerous if statements. I could use the pixels-per-second instead of width, height, and deintfps so 480p60 would automatically use my 720p30 profile and 720p60 would automatically use my 1080p30 profile. |
23rd March 2014, 10:17 | #25250 | Link |
First and last aren't exclusive to madVR. Pretty much any decent video player will have them, including MPC-HC out of the box. Smooth motion does more harm to the picture than good (IMO). I use IVTC all the time, very handy. Anyways...
23rd March 2014, 15:41 | #25251 | Link |
i just upgraded my GPU from a 5750 to a 280x but my motherboard is a PCI-E 2.0 and when i tried NNEDI3 "64 neurons" it cant handle it but its ok at "32 neurons", material is 1080p24 High-Bitrate and ffdshow is set to output 16bit P016. Could that be that my PCI-E is to slow? Do i need to upgrade? I'm very bad at all this but i really try to learn..
lost frames seems to be way better with P016 then at RGB32 if that makes any sense..... but i get artifacts in windows when i use P016 and NNEDI13.
Gigabyte G1.Sniper Z87, I7 4770K (3.5ghz), Gigabyte Radeon 280x, Win8.1 x64, ATI 15.7.1, MPC-HC BE 1.4.6 1478, MadVR v0.90.21, LAV Filters 0.68.1, XySubFilter 3.1.0.746 |
23rd March 2014, 16:18 | #25252 | Link |
madshi, what are your thoughts on using sharpening filters in combination with nnedi doubling? nnedi gives a very nice, sharp, artifact and ringing/aliasing free picture, but I still prefer a bit more sharpness for 720p->1080p scaling. I'm using LumaSharpen at very low values pre-resize, just enough to take out the little bit of softness that is left over from upscaling, nothing more. I think the picture looks pretty much perfect, but I'm wondering if this works against nnedi at all or its just one of those things "do what you think looks best".
23rd March 2014, 16:29 | #25253 | Link |
@StinDaWg:
When you sharpen something, you basically add ringing. Other than that, it's all personal preference. Personally, I always use luma doubling in combination with Lanczos 8 AR, which gives me an incredibly sharp and still mostly artifact-free result. I'm also using 1080p as an output device. |
23rd March 2014, 16:50 | #25254 | Link | |
23rd March 2014, 17:02 | #25256 | Link |
NNEEDI is it's own algorithm, but in combination with Lanczos 8 AR, you get the sharpest results, because Lanczos 8 AR is very sharp to begin with. That's only for upscaling purposes though, I still use Catmull-Rom linear light for downscaling.
23rd March 2014, 17:12 | #25257 | Link |
I tried L8AR/CRAR and L8AR/L8AR and still prefer using LumaSharpen pre-resize. It takes out the softness better than Lanczos scaling alone. One thing is for certain though. nnedi is way better than Jinc when it comes to sharpness/ringing/artifacts.
I'm using Code:
#define sharp_strength 0.5 #define sharp_clamp 0.05 #define pattern 3 |
23rd March 2014, 17:22 | #25258 | Link | |
With madshi's AR algorithm, possibly even NNEDI could be improved, which I suggested before. But we would need to test that. And yes, I also prefer NNEDI (but NNEDI only works for powers of 2) > Lanczos AR > Jinc AR. But I expect that to be highly dependent on the content and your display setup. And of course, your personal preference. Last edited by iSunrise; 23rd March 2014 at 17:30. |
