Old 14th January 2018, 08:54   #22421  |  Link
nevcairiel
I don't have any plans to do that anytime soon. I don't believe I even have any disc which uses that. Most discs with localized video I have seen used different titles instead of Angles.
Old 14th January 2018, 11:09   #22422  |  Link
nevcairiel
Originally Posted by fluffy01 View Post
Ok. If you want me to try out some test builds with some extended logging, so perhaps it can be easier to see what is going wrong, then I can do that for you.
I could reproduce the problem on a disc with an Intel GPU, unfortunately it appears to be a long-standing Intel issue that can result in the GPU reporting a "busy" state infinitely, causing decoding to just die. So for the time being, i've turned off hardware accelerated decoding again.
Old 14th January 2018, 12:31   #22423  |  Link
fluffy01
Ok thanks. I will test it as soon as the next nightly is up.
fluffy01 is offline   Reply With Quote
Old 14th January 2018, 19:04   #22424  |  Link
bisse
Yes I know. I have a large Bluray library and these from GKIDS are the first ones I've come across that uses this feature. Unfortunately I've already purchased 14 of them. I suppose the only solution right now is to rip all the corresponding mt2s into a single MKV. It just feels wrong seeing names like Gillian Anderson and the Fanning sisters in the credits of a Studio Ghibli film.
Does anyone know of any other solution? My only requirement is madvr.
bisse is offline   Reply With Quote
Old 15th January 2018, 14:35   #22425  |  Link
fluffy01
Just tested the new nightly, and it works again Thank you.
Old 17th January 2018, 08:54   #22426  |  Link
runner
hi, I would like to know if lavsplitter supports parsing bduhd, thanks
runner is offline   Reply With Quote
Old 17th January 2018, 09:31   #22427  |  Link
sneaker_ger
Next version will have (limited) UltraHD Blu-ray support. You can already test it if you install the nightly build.
Old 17th January 2018, 15:41   #22428  |  Link
BDFan
Hi nevcairiel!
1. D3D11 doesn't work with the nVidia Optimus on Intel GPU if in the control panel nVidia selected GPU nVidia.
http://i99.fastpic.ru/big/2018/0117/...fb41dc2bf4.jpg
DXVA Checker shows that d3d11 enable on Intel GPU if in the control panel nvidia selected GPU nVidia.
http://i99.fastpic.ru/big/2018/0117/...8582c9261e.jpg
2. nVidia CUVID doesn't work with the nVidia Optimus if in the control panel nvidia selected any GPU.
3. After install LAV 0.70.2.88 mvc (software mode) doesn't work with the nVidia Optimus if in the control panel nvidia selected any GPU.
Windows 10 1709, Intel i5-4200M, Intel(R) HD Graphics 4600 (20.19.15.4835), NVIDIA GeForce 840M (23.21.13.9065)
BDFan is offline   Reply With Quote
Old 17th January 2018, 15:54   #22429  |  Link
madshi
I hate Optimus.
Old 17th January 2018, 16:32   #22430  |  Link
nevcairiel
Optimus is generally just not supported. Use it at your own discression, but don't expect anything to work. I do not provide support for such setups because they are impossible.
Old 17th January 2018, 22:26   #22431  |  Link
BDFan
I hate Optimus.
madVR works great with Optimus, but only in 2D
On Intel GPU - 3D is slide show and later crush Intel driver.
On nVidia GPU - 3D doesn't work.
madVR or LAV Filters bugs?
Old 17th January 2018, 22:27   #22432  |  Link
P.J
Δ
Originally Posted by BDFan View Post
Hi nevcairiel!
Wish I could use Optimus too...
P.J is offline   Reply With Quote
Old 17th January 2018, 22:35   #22433  |  Link
nevcairiel
LAV has no control over what hardware is available. It'll just try to use it. If its unavailable due to Optimus, there is nothing I can do about that.
Just leave DXVA2-CB or D3D11 in "auto" mode and let it pick the device, it'll try to find one that works, I hope.
Old 17th January 2018, 22:45   #22434  |  Link
SamuriHL
SamuriHL's Avatar
I have optimus, too, and I can get it to work well enough for 2D. It's not a well implemented technology so any issues you have with it are not going to be things LAV and madvr are going to solve. Bug MS, nVidia, and Intel.
Old 17th January 2018, 22:45   #22435  |  Link
BDFan
Intel Quick Sync works...
Old 17th January 2018, 23:00   #22436  |  Link
BDFan
Only on Intel GPU works (if in the nVidia control panel selected Intel GPU).
But Intel GPU is slow for madVR
Old 18th January 2018, 00:49   #22437  |  Link
hubblec4
Matroska find' ich toll
The first way is like you said, an mkv. With my chapterEditor is it an easy task and should be done in less then 15min(depend on your hardware).
The second way: You can manipulate the mpls with BDEdit. Make a copy before!
Multi-Angle mpls works similar to Multi-Edition BDs, different m2ts files are used for different Angles/Editions.
Find out which m2ts files belongs to the Angle you want.
I'm not an expert in BDEdit but it should be possible to change the "main" playlist of an Angle-mpls.
hubblec4 is offline   Reply With Quote
Old 18th January 2018, 06:58   #22438  |  Link
yukinok25
I hate Optimus.
You have no idea how much I would like to scream this to Intel!
Sent from my HTC 10 using Tapatalk
yukinok25 is offline   Reply With Quote
Old 18th January 2018, 12:01   #22439  |  Link
el Filou
el Filou's Avatar
If you select the NVIDIA GPU for MPC-HC and then choose DXVA2 Copy-Back or D3D11 and select the HD 4600 in LAV, what happens? madVR still uses the Intel for rendering?
Old 18th January 2018, 14:38   #22440  |  Link
BDFan
Read my first post.
D3D11 should theoretically work (see image DXVA Checker).
No. NVIDIA GPU active.
