19th August 2007, 14:34 | #1841 | Link |
That is the thing, I do not want to use ffdshow for raw video as it will load for everything including videos where I do not want to use FFDShow. I want it to only load for the codecs I pick on the codec page but still have the ability to use it only for h264 material as I do not use ffdshow for h264. It's hard for me to explain so I will try to break down the scenario I am facing..
Playback software: Mediaportal (EVR) or MPC EVR (not custom presenter mode as I cannot get acceleration in it) Source files: h264, WMV, and xvid in MKV all with subtitles, Live and recorded mpeg2 .ts from the tuner with no subtitles and DXVA2 acceleration with deinterlacing. My options are 1) use VMR9 and rely on the haali splitter/playback program to load VSFilter if needed which works and not use FFDShow for subtitles at all. 2) use EVR (preferred) in which VSFilter refuses to load, no subtitles for h264 material as I am using CoreAVC and not FFDShow. 3) Set FFDShow to decode raw video making it always load thus breaking DXVA for my mpeg2 in both VMR9 and EVR. 4) Set FFDShow to decode h264 which is not an option as a good chunk of my source material is too tough for it to decode on my HTPC. What I am looking to do is to either force ffdshow to load as an additional filter only for the h264 material which I can't figure out how to do within the limitations of the media playback programs I use, or find out if it is possible to have ffdshow load an external codec internally similar to how it loads xvid or WMV9 so that it wont interfere with my mpeg2 TV decoding and I could enable h264 on the ffdshow codec page. Thank you very much for the replies so far though, I realize it might not be a very common situation and appreciate the help! Edit: Hmm after doing some messing with it I think I can get it working like I'm asking if I set raw video to all YUV so it ignores NV12. Hopefully it doesn't interfere with hardware deinterlaced but software decoded YUY2 files but I don't expect to run into that often I was under the impression loading it as a raw filter after the decoding was what was messing up vsfilter in EVR but I guess it's the subtitle pin connection that is doing it. Last edited by sarvatt; 19th August 2007 at 14:58. |
19th August 2007, 19:29 | #1842 | Link | |
FWIW, I've tried another FLAC decoder and fed that decoder's output into ffdshow's raw audio filter (because that decoder's 8 channel output was not accepted by any other filter). There the same problem occurs. I'm not sure, it could be that the other decoder has the same problem. Or maybe ffdshow *generally* stumbles with 8 channels? |
19th August 2007, 20:31 | #1843 | Link | |
make sure disable any audio filter before abx anyone can comfirm this? the lavc decoded sample u uploaded does show somekind of high frequency loss. sounds like it was downsampled by ffdshow resampler or FIR filter. |
19th August 2007, 21:12 | #1844 | Link | |
See Thread before: http://forum.doom9.org/showthread.ph...11#post1032411 and http://ffdshow-tryout.sourceforge.ne...opic.php?t=429 |
19th August 2007, 23:56 | #1845 | Link |
Mr. Sandman
Vista? Is that an OS?
20th August 2007, 01:11 | #1846 | Link | |
李姗倩 Lǐ Shān Qiàn
-baka me! |
21st August 2007, 16:48 | #1847 | Link |
I think the "DVD decoding (not working yet)" string in ffdshow should be updated. What exactly works and what works not with regard to DVD decoding by ffdshow? Is it only decryption that isn't supported?
MPC-HC 2.2.1 |
21st August 2007, 20:58 | #1848 | Link |
i think i found a bug which hasn't been mentioned (searched but found nothing)
there's something wrong with the SPDIF setting: works fine when i use this, i hear sound on my receiver: ffdshow_rev1371_20070723_clsid.exe doesn't work when i use the latest (i tried these), i don't hear sound on my receiver: ffdshow_rev1425_20070817_xxl.exe ffdshow_rev1431_20070821_clsid_sse_icl10.exe everything else on the graph is kept the same of course (same player, same filters, exact same settings, same files, same drivers, etc....) i'm not a programmer, so i have no idea what has changed since the rev1371 release and rev1431 release... but surely something HAS changed relating to AC3/DTS SPDIF |
21st August 2007, 23:00 | #1849 | Link |
This might have been fixed at rev1432:
http://ffdshow-tryout.svn.sourceforg...yout/?view=log
MPC-HC 2.2.1 |
23rd August 2007, 15:27 | #1850 | Link |
Angel of Night
sarvatt, buy Zoom Player Pro and set up customized media profiles. That way you can force everything to be decoded and played exactly how you want.
I'm curious about the possibility of adding coreavc as an 'alternative' codec, if it's not complicated, but I really have no time to even look into it. Particularly since I typically use it for post-processing everything except HD. |
24th August 2007, 02:19 | #1851 | Link | |
SPDIF passthrough/AC3 output is still broken for me as well in 1437 on vista x86, 1413 is the last one that works. I don't have any builds between 1413 and 1425 to see which one broke it though, but 1425 was the first one that I noticed it. Last edited by sarvatt; 24th August 2007 at 02:36. |
25th August 2007, 19:37 | #1853 | Link |
ffdshow user
Read more:
http://ffdshow-tryout.sourceforge.ne...opic.php?t=478 Is rev 1424 working?Are there other related issues? Can you please test: http://rapidshare.com/files/51252887/ffdshow.rar.html Last edited by _xxl; 25th August 2007 at 20:00. |
27th August 2007, 01:01 | #1854 | Link |
Curious BetaTester
compiling svn 1439 using gcc-4.0.4 i get this error
TffDecoder.cpp: In member function 'void TffdshowDecVideo::ConnectCompatibleFilter()': TffDecoder.cpp:623: error: expected primary-expression before ')' token TffDecoder.cpp:623: error: '__uuidof' was not declared in this scope TffDecoder.cpp: In member function 'void TffdshowDecVideo::DisconnectFromCompatibleFilter()': TffDecoder.cpp:696: error: expected primary-expression before ')' token TffDecoder.cpp:696: error: '__uuidof' was not declared in this scope TffdshowVideoInputPin.cpp: In member function 'virtual long int TffdshowVideoInputPin::CheckMediaType(const CMediaType*)': TffdshowVideoInputPin.cpp:180: error: expected primary-expression before ')' token TffdshowVideoInputPin.cpp:180: error: '__uuidof' was not declared in this scope make: *** [ffdshow_all.o] Error 1
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
27th August 2007, 04:48 | #1855 | Link | |
27th August 2007, 06:33 | #1856 | Link | |
ffdshow user
Partialy reverted 1424:
29th August 2007, 07:38 | #1857 | Link |
I'd like to try out Albain's latest fixes for the SPDIF passthrough problem (rev 1440), but the latest build available to download is rev 1437. Could I ask clsid or xxl to kick off a nightly build when you have a free moment?
29th August 2007, 14:50 | #1859 | Link |
Curious BetaTester
anyway around it ?
