3rd January 2016, 20:08 | #1541 | Link | |||
3rd January 2016, 20:12 | #1542 | Link | |
Software Developer
Hm, looks like VapourSynth was detected successfully:
3rd January 2016, 20:23 | #1544 | Link | |
3rd January 2016, 20:24 | #1545 | Link | |
Software Developer
Update to a newer program version? If so, what is the last version that was still working okay? Otherwise, maybe you updated to a newer VapourSynth version?
3rd January 2016, 20:28 | #1546 | Link | ||
Software Developer
It's working for me with VapourSynth R26:
3rd January 2016, 20:35 | #1547 | Link | |
I run the same script in in StaxRip_x64 and is fine. Last edited by tona69; 3rd January 2016 at 20:57. |
3rd January 2016, 20:40 | #1548 | Link |
Software Developer
Just tried VapourSynth R29, but everything is working perfectly fine:
http://i.imgur.com/iGZ9xDK.jpg
3rd January 2016, 20:43 | #1549 | Link | |
StaxRip x64 I reinstalled all again and woks fine all : ) Works again Last edited by tona69; 3rd January 2016 at 21:06. |
4th January 2016, 20:00 | #1550 | Link | |
Software Developer
If you have only the 32-Bit version VapourSynth installed, but you have selected "prefer 64-Bit" in the preferences, it was going to fail at the start of the encode. Similarly, if you have only the 64-Bit version VapourSynth installed, but you have not selected "prefer 64-Bit" in the preferences, encode was going to fail as well. This Test build should improve the "32-Bit vs. 64-Bit" selection logic for the Avisynth/VapourSynth source filters: http://sourceforge.net/projects/muld...T.exe/download
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 4th January 2016 at 20:06. |
8th January 2016, 22:03 | #1551 | Link | |
10th January 2016, 08:44 | #1552 | Link |
To make it simple, if one doesnt have Xsinth installed, what input can give?
Why it is not accepting my Huffy avi? You need FFmpeg for this? Why you could even have a patch for audio but not for intermediate uncompressed avi? Why doesnt let me to delete the 64 binaries in a 32 bit environment? So, my input was illegal and it stopped, but i put the following string like command --ctu 32 --cutree --keyint 150 --min-keyint 10 --ipratio 1.9 --nr-inter 390 --sar 16:15 --no-strong-intra-smoothing Is it legal? Last edited by movmasty; 10th January 2016 at 11:35. |
10th January 2016, 16:04 | #1553 | Link | |||
Software Developer
x265: "Raw" YUV data in YUV4MPEG2 format. What is "it"? If you refer to x265 here: At this time, x265 doesn't support reading (compressed) AVI files. Or anything else, except for YUV4MPEG2. Just frame-serve the input from Avisynth/VaourSynth. Or pipe from FFmpeg. That's it. If you want to pipe the input from FFmpeg, then, obviously, you are going to need FFmepg. Avisynth/VaourSynth doesn't need FFmpeg (as a standalone application), but you probably want to use FFMS2 (FFmpegSource). Quote:
AFAIK, there is an unofficial "audio support" patch for x264, but that has never been committed (and probably never will). Quote:
So, my input was illegal and it stopped, but i put the following string like command "legal" in what regard?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th January 2016 at 16:12. |
10th January 2016, 18:17 | #1554 | Link |
I was a bit imprecise sorry,
I refer to x265, it doesnt accet avi in huffy, as i said i dont have avisinth, could you put any prog able to feed x265 in the pack? Since im on win32, i tryed to delete the binaries in 64 bits, it is not possible. is --ctu 32 --cutree --keyint 150 --min-keyint 10 --ipratio 1.9 --nr-inter 390 --sar 16:15 --no-strong-intra-smoothing ok for x265? |
10th January 2016, 21:56 | #1555 | Link | |||
Software Developer
http://sourceforge.net/projects/avisynth2/ In theory support for piping input from FFmpeg could be implemented. But it's currently not on my TODO list. Just use FFMS2 Quote:
Totally depends on what you are trying to achieve...
14th January 2016, 23:23 | #1557 | Link | |
What you did is terrific! Solves the issue I was having exactly. Thank you very much for that. Using the newer test build now. |
24th January 2016, 15:46 | #1558 | Link | |
Software Developer
Simple x264 Launcher v2.65
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 6th February 2016 at 13:25. |
6th February 2016, 13:26 | #1559 | Link | |
Software Developer
Simple x264 Launcher v2.66
https://github.com/lordmulder/Simple...ases/tag/v2.66 Quote:
25th February 2016, 21:35 | #1560 | Link |
Second Pass Fails 9 out of 10 times.
I'm a total newbie to video encoding. A friend at work heard me saying that I was using Handbrake to encode some Quicktime files to Blu-ray and told me I should be using a frame server... WTF? I replied to him! Anyway he came to my place, set me up with: - python-3.5.1-amd64.exe - ffms2-2.22-msvc (I'm using the x64 flavor) - vapoursynth-r29.exe (x64 flavor I guess) - x264_launcher.2016-02-06.exe He wrote me a VapourSynth script whish looks like this: Code:
import vapoursynth as vs # get the core instance core = vs.get_core() # load a native vapoursynth plugin, you can also use the auto-loading # you should use absolute paths as the working directory may not be what you think it is core.std.LoadPlugin(r'S:\Dropbox\softwares\portableapps\codec_encoder\ffms2-2.22-msvc\x64\ffms2.dll') # open a video file; ret is now a clip object path = r'D:\restauration\projet\tropico\deliveries\master\tropico.mov' ret = core.ffms2.Source( source = path ) # flip the video a bit #ret = core.std.Transpose( ret ) # set the clip to be output ret.set_output() Here's the .log (Well, I hope). Sorry I'm a digital colorist not a computer geek. Code:
Simple x264 Launcher (Build #1012), built 2016-02-06 Job started at 2016-02-18, 22:19:28. Source file : D:\encodage\projet\tropico\script.vpy Output file : D:\encodage\projet\tropico\output\script.264 --- SYSTEMINFO --- Binary Path : C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2 Avisynth : No VapourSynth : Yes --- SETTINGS --- Encoder : x264 (H.264/AVC), x64, 8-Bit Source : VapourSynth (vpy) RC Mode : 2-Pass Preset : slower Tuning : Film Profile : High Custom : --level 4.1 --ref 4 --subme 10 --psy-rd 1.00:0.15 --merange 24 --deadzone-inter 21 --deadzone-intra 11 --no-fast-pskip --cqm flat --chroma-qp-offset 3 --threads 12 --lookahead-threads 1 --slices 4 --no-dct-decimate --bluray-compat --vbv-maxrate 38000 --vbv-bufsize 30000 --bframes 3 --b-pyramid 1 --weightb --open-gop --weightp 1 --keyint 24 --min-keyint 1 --rc-lookahead 24 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --qcomp 0.00 --qpmin 0 --- CHECK VERSION --- Detect video encoder version: Creating process: "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64\x264_8bit_x64.exe" --version x264 0.148.2665 a01e339 (libswscale 4.0.100) (libavformat 57.21.101) (ffmpegsource 2.22.0.1) built by Komisar on Jan 18 2016, gcc: 4.8.4 (multilib.generic.Komisar) x264 configuration: --bit-depth=8 --chroma-format=all libx264 configuration: --bit-depth=8 --chroma-format=all x264 license: GPL version 2 or later libswscale/libavformat/ffmpegsource license: GPL version 2 or later Detect video source version: Creating process: "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --version VapourSynth Video Processing Library Copyright (c) 2012-2015 Fredrik Mellbin Core R29 API R3.2 Options: - > x264 revision: 2665 (core #148) > VapourSynth version: r29 (API r3) --- GET SOURCE INFO --- Creating process: "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --info D:\encodage\projet\tropico\script.vpy - Width: 1920 Height: 1080 Frames: 7491 FPS: 24000/1001 (23.976 fps) Format Name: YUV422P10 Color Family: YUV Bits: 10 SubSampling W: 1 SubSampling H: 0 Resolution: 1920x1080 Frame Rate: 24000/1001 No. Frames: 7491 --- ENCODING PASS #1 --- Creating input process: "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m D:\encodage\projet\tropico\script.vpy - Creating encoder process: "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64\x264_8bit_x64.exe" --bitrate 35000 --pass 1 --stats D:\encodage\projet\tropico\output\script.stats --preset slower --tune film --profile high --level 4.1 --ref 4 --subme 10 --psy-rd 1.00:0.15 --merange 24 --deadzone-inter 21 --deadzone-intra 11 --no-fast-pskip --cqm flat --chroma-qp-offset 3 --threads 12 --lookahead-threads 1 --slices 4 --no-dct-decimate --bluray-compat --vbv-maxrate 38000 --vbv-bufsize 30000 --bframes 3 --b-pyramid 1 --weightb --open-gop --weightp 1 --keyint 24 --min-keyint 1 --rc-lookahead 24 --colorprim bt709 --transfer bt709 --colormatrix bt709 --qcomp 0.00 --qpmin 0 --output D:\encodage\projet\tropico\output\script.264 --frames 7491 --demuxer y4m --stdin y4m - y4m [info]: 1920x1080p 0:0 @ 24000/1001 fps (cfr) resize [warning]: converting from yuv422p16le to yuv420p16le x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x264 [info]: profile Main, level 4.1 x264 [info]: frame I:339 Avg QP:10.89 size:467818 x264 [info]: frame P:2145 Avg QP:13.96 size:277862 x264 [info]: frame B:5007 Avg QP:18.17 size:120544 x264 [info]: consecutive B-frames: 5.1% 5.4% 35.4% 54.0% x264 [info]: mb I I16..4: 41.5% 0.0% 58.5% x264 [info]: mb P I16..4: 43.0% 0.0% 0.0% P16..4: 35.5% 0.0% 0.0% 0.0% 0.0% skip:21.5% x264 [info]: mb B I16..4: 12.5% 0.0% 0.0% B16..8: 26.5% 0.0% 0.0% direct:26.8% skip:34.2% L0:10.4% L1:14.9% BI:74.8% x264 [info]: direct mvs spatial:99.7% temporal:0.3% x264 [info]: coded y,uvDC,uvAC intra: 94.9% 39.3% 19.9% inter: 47.8% 11.9% 5.6% x264 [info]: i16 v,h,dc,p: 14% 9% 65% 12% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 9% 20% 10% 11% 11% 9% 10% 10% x264 [info]: i8c dc,h,v,p: 65% 16% 16% 4% x264 [info]: Weighted P-Frames: Y:3.0% UV:0.8% x264 [info]: kb/s:34776.07 encoded 7491 frames, 25.61 fps, 34776.07 kb/s vpyp [info]: Output 7491 frames in 292.32 seconds (25.63 fps) Final file size is 1.26 GB bytes. --- ENCODING PASS #2 --- Creating input process: "C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m D:\encodage\projet\tropico\script.vpy - Creating encoder process: "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64\x264_8bit_x64.exe" --bitrate 35000 --pass 2 --stats D:\encodage\projet\tropico\output\script.stats --preset slower --tune film --profile high --level 4.1 --ref 4 --subme 10 --psy-rd 1.00:0.15 --merange 24 --deadzone-inter 21 --deadzone-intra 11 --no-fast-pskip --cqm flat --chroma-qp-offset 3 --threads 12 --lookahead-threads 1 --slices 4 --no-dct-decimate --bluray-compat --vbv-maxrate 38000 --vbv-bufsize 30000 --bframes 3 --b-pyramid 1 --weightb --open-gop --weightp 1 --keyint 24 --min-keyint 1 --rc-lookahead 24 --colorprim bt709 --transfer bt709 --colormatrix bt709 --qcomp 0.00 --qpmin 0 --output D:\encodage\projet\tropico\output\script.264 --frames 7491 --demuxer y4m --stdin y4m - y4m [error]: bad sequence header magic x264 [error]: could not open input file `-' WARNING: Input process exited with error (code: -1073741819), your encode might be *incomplete* !!! IMPORTANT: The Vapoursynth process terminated abnormally. This means Vapoursynth or one of your Vapoursynth-Plugin's just crashed. PROCESS EXITED WITH ERROR CODE: -1 |
