Old 6th December 2013, 01:11   #21  |  Link
Vampiredom, There is also a compile/run time version in RT_Stats, not based on Frame number, Constructor, Destructor.
Old 13th December 2013, 23:25   #22  |  Link
vampiredom
I finally got around to trying it, StainlessS. It works a treat. Excellent. I have no idea if this is even possible… but it there some way to have a function like this return a program's STDOUT to AviSynth as a string? That would be extremely useful.
vampiredom is offline   Reply With Quote
Old 15th December 2013, 20:10   #23  |  Link
martin53
What you can do today is redirect STDOUT to a file, and read the file from AviSynth. See here
martin53 is offline   Reply With Quote
Old 16th December 2013, 01:03   #24  |  Link
vampiredom
Thanks. Yeah, I already do stuff like this ... I often write Perl scripts and such that generate strings and write them out as AviSynth variables in a text file, Import() them in AviSynth, etc.
It would just be handy (and cleaner) to have AviSynth be able to read the STDOUT directly, I suppose.
Old 10th November 2015, 15:29   #25  |  Link
Been playing a little with functions to extract MediaInfo using CallCmd
Library of funcs, require CallCmd, RT_Stats, GScript. [EDIT: And of course the magnificent MediaInfo.exe, CLI version]
# CallCmd_MediaInfo.Avs
# If Below Global Variable Exists then will use it, Otherwise MediaInfo.Exe must live somewhere in Path of system Environment.
#Global MEDIAINFO_PATH = "C:\BIN\MediaInfo.Exe"          # Modify for your system, Can Comment out if MediaInfo.Exe already in system Path.
# Debug sends ONLY CallCmd output to DebugView
Function CallCmdReturnOutput(String "Cmd",Bool "Debug") {
    # Call with temporary output filename placement insertion position flagged with '@@@FILENAME@@@' (excluding quotes).
    # Returns with output filename in string, or Int(-1) on error.
    myName="CallCmdReturnOutput: "    Debug=Default(Debug,False)
    Find_FN_S="@@@FILENAME@@@"  pos = RT_FindStr(Cmd,Find_FN_S,Sig=False)
    Assert(pos!=0,RT_String("%sOutput Filename not flagged in CMD arg string\n'%s'",myName,Cmd))
    fn=RT_GetFullPathName("MediaInfo_"+RT_LocalTimeString(File=true)+".txt")        # Unique filename, full path
    Cmd=RT_StrReplace(Cmd,Find_FN_S,fn)
    RT_FileDelete(fn)                                                               # Delete output file prior to Call (Unlikely to ever Exist)
    CallCmd(BlankClip(Length=1), Open=Cmd, Hide=true, debug=Debug, Synchronous=1)   # Call the command, wait command terminated.
    return (Exist(fn)) ? fn : -1
# Debug sends CallCmd Info + COMPLETE MediaInfo output to DebugView
Function GetMediaInfo(String VidFn,Bool "Debug",Bool "DelOutputFile") {
    # Get MediaInfo
    myName="GetMediaInfo: "     DelOutputFile=Default(DelOutputFile,True)   Debug=Default(Debug,FalsE)
    VidFn=RT_GetFullPathName(VidFn)
    # If Global Var exists, then use it else expect MediaInfo to be in a system path.
    MEDIAINFO = RT_VarExist("MEDIAINFO_PATH") ? MEDIAINFO_PATH : "MediaInfo.Exe"
    # Below, Double %% is ESCaped representation of single %, ie must use %% for literal single %, % is insertion marker for RT_String.
    Fmt="""%s  --LogFile="@@@FILENAME@@@" --Inform=Video; "%s" """
    # Below inserts MEDIAINFO at beginning and VidFn at end of string
    Cmd=RT_String(Fmt,MEDIAINFO,VidFn)
    Ofn=CallCmdReturnOutput(Cmd,Debug=Debug)
    Assert(Ofn.IsString,RT_string("%sCallCmdReturnOutput return FAILED",myName))
    Txt=RT_ReadTxtFromFile(Ofn)
    (Debug) ? RT_DebugF("MediaInfo:\n%s",Txt,name=myName) : NOP
    (DelOutputFile) ? RT_FileDelete(Ofn) : NOP
    return Txt
# Debug sends ONLY FULL SECTION Info to DebugView
Function ExtractMediaInfoSection(String Txt,String SectionName,Bool "Debug") {
    myName="ExtractMediaInfoSection: "    Debug=Default(Debug,False)    Lines=RT_TxtQueryLines(Txt) T="" InSect= False
    GSCript("""
        For(i=0,Lines-1){S=RT_TxtGetLine(Txt,i)if(S==SectionName){InSect=True}else if(S==""){InSect=False} else if(InSect){T=RT_TxtAddStr(T,S)} }
    (Debug) ? RT_DebugF("%s:\n%s",SectionName,T,name=myName) : NOP
    Return T
Function GetMediaInfoSection(String VidFn,String "SectionName",Bool "Debug") {
    # Get MediaInfo by SectionName (Default="Video") and return as String. Section Name eg "General", "Video", "Audio", "Audio #1", "Text #3"
    # Will return "" if SectionName does not exist (eg "Text #24" does not exist, or "Audio #1" when only "Audio" section in file).
    SectionName=Default(SectionName,"Video")
    Txt=GetMediaInfo(VidFn)
    return ExtractMediaInfoSection(Txt,SectionName,Debug)
Function GetGeneralInfo(String VidFn,Int "Stream",Bool "Debug") {
    Stream = Default(Stream,0)                                            # Default is NO STREAM Number (Unlikely more than 1 General section)
    SectionName=(Stream==0)?"General":"General #"+String(Stream)
    Return GetMediaInfoSection(VidFn,SectionName,Debug=Debug)
Function GetVideoInfo(String VidFn,Int "Stream",Bool "Debug") {
    SectionName=(Stream==0)?"Video":"Video #"+String(Stream)
Function GetAudioInfo(String VidFn,Int "Stream",Bool "Debug") {
    SectionName=(Stream==0)?"Audio":"Audio #"+String(Stream)
Function GetTextInfo(String VidFn,Int "Stream",Bool "Debug") {
    SectionName=(Stream==0)?"Text":"Text #"+String(Stream)
Function GetFirstStream(String VidFn,String SectionName,Bool "Debug") {
    S=GetMediaInfoSection(VidFn,SectionName,Debug=Debug)
    S=(S=="")?GetMediaInfoSection(VidFn,SectionName+" #1",Debug=Debug):S
    return S
# Debug shows only Specific Info.
Function ExtractSpecificMediaInfo(String SectionText,String IDString,bool "Debug") {
    myName="ExtractSpecificMediaInfo: "
    Debug=Default(Debug,false)
    Ret = ""    # Not Found
    Lines=RT_TxtQueryLines(SectionText)
    GSCript("""
        For(i=0,Lines-1) {
            S=RT_TxtGetLine(SectionText,i)
            if(RT_FindStr(S,IDString,sig=False)==1) {
                S=MidStr(S,Strlen(IDString)+1)                              # Strip IDString from Start
                While(RT_Ord(S)==32 || RT_Ord(S)==9) {S=MidStr(S,2)}        # Eat White
                if(LeftStr(S,1)==":") {
                    S=MidStr(S,2)                                           # Strip Colon
                    Ret = S                                                 # Result
                    i = Lines                                               # Break
    (Debug) ? RT_DebugF("'%s' = '%s'",IDString,S,name=myName) : NOP         # Write IDString = Extracted Text to DebugView
    return Ret
Function FirstStreamSpecificMediaInfo(String VidFn,String SectionName,String IDString,Bool "Debug") {
    S=GetFirstStream(VidFn,SectionName)
    return ExtractSpecificMediaInfo(S,IDString,Debug=Debug)                 # Debug Output ONLY eg "Display aspect ratio = 16:9"
Function GetAspectRatio(String VidFn,Int "Stream",Bool "Debug") {
    # Demo individual purpose function
    S=GetVideoInfo(VidFn,Stream)
    return ExtractSpecificMediaInfo(S,"Display aspect ratio",Debug=Debug)   # Debug Output ONLY eg "Display aspect ratio = 16:9"
EDITED:
And demo Client
# CallCmd_MediaInfo_Client.Avs
Import("CallCmd_MediaInfo.Avs")
Colorbars.KillAudio
#NAME="Out.AVI"                                                     # No Stream numbers usually eg "Audio", not "Audio #1"
NAME="VTS_01_1.VOB"                                                 # Possible Stream Numbers eg "Text #1"
STREAM  = 0
DEBUG   = True
# UNCOMMENT ONE OF BELOW and Set Above STREAM #
# Send CallCmd + Complete MediaInfo to DebugView
#S=GetMediaInfo(NAME,Debug=DEBUG)
# Send Section INFO to DebugView
#S=GetVideoInfo(NAME,Stream=STREAM,Debug=DEBUG)
#S=GetAudioInfo(NAME,Stream=STREAM,Debug=DEBUG)
#S=GetTextInfo(NAME,Stream=STREAM,Debug=DEBUG)
#S=GetFirstStream(NAME,"Audio",Debug=DEBUG)
#S=GetFirstStream(NAME,"Text",Debug=DEBUG)
# Send ONLY Specific INFO to DebugView
#S=GetAspectRatio(NAME,Stream=STREAM,Debug=DEBUG)
#S=GetVideoInfo(NAME).ExtractSpecificMediaInfo("Display aspect ratio",Debug=DEBUG)
#S=FirstStreamSpecificMediaInfo(NAME,"Audio","Format",Debug=DEBUG)
# Leave MediaInfo generated file in current directory, Looks something like "MediaInfo_20151110_225534_968.txt"
S=GetMediaInfo(NAME,Debug=DEBUG,DelOutputFile=False)
S = (S!="") ? RT_StrReplace(S,Chr(10),"\n") : S
Return SubTitle(String(S),lsp=0,Font="Courier New")
Oops, got my Channels and Streams muxed up, Demuxed.
Old 10th November 2015, 15:40   #26  |  Link
Further to previous post, here MediaInfo output of typical VOB with stuff that can be extracted.
EDIT: Sections are separated by Blank Line, with section Name at start of each section.
General
Complete name                            : D:\CallCmd\VTS_01_1.VOB
Format                                   : MPEG-PS
File size                                : 1 024 MiB
Duration                                 : 24mn 48s
Overall bit rate mode                    : Variable
Overall bit rate                         : 5 770 Kbps
Video
Format                                   : MPEG Video
Format version                           : Version 2
Format profile                           : Main@Main
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Duration                                 : 24mn 48s
Bit rate mode                            : Variable
Bit rate                                 : 4 695 Kbps
Maximum bit rate                         : 8 436 Kbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 fps
Standard                                 : PAL
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.453
Stream size                              : 833 MiB (81%)
Audio #1
ID                                       : 189 (0xBD)-128 (0x80)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Muxing mode                              : DVD-Video
Duration                                 : 24mn 48s
Bit rate mode                            : Constant
Bit rate                                 : 384 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 68.1 MiB (7%)
Audio #2
ID                                       : 189 (0xBD)-129 (0x81)
Format                                   : AC-3
Duration                                 : 24mn 48s
Bit rate                                 : 384 Kbps
Bit depth                                : 16 bits
Audio #3
ID                                       : 189 (0xBD)-130 (0x82)
Format                                   : AC-3
Duration                                 : 24mn 48s
Bit rate                                 : 192 Kbps
Channel(s)                               : 1 channel
Channel positions                        : Front: C
Bit depth                                : 16 bits
Stream size                              : 34.1 MiB (3%)
Text #1
ID                                       : 189 (0xBD)-33 (0x21)
Format                                   : RLE
Format/Info                              : Run-length encoding
Duration                                 : 24mn 43s
Delay relative to video                  : 3s 400ms
Text #2
ID                                       : 189 (0xBD)-34 (0x22)
Format                                   : RLE
Duration                                 : 24mn 43s
Delay relative to video                  : 3s 160ms
Text #3
ID                                       : 189 (0xBD)-35 (0x23)
Format                                   : RLE
Duration                                 : 24mn 43s
Delay relative to video                  : 3s 480ms
Text #4
ID                                       : 189 (0xBD)-36 (0x24)
Format                                   : RLE
Duration                                 : 24mn 43s
Text #5
ID                                       : 189 (0xBD)-37 (0x25)
Format                                   : RLE
Duration                                 : 24mn 43s
Text #6
ID                                       : 189 (0xBD)-38 (0x26)
Format                                   : RLE
Duration                                 : 24mn 43s
Text #7
ID                                       : 189 (0xBD)-40 (0x28)
Format                                   : RLE
Duration                                 : 24mn 43s
Text #8
ID                                       : 189 (0xBD)-32 (0x20)
Format                                   : RLE
Text #9
ID                                       : 189 (0xBD)-39 (0x27)
Format                                   : RLE
Menu
Old 10th November 2015, 23:11   #27  |  Link
Post #25 updated, general fiddling about.
EDIT: result of client script (extracting and showing only video Info [not audio/text etc]).
Colorbars.killAudio
S=GetVideoInfo("VTS_01_1.VOB")
And this would show, just "16:9".
Colorbars.killAudio
S=GetAspectRatio("VTS_01_1.VOB")
Old 5th April 2016, 18:16   #28  |  Link
martin53
Strange delay under Win10
StainlessS,
would you please help checking if there might be a new Win10-related issue.
I use a loop of AviSynth Script calls to a Thumbsheet-Creator function to make thumbsheets of a set of clips.
The thumbsheet creator uses the ImageWriter function, and to compress the Jpegs and remove the frame number from the filename, CallCmd calls ImageMagick's 'convert' and command prompt's 'del' at the closedown of the modified script in line 63
CallCmd(Close=
\"Cmd.exe /c P:\PortableApps\ImageMagick\convert " + chr(34) + JpgName +"000000.jpg" +chr(34) + " -quality 75 " + chr(34) + JpgName + ".jpg" + chr(34) + " && del " + chr(34) + JpgName +"000000.jpg" +chr(34),
\Hide=true, Synchronous=7)
I used this regularly and without obvious flaws for many months, for a while with 32bit AviSynth+ r1779, and recently updated from Win7 (x64) to Win10.
Now I observe that the thumbsheets all need a suspicious time of exactly 30 seconds to be created, and by some random cause, the time switches to exactly 30 minutes(!) per thumbsheet.
I'm unsure if the 'synchronous' parameter might be broken in Win10, so CallCmd runs into some sort of timeout.
Will change the outmost loop to do these operations outside the AviSynth script and report more findings.
EDIT
After commenting out line in AVS script and adding the commands in the calling AU3 script, processing time is not as stable at 30" as before, and issue is still there. So seems not to come from the CallCmd line but maybe from VirtualDub (which is the portable version 1.10.4 being called directly without the 'portable wrapper' because that is not needed here) or AviSynth+ itself.
AVS script is executed from AutoIt via:
RunWait("P:\PortableApps\VirtualDubPortable\App\VirtualDub\vdub.exe " & $s2 & " /cmd VirtualDub.RunNullVideoPass(); /x", "", @SW_HIDE)
AutoIt: 3.3.14.2, OS: WIN_10/X64, Script: MakeThumbsheets.au3
19970814 21.21.59.avi
20:00:56
19970814 22.18.40.avi
20:01:27
19970814 22.20.00.avi
20:01:58
19970814 22.20.18.avi
20:02:28
19970814 22.20.44.avi
20:02:58
19970814 22.21.27.avi
20:03:29
19970814 22.24.23.avi
20:04:00
19970814 22.24.43.avi
20:04:30
19970814 22.26.22.avi
20:05:01
19970815 22.27.48.avi
20:05:32
19970818 22.43.47.avi
20:06:26
19970818 22.45.48.avi
20:06:57
19970818 22.48.49.avi
20:36:58
19970818 22.51.32.avi
20:37:31
19970818 22.52.36.avi
20:38:01
19970818 22.53.43.avi
20:38:32
19970818 22.56.25.avi
20:39:03
19970818 22.57.46.avi
20:39:33
20:40:04
>>>>>> Please close the "Report Log Window" to exit <<<<<<<
EDIT2
will try AVSMeter instead of vdub NullVideoPass()
Old 5th April 2016, 22:28   #29  |  Link
Mobile:
M53, I'm sorry, don't use/have win 10, me still happy on xp32.
Callcmd comes with source, you are perhaps best person to fix problem. If you have any questions on source then can post or PM and I'll do my best to assist.
Old 6th April 2016, 23:38   #30  |  Link
You could perhaps try without HIDE, see if anything is waiting some keypress or something (or error message).
Old 4th April 2018, 01:03   #31  |  Link
CallCmd v1.04, see first post.
	v1.00,      - 08 Oct 2012, Changed Frames spec, added Open,Close
	v1.01,      - 21 Oct 2012, Add Synchronous Arg.
	v1.02,      - 1 Jan 2013, Add error message on fail.
	v1.03,                  , SetLastError(ERROR_SUCCESS) prior to call.
	v1.04,      - 3 Apr 2018, compile VS2008
Included Avsiynth v2.58, avs+ v2.6 x86, and Avs+ x64 dll's
call, execute
