Old 15th April 2009, 13:07   #1  |  Link
zn
Frame accurate AC3 editor
Anyone know frame accureate AC3 editor wich works from command line (split and join)?
This is possible to be done by FFMPEG, but it only support timestamps, not frame numbers.
May be there are another application with same library wich can use frame numbers?
zn is offline   Reply With Quote
Old 15th April 2009, 18:19   #2  |  Link
tebasuna51
tebasuna51's Avatar
To split ac3 you can use BeSplit or DelayCut (have a command line mode)
The fragments are always a exact number of ac3 frames (32 ms. for 48000 Hz.)
To join ac3 you can use the COPY /B msdos command.
ac3
