10th June 2016, 14:35 | #14421 | Link | |
And show us what you see.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th June 2016 at 14:38. |
17th June 2016, 17:47 | #14423 | Link |
send me sample if you want me to take a look.
17th June 2016, 19:09 | #14424 | Link |
Can we select by default 2 encoding clients (or more) for each PC, every time we run the program?
Preferably the second client minimized to tray too like the first one
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
17th June 2016, 20:13 | #14425 | Link | |
Just create simple batch file Code:
ripbot264.exe EncodingServer.exe EncodingServer.exe
18th June 2016, 11:28 | #14429 | Link | |
for example RunRipBot264and2Servers.cmd Code:
c:\program files\Ripbot264\Ripbot264.exe c:\program files\Ripbot264\EncodingServer.exe c:\program files\Ripbot264\EncodingServer.exe
18th June 2016, 13:23 | #14431 | Link |
EncodingServer always starts in Tray (minimized) by default.
19th June 2016, 06:35 | #14434 | Link | |
Also, I put Ripbot in the Documents folder, which made it a little different. |
20th June 2016, 19:36 | #14436 | Link | |
http://www.mediafire.com/download/jw...tChapterFix.7z I was passing wrong values to this tool Code:
ModifyChapters.exe "original-chapters.txt" (SourceNumberOfFrames/SourceFPS) / (CurrentNumberOfFrames/CurrentFPS) "chapters.txt" Code:
ModifyChapters.exe "original-chapters.txt" (CurrentNumberOfFrames/CurrentFPS) / (SourceNumberOfFrames/SourceFPS) "chapters.txt"
21st June 2016, 04:20 | #14437 | Link | |
21st June 2016, 19:59 | #14438 | Link |
shared folder
[QUOTE=Atak_Snajpera;1768168]
Added: hidden option to move mkv to shared folder. Following lines must be added manually to EncodingClient.ini [hidden settings] MoveMKVtoSharedFolder=1 Added: Updater automatically fixes corrupted updater.ini file Fixed: Downmix 4.0 to 2.0 didn't work Changed: In order to avoid language issues Encoding Client will share ripbot264temp folder using following command line icacls "...\RipBot264temp" /T /C /Q /Grant:R *S-1-1-0:(OI)(CI)F (On commandline icacls cmd is working) Last edited by userx; 22nd June 2016 at 05:58. |
23rd June 2016, 18:14 | #14439 | Link |
Hello Atak_Snajpera, first I would like to forgive me for writing mistakes because they do not speak English (I'm Brazilian) and I'm using an online translator for that, I would say that I am a great admirer of his work and accompany the roughly six years, good will then ask you a layman's question because I do not know if you can:
You can direct more ripbot264 processing to the GPU than the CPU? I ask this question because the GPUs seem to be at higher evolution than the CPUs in a matter of processing, the latest generation of both Nvidia and AMD less lithography 16nm or 14nm had a brutal gain processing performance, you can use this processing in ripbot264 now or in a future release to reduce the load on the CPU? I'm sorry if I'm talking nonsense as I said I am a layman in relation to programming, anyway continue with your great work the ripbot264 is simply wonderful I love the function to use multiple PCs together to encode dividing the work. |
25th June 2016, 01:38 | #14440 | Link |
Posts: n/a
Download Poster no longer working
Hello Atak,
It appears as though The Movie Database may have made changes to their API, your Download Poster application is no longer downloading posters. I have tried on three different computers and two different networks, you can query a title and a list of results will return, but when you select one of the items there is just the spinning wheel that appears with the Downloading... text that accompanies it. |
