1st January 2012, 16:58 | #584 | Link |
ffx264/ffhevc author
ChangeLog for version 9.4.2
* Use a separate variable in config file for setting the default CRF or QP value (DEFAULT_VID_CRFQP). This bumps the config file version to 21 * Renamed the DEFOUTPUT, DEFPATH and DEFBATCHDIR variables to DEFAULT_OUTPUT, DEFAULT_PATH and DEFAULT_BATCHDIR * Be slightly more portable by using #!/usr/bin/env bash instead of #!/bin/bash shebang * Replaced some if conditionals in the -sc option by using 'test' directly * Added an option for passing additional MEncoder parameters. Useful for when the user wants to use something like -mc 0 -noskip, for example * Added support for encoding to DTS audio through the dcaenc encoder which can be found at http://aepatrakov.narod.ru/dcaenc/ * Minor changes to the video_delogo_func() function. Use $sourcetype, $device, $vid and $MPLAYEROPTS variables. Also use -nosound in MPlayer * Improved the mkvtags file. Escape special characters like &, <, > and " in the Title field |
15th January 2012, 13:47 | #586 | Link |
Question from the German Debianforum : With Version 9.3.2 is not (more?)possible to multiplex (mux) AAC/AC3 in Avi. Is that correct?
https://debianforum.de/forum/viewtop...?f=25&t=133846
Henrikx |
15th January 2012, 13:51 | #587 | Link |
AAC in AVI is no longer supported. AC3 in AVI however is still supported
If you want to use AAC, you must select at least one of the other supported containers like MP4/MKV/TS Last edited by microchip8; 15th January 2012 at 13:56. |
13th March 2012, 00:45 | #590 | Link |
I tried to encode video for my mobile phone Samsung S5230
Normally the phone support AAC, AAC+, mp3 and h264 in mp4 conainer. Resolution should be 320x240 Nevertheless I couldn't obtain the video which will bw play on my phone. I have the error - unsupported media format or bitrate over my batchfile is here http://paste.org.ru/?qj93dc mplayer can play this file, but Samsung couldn't Code:
mplayer H264-29612.mp4 Failed to read /etc/mplayer/mplayer.conf.local: No such file or directory Warning unknown option include at line 171 MPlayer SVN-r34728 (C) 2000-2010 MPlayer Team Can't open joystick device /dev/input/js0: No such file or directory Can't init input joystick mplayer: could not connect to socket mplayer: No such file or directory Failed to open LIRC support. You will not be able to use your remote control. Playing H264-29612.mp4. libavformat version 54.1.100 (internal) libavformat file format detected. [lavf] stream 0: video (h264), -vid 0 [lavf] stream 1: audio (mp3), -aid 0, -alang und VIDEO: [H264] 320x240 24bpp 25.000 fps 981.2 kbps (119.8 kbyte/s) Clip info: major_brand: isom minor_version: 1 compatible_brands: isomavc1 creation_time: 2012-03-12 23:13:16 title: H264-29612 comment: Tagged by h264enc 9.4.4 on Втр Мар 13 03:13:16 SAMT 2012 Load subtitles in ./ ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 54.3.100 (internal) Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== ========================================================================== Requested audio codec family [mpg123] (afm=mpg123) not available. Enable it at compilation. Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders AUDIO: 44100 Hz, 2 ch, floatle, 131.0 kbit/4.64% (ratio: 16379->352800) Selected audio codec: [ffmp3float] afm: ffmpeg (FFmpeg MPEG layer-3 audio) ========================================================================== AO: [alsa] 48000Hz 2ch floatle (4 bytes per sample) Starting playback... Unsupported PixelFormat 61 Unsupported PixelFormat 53 Unsupported PixelFormat 81 Movie-Aspect is 1.77:1 - prescaling to correct movie aspect. VO: [xv] 320x240 => 426x240 Planar YV12 A: 1.1 V: 1.0 A-V: 0.171 ct: -0.036 0/ 0 217% 327% 9.9% 4 0 Exiting... (Quit) |
24th March 2012, 19:10 | #593 | Link |
I am having a lot of trouble using this program. I am a movie novice but some of the questions are kind of confusing.
Like this one for example; Code:
Specify the desired Resolution [default is ??]: Then after filling out that entire script this is what I get for an output. What's up with this? Code:
Starting to encode in: 5 4 3 2 1 MPlayer SVN-r31918 (C) 2000-2010 MPlayer Team The hostname option must be an integer: platoon Struct dvd, field hostname parsing error: platoon libdvdread: Encrypted DVD support unavailable. libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed libdvdread: Can't open file VIDEO_TS.BU. Can't open VMG info! No stream found to handle url dvd://platoon Cannot open file/device. Exiting... -> MEncoder has exited with a non-zero value! -> Exiting in function: mencoder_exit() Code:
Specify the DVD title [1-/all] |
25th March 2012, 11:49 | #594 | Link |
@Soapm
You're dealing with an encrypted DVD but your mplayer doesn't have that support Code:
libdvdread: Encrypted DVD support unavailable. |
25th March 2012, 16:07 | #595 | Link | |||
seems there is problem withe transcoding aac with faac
If I will use neroAAC than no problem Quote:
25th March 2012, 20:48 | #597 | Link | |
The good side is that I installed apt-get install libdvdcss-dev I believe that fixed encryption error. At least it looks that way at this point... thanks! |
27th March 2012, 18:13 | #598 | Link | |
I think that's the point - MP4 support unavailable. I will use neroAAC
thank you for the tip Quote:
h264enc, ipod, mencoder, ps3, xbox360 |
