20th August 2012, 06:38 | #4324 | Link |
Agreed. I'm having trouble with SelectEven getting from 50 FPS to 25. The file gets twice as big and the sound is messed up.
MultiMakeMKV: MakeMKV batch processing (Win) MultiShrink: DVD Shrink batch processing Offizieller Übersetzer von DVD Shrink deutsch |
21st August 2012, 06:01 | #4327 | Link | |
video=selecteven(video) in RipBot I'm getting 25 FPS. How do this in Staxrip? Assume 25 FPS does not work.
21st August 2012, 09:11 | #4328 | Link |
assumefps does not work because this function only changes speed of the movie. selecteven discards every other frame. the same effect gives changefps(25) function.
22nd August 2012, 07:27 | #4331 | Link | |
I don't know where to enter this in Staxrip?
2nd September 2012, 08:42 | #4333 | Link |
no one? i want to add "--default-duration 0:%source_framerate_mediainfo%" but staxrip add this one "--default-duration 0:%source_framerate%" and i can't change it, please help me
10th September 2012, 15:31 | #4334 | Link |
libsndfile-1.dll again!
The application has failed to start because libsndfile-1.dll was not found. Reinstalling application may fix this problem.
After formatting XP and reinstalling still getting that bloody annoying message above and a Staxrip crash. Like a said putting that dll in Vdubmod folder does not solve the issue and registering it was impossible. an installer package proved to be useless. Mystifying bug! That said all these problems apparently started after installing NET Framework 4? |
11th September 2012, 11:54 | #4336 | Link |
I have all framework versions prior NET4 installed and I could be wrong about this being the cause. Funny thing is I installed AutoGK, because it has Vdubmod as part of its package and this problem never occurrs. It is probably an XP system specific issue and one which has been bugging me for ages!
11th September 2012, 15:06 | #4337 | Link | |
I have been using StaxRip forever on my Win XP Pro installation without ever getting this error. And neither StaxRip nor VdubMod need this file libsndfile-1.dll. I just searched my whole drive for this file, and I only have one single instance in my LameXP folder. And it does not come frome LameXP itself, it comes from the Fraunhofer AAC encoder which had been extracted from WinAmp. I really can't see why Staxrip would complain when this file is missing. StaxRip does not use the FHG encoder, it uses Nero. Strange... Cheers manolito |
11th September 2012, 15:25 | #4338 | Link | |
Swallowed in the Sea
Probably, it comes from soundout avisynth plugin...
11th September 2012, 22:00 | #4339 | Link |
I once tried copying that miserable littledll to the system 32 folder and it failed miserably as all my other tryouts, but I'll certainly give it a bash and copy directly to avisynth plugin folder. Why didn't I think of that one? I copied to VdubMod instead!
Hopefully it will work. I've more or less had the same set up and am very careful of what goes in my system) so it is very perplexing to know how this bloody error started up in the first place. Thankyou for your very helpful advice. I think I know why it started: I installed Avisynth 2.5.8 rev2 along with new Staxrip version. Previously when things worked fine, I was using an older 2.5.8 version where this dll.file may have been included(or if not it this version of Avisynth was certainly more compatible with Staxrip's processes?) in the installer and it worked with the older version of staxrip. Your advice worked. Cheers Kurtnoise I owe you one! Thanks guys! Last edited by datauser; 12th September 2012 at 17:23. Reason: Update on query! |
9th October 2012, 01:07 | #4340 | Link |
@zarei
Do you try to achieve something special? The value StaxRip passes to --default-duration is the frame rate returned by the avisynth script, the script can be modified using the changefps() function. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
