Old 11th June 2019, 05:05   #3421  |  Link
stax76
stax76's Avatar
Originally Posted by Myrsloik View Post
I've split it into separate 32 and 64 bit installers simply because it's so much easier. Now I just have to test everything again which is super boring.
Maybe writing a test script in a language you want to learn could be fun?
I didn't expect that you like the idea.
Will be testing it once it's done.
Old 16th June 2019, 13:11   #3422  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
R46 RC3/4:
64bit
32bit
The installer was reworked quite a bit to split it into two parts. The registry entries for the 32 bit version are now under a key called Vapoursynth-32 instead so they don't overlap in HKCU.
So test all the different combinations of options and report if it works/doesn't work. Especially for the 32 bit version.
Myrsloik is offline   Reply With Quote
Old 16th June 2019, 13:28   #3423  |  Link
ChaosKing
Typo?
EDIT
I can't install VS 32bit on 64bit windows?
Old 16th June 2019, 13:36   #3424  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by ChaosKing View Post
Typo?
EDIT
Fixed, use the same download link.
Not a typo, just a stylistic choice.
Old 16th June 2019, 13:51   #3425  |  Link
ChaosKing
32 bit (per user install) works great. 64 Bit installer also installed without problems and VS seems to work as usual.
Suggestion: change "Python 3.7" to "Python 3.7 (32-Bit)" in 32 bit installer, as a hint for newbies.
Old 16th June 2019, 14:31   #3426  |  Link
Myrsloik
Myrsloik's Avatar
Makes sense. I've updated the installers with this small change now.
Old 16th June 2019, 14:45   #3427  |  Link
stax76
stax76's Avatar
For me it works (x64 all users), thanks for improving it.
Old 17th June 2019, 12:17   #3428  |  Link
tuanden0
R46 RC3:
64bit
32bit
I installed R46 RC 64bit
I got same error with previous version when installed with per user
Script evaluation failed:
Python exception: No attribute with the name lsmas exists. Did you mistype a plugin namespace?
Traceback (most recent call last):
File "src\cython\vapoursynth.pyx", line 1942, in vapoursynth.vpy_evaluateScript
File "src\cython\vapoursynth.pyx", line 1943, in vapoursynth.vpy_evaluateScript
File "e:\Download\Source\test.vpy", line 6, in <module>
clip = core.lsmas.LWLibavSource(r"E:\Download\Source\test.mkv")
File "src\cython\vapoursynth.pyx", line 1675, in vapoursynth._CoreProxy.__getattr__
File "src\cython\vapoursynth.pyx", line 1537, in vapoursynth.Core.__getattr__
AttributeError: No attribute with the name lsmas exists. Did you mistype a plugin namespace?
tuanden0 is offline   Reply With Quote
Old 17th June 2019, 13:55   #3429  |  Link
Myrsloik
Myrsloik's Avatar
Did you install VS R45 using my installer and did that work?
If you installed it through pip you have a portable version and it autoloads from another directory.
Old 17th June 2019, 15:00   #3430  |  Link
tuanden0
I installed VS R45 and it work.
I tried to install R46 and can only preview on VSEdit.
So I have to install vapoursynth via pip to get it work again
And the autoload after install via pip is correct at "C:\Program Files (x86)\VapourSynth\plugins64"
Old 19th June 2019, 20:46   #3431  |  Link
VS_Fan
R46 RC3:
64bit
32bit
I have tested 64bit without problems. But 32bit installer won't work: After doing some progress installing, it will pop a new window:
Error creating registry key:
HKEY_LOCAL_MACHINE\'SOFTWARE\Vapoursynth'
RegCreateKeyEx failed; code 87.
The parameter is incorrect.
It will repeatedly pop the same error window if you click on "retry" or "ignore". Leaving "cancel" as the only option, which will rollback any changes made.
VS_Fan is offline   Reply With Quote
Old 19th June 2019, 22:09   #3432  |  Link
Myrsloik
Myrsloik's Avatar
R46 RC3/4:
64bit
32bit
Link updated with an RC4 installer for 32 bit. Fixes the invalid registry entries when doing all user installs... and shows just how little attention I paid to 32 bit stuff.
Old 20th June 2019, 16:27   #3433  |  Link
VS_Fan
Thanks, they are both working. 64bit and 32bit are autoloading plugins respectively from:
  • %ProgramFiles%\VapourSynth\plugins
  • %ProgramFiles(x86)%\VapourSynth-32\plugins
Old 20th June 2019, 16:46   #3434  |  Link
ChaosKing
How about a function to report autoloading paths in their respective order? Similar to vsrepo paths.
Old 20th June 2019, 21:39   #3435  |  Link
Myrsloik
Myrsloik's Avatar
I don't understand the request. Basically you should only ever use the user autoload dir unless you have some environment set up in advance for lots of people.
Old 20th June 2019, 22:42   #3436  |  Link
ChaosKing
For easier debugging. For example the user tuanden0, with his R45/R46 plugin loading problem, could quickly check which folder is used. I also had 1-2 cases where I just didn't know which of my vapoursynth versions (or which plugin folder, portable+installed) are currently "active".
EDIT:
user autoload dir = the folder in appdata?
I for example use the plugins64 folder (and custom VS installation). It is a bit annoying to always open the appdata folder. And for newbies even more since appdata is hidden by default.
vsrepo "fixes" it for us, but not for all plugins.
Old 21st June 2019, 16:08   #3437  |  Link
Myrsloik
Myrsloik's Avatar
Yes, the one in appdata where vsrepo also puts things by default. I've added a convenient shortcut in the start menu in R46.
Old 25th June 2019, 08:14   #3438  |  Link
lansing
If I'm converting a dvd source to rgb, should I be using matrix_in_s="170m" instead of "709"?
clip = core.resize.Bicubic(clip, matrix_in_s="170m", format=vs.RGBS)
Old 27th June 2019, 15:00   #3439  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Short answer: yes (if this is NTSC (US, JP) DVD though)
Longer answer: you shouldn't be using matrix_in_s at all, unless your input clip does not have this property for some reason (which would result in an error) or you are sure your clip is wrong and you want to correct that.
Old 27th June 2019, 15:39   #3440  |  Link
lansing
I want to apply a lut on the clip inside vs, so I need to make sure I convert it correctly, as I always got confuse with matrix_s and matrix_in_s.
speed, vaporware, vapoursynth
