5th April 2016, 00:42 | #2001 | Link | |
Yeah, that was a typo. (I looked at the wrong dll). This is from the cmd output: F:\jobs>pfm register "C:\Program Files (x86)\VapourSynth\core64\vsfs.dll" Registering formatter "C:\Program Files (x86)\VapourSynth\core64\vsfs.dll". F:\jobs>vsfs neela.vpy 'vsfs' is not recognized as an internal or external command, operable program or batch file. F:\jobs>start vsfs neela.vpy The system cannot find the file vsfs.
Gorgeous, delicious, deculture! Last edited by asarian; 5th April 2016 at 00:46. Reason: Yet another typo :P |
5th April 2016, 01:10 | #2003 | Link | |
Odd. I installed the latest Pismo File Mount Audit Package build 181 (just installed everything VS two days ago); yet it still has a context right-click 'mount' option (wasn't that supposed to be gone?!). And the mount option, surprisingly, is actually the thing that works. The Pismo system shows 'vsfs' as a registered package, so it's all good. Not sure why I can't make 'vsfs' work from a command prompt; but, then again, I'm thinking it maybe really was meant to only work via that mount option. Anyway, thank you kindly for your assistence!
Gorgeous, delicious, deculture! |
5th April 2016, 09:39 | #2004 | Link |
Hmm, this gives me green borders:
vid = core.std.AddBorders (clip=vid, left=240, right=240, top=0, bottom=0, color=[0, 0, 0]) That can't be right. (Found the syntax for AddBorders on this forum, btw: manual doesn't say how, does it?)
5th April 2016, 09:41 | #2005 | Link |
Professional Code Monkey
Sure it's right. If ypu have a yuv clip you need to specify the color as yuv, not rgb. Or skip iy since it defaults to black anyway.
5th April 2016, 11:30 | #2007 | Link |
So, what is needed then to make QTGMC work under VS 64-bit?! Cuz I'm having the hardest time getting it to even load. (See below). Several things, like MaskTools for VapourSynth, I can't even find anywhere. I call it as follows:
import vapoursynth as vs import havsfunc as haf import mvsfunc as mvf import adjust core = vs.get_core () vid = core.lsmas.LWLibavSource ("f:/video/neela.mkv") vid = haf.QTGMC (vid, InputType=0, Preset="Very Slow", TR2=3, TFF=True) Code:
Script evaluation failed: Python exception: No attribute with the name scd exists. Did you mistype a plugin namespace? Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1489, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26885) File "f:\jobs\neela.vpy", line 10, in <module> vid = haf.QTGMC (vid, InputType=0, Preset="Very Slow", TR2=3, TFF=True) File "C:\Program Files\Python35\lib\site-packages\havsfunc.py", line 978, in QTGMC if TR0 > 0: ts1 = TemporalSoften(bobbed, 1, 255 << shift, CMts << shift, 28 << shift, 2) # 0.00 0.33 0.33 0.33 0.00 File "C:\Program Files\Python35\lib\site-packages\havsfunc.py", line 4287, in TemporalSoften clip = set_scenechange(clip, scenechange) File "C:\Program Files\Python35\lib\site-packages\havsfunc.py", line 4319, in set_scenechange sc = core.scd.Detect(sc, thresh) File "src\cython\vapoursynth.pyx", line 1103, in vapoursynth.Core.__getattr__ (src\cython\vapoursynth.c:20711) AttributeError: No attribute with the name scd exists. Did you mistype a plugin namespace?
5th April 2016, 11:46 | #2008 | Link |
The same as for avisynth you need to download all needed plug-ins.
If you search this thread for "list" you will find some of them: http://forum.doom9.org/showthread.ph...st#post1753688 That being said, maybe the script changed and you will need some more... or not. scd makes reference to SceneChange. In an ideal world the author will maintain an updated list somewhere, because this script is a monster. |
5th April 2016, 12:21 | #2009 | Link | |
Directory of C:\Program Files (x86)\VapourSynth\plugins64 Code:
05-Apr-16 13:11 <DIR> . 05-Apr-16 13:11 <DIR> .. 09-Jun-15 10:37 316,928 DFTTest.dll 25-Mar-16 17:01 1,206,272 fmtconv.dll 15-Mar-14 18:29 2,545,034 libfftw3-3.dll 15-Mar-14 18:29 2,604,934 libfftw3f-3.dll 15-Mar-14 18:30 1,191,702 libfftw3l-3.dll 03-Apr-16 15:12 3,522,048 libmvtools.dll 24-Jan-16 14:59 824,320 libnnedi3.dll 01-Oct-13 11:31 115,930 libtemporalsoften.dll 05-Nov-14 20:00 127,488 templinearapproximate.dll 07-Mar-16 11:13 16,264,192 vslsmashsource.dll 10 File(s) 28,718,848 bytes 2 Dir(s) 102,245,715,968 bytes free
5th April 2016, 12:33 | #2010 | Link |
http://forum.doom9.org/showthread.ph...70#post1694970
Chikuzen stuff is somewhat unmaintained by him, so you need to find updated versions somewhere in the middle of the threads :/ |
5th April 2016, 22:33 | #2012 | Link |
Just want to say, VapourSynth rocks! I was looking at a 90 hours job, with AviSynth and MCTD, and now, in VapourSynth and TempLinearApproximateMC (similar settings), I'm looking at an eta of ~11 hours! As expected/hoped, VapourSynth does an astounding, thread-safe job occupying your full CPU! And all in 64-bit!
Took me a bit to get it all straightened out, but this is gold, I tell you. Pure gold!
6th April 2016, 20:41 | #2013 | Link |
Try out R32 RC2. It will be released in a day or two if no serious issues are found.
Changes: Code:
r32: fixed cache not being automatically added for filters with nfmakelinear flag set (jackoneill) assvapour now has integrated blending (jackoneill) added the experimental function setfieldbased for convenience, expect it to change in the future the tff argument is now optional and ignored for doubleweave when the _field property is present in a valid combination, _fieldbased will also be properly set now the tff argument is now optional and ignored for separatefields when the _fieldbased property is present added support for interlaced resizing extended avisynth mvtools compatibility hack to work for 64bit version as well fixed regression from r29 that would make compatyuy2 conversions vertically flipped vspipe now outputs planar rgb in gbr plane order to better match what other software expects as input now has a slightly more informative error message when the wrong type is passed as an argument in python vsvfw now prints per frame errors on the corresponding frame splicing two incompatible clips could sometimes give a confusing error message removed planeaverage
6th April 2016, 23:43 | #2014 | Link |
^^ Thx for (soon to be) R32!
When it is released, will I just be able to install it over the existing R31 (never done this before with VapourSynth), or do I need to preserve plugins64 directory and such first?!
7th April 2016, 20:50 | #2017 | Link |
Btw, does anyone know of a filter like AutoAdjust (64-bit) for VS? Would really love to see that one day.
Or at least maybe someone knows of a way to adjust brightness/contrast?
Gorgeous, delicious, deculture! Last edited by asarian; 7th April 2016 at 21:06. |
speed, vaporware, vapoursynth |
